Replacing ceiling tile & sprinkler head in way - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-29-2004, 11:05 AM   #1 (permalink)
Member # 5399
Does anyone know if there is a way to remove the sprinkler head to replace a 2'x4' celing tile w/o haing to have a *slit* in the newly installed ceiling tile. Attached is a picture of said sprinkler head.
Mel85CJ is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:15 AM   #2 (permalink)
Hero's Avatar
Member # 22799
Note sure, but dont bump that thing. You bust that little thermometer thingie and the whole system with kick off. Ask me how I know. Or rather, dont.
Hero
Hero is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:15 AM   #3 (permalink)
Dieselmh's Avatar
Member # 6417
Send a message via Yahoo to Dieselmh
Nope, not without shutting off the water, draining the system and unscrewing the head.
Dieselmh is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:15 AM   #4 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
Whats wrong with the one that is in there?
I would remove all the tiles around it and try to spread the hangers apart a little. You may even try tilting the tile to get it to clear.
Space For Rent
Benny is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:17 AM   #5 (permalink)
Member # 5399
There really isnt anything wrong with the tile, but.. hey.. they want it done.. so.. gotta figure it out. what a pita...
Old 04-29-2004, 11:18 AM   #6 (permalink)
Member # 9821
Cut the trim ring with a pair of snips then pick up a retrofit "hinged" one.
OR
Shut down the system, find the service drain, open it to drain the system, unscrew the head and replace the tile.
You do have your red box of spares heads with the service wrench in it don't you???
I'm pimping ScottFJ40's
so he owes me a dollar.
[color=orange] Two wrongs don't make a right but three rights make a left.[/color]
[color=yellow]I before E except after C except in words like neighbor and Budweiser.[/color]
[color=lime]May clinging breasts always come to your aid in the kitchen.
[/color]
ForestCam is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:20 AM   #7 (permalink)
Josh83's Avatar
Member # 5899
Send a message via AIM to Josh83
OR
Be sure to notify your insurance co. if you do this, and your fire dept. We have to when we shut the sprinkler system down.
Josh
"Tim McGraw is my cousin. Everyone says we look alike, only i am the uglier more out of shape version of him with creepy eyes. He never calls. He beat me up once at a family reunion when i was 8. Then he married Faith. Goddam prick."
Josh83 is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:20 AM   #8 (permalink)
Member # 13966
Nah, get a few days off out of it.
Take a big hammer and knock it off!
Joe
[FONT=Comic Sans MS]See, I told you it would break.[/FONT]
Rocktoyo is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:23 AM   #9 (permalink)
Member # 9821
We never do when the system is inspected by the sprinkler company.
Had to wrap that damned fire bell in a blanket 'cause it was driving me nuts as often as the guy was setting it off.
[/color]
Old 04-29-2004, 11:26 AM   #10 (permalink)
NastyNate's Avatar
Member # 13276
Send a message via AIM to NastyNate
Take off the trim ring. Should be held on with a little screw, similar to trim rings on bathroom hardware like towel racks. Remove old tile. Measure center of head from all sides and mark on new tile. Use hole saw smaller than trim ring, but larger than sprinkler head. Replace tile.
Those who give up a little freedom for a little security, WILL SOON LOSE BOTH AND DESERVE NEITHER!
NastyNate is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:44 AM   #11 (permalink)
Member # 8893
There are two kinds of escuchons, ones that press into a cut hole in the ceiling tile and one that is attached to the sprinkler head/drop. the ring will come off without removing the sprinkler head, at which point you should be able to lift the tile up, tilt it and pull it down. the sprinkler head will either be a fusable link or glass bulb. the glass bulb will take a little more bumping the fusible link will be two pieces of metal held together with solder designed to break at a specific temp.
the final point to this book is the tile will come down without removing the sprinkler head.
Allen_69 is offline   Reply With Quote Quick reply to this message
Old 04-29-2004, 11:52 AM   #12 (permalink)
Member # 5240
What Allen 69 said.
Also, the company that certifies your system will have tool to stop the head if the element is broken. It like pliers but expands to fill the hole.
Our company policy is to turn one over to maintenance dept at the end of a job.
Rob 85K5
Rob 85K5 is offline   Reply With Quote Quick reply to this message
