Rekeying a garage door opener - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-01-2004, 03:01 PM   #1 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
Send a message via AIM to Roxywheels Send a message via Yahoo to Roxywheels
Tell me how its done. We need to rekey Steph's garage door ASAP and she can't find any of the papers for it. Its a Craftsman and the ID she found on it is HBW1127. Thanks!
I'm not a bitch, I just play one in your life
Roxywheels is offline   Reply With Quote Quick reply to this message
Old 05-01-2004, 03:10 PM   #2 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
The one I had a few years ago used dip switches. Open up the battery door and see if theres a row of white switches that you can slide or press off/on, should be about 8-10. Just change the switches on both the controller and the opener itself.
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Joe_W is online now   Reply With Quote Quick reply to this message
Old 05-01-2004, 03:12 PM   #3 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
I think what she wants to change the code on is the keypad on the outside of the house. Any idea? It would be easier if we were at her house and then we could see if there is an 800# to call or any other details, but this is all she has given me
Old 05-01-2004, 03:19 PM   #4 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Nope..I never had a keypad so no ideas. I searched on that model number but no hits.
Old 05-01-2004, 03:21 PM   #5 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
I searched to and nothing came up. I'll have to go over and check it out myself.
Old 05-01-2004, 03:26 PM   #6 (permalink)
ChevyGal's Avatar
Member # 4033
I believe you will have to have someone hold down a button on the back of the celing mounted until (the motor) and someone at the keypad to enter in the new code. I remember helping a friend a long time ago doing this. I don't recall the order or really much else. But at least you can check and see if this does something (beeps, blinks gives some clue it does something). Maybe tinker with it until you hit on the right thing? I'll see if I can find something....
Needs more cowbell!
ChevyGal is offline   Reply With Quote Quick reply to this message
Old 05-01-2004, 03:31 PM   #7 (permalink)
ChevyGal's Avatar
Member # 4033
If you can sift through this one one of these people hit on the right combo of things you can try...
http://www.bobvila.com/wwwboard/messages/16998.html
I'll keep looking.... here what the search turned up....
http://search.yahoo.com/bin/search?p...0garage%20door
Needs more cowbell!
Old 05-01-2004, 03:42 PM   #8 (permalink)
Girly Bender
Roxywheels's Avatar
Member # 1842
Thanks Steph! I think I found what will work to help out the other Steph!
Old 05-01-2004, 05:00 PM   #9 (permalink)
M.Martian's Avatar
Member # 3945
Here is the instructions for my Craftsman wireless keyless entry unit.
1. punch in your 4-digit code
2. press the enter button and hold.
3. while still holding the keyless entry button down, push the "Smart Button" (either round or square) on the back of the powerhead mounted to your garage ceiling.
It should then trigger the garage door to open. Then let go of all of your buttons. From then on when you enter the 4-digit code and press enter the door should open/close.
Mark
M.Martian is offline   Reply With Quote Quick reply to this message
Old 05-01-2004, 09:19 PM   #10 (permalink)
Member # 2059
Does she have a normal garage door button just inside the door frame adjacent to the outdoor keypad?
The best Web Host EVAR!
Ultra4 IT Flunkie
Chister is offline   Reply With Quote Quick reply to this message
Old 05-01-2004, 09:21 PM   #11 (permalink)
Member # 2059
If so.... pry off the panel as shown above.
Inside, you will find a battery and a switch.
Replace the 9 Volt Battery while you are here (it will save you greif later when it dies and you cannot get into the house because of it.) Notice the OEM SEARS battery that has been in the opener for atleast 7 years and no longer works.
Ultra4 IT Flunkie
Old 05-01-2004, 09:25 PM   #12 (permalink)
Member # 2059
move the selector switch to "PROGRAM"
Key in your 4 digit number on the exterior keypad
return the switch to "OPERATE"
test 4 digit code.
Ultra4 IT Flunkie
Old 05-01-2004, 09:57 PM   #13 (permalink)
MKBruin's Avatar
Member # 6407
roxy, I sell these. Call me and I can walk you through it!
______________________________
"Did you think this forum served a legitimate socially redeeming function other than mental masturbation?" posted by Bobzooki
MKBruin is offline   Reply With Quote Quick reply to this message
