Math help: how do you calculate the length of a spiral? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2008, 06:44 AM   #1 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
Say you had a wire spiraling around a 30" pipe at a 6" pitch. How would you go about calculating the length of that wire per foot of the pipe?
I have an equation for doing such but it makes no sense to me and I wanna make sure it's right.
I love Dicks and will continue to shop there.
bgaidan is offline   Reply With Quote Quick reply to this message
Old 07-10-2008, 06:45 AM   #2 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
cut wire off... flatten out on floor, measure.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote Quick reply to this message
Old 07-10-2008, 06:59 AM   #3 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
godamnitmothfuckle this is hypothetical...gimme the mathematical way of solving it
Old 07-10-2008, 07:00 AM   #4 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
What is your level of math...I can give it to you is terms of calculus...
Schmozilla is offline   Reply With Quote Quick reply to this message
Old 07-10-2008, 07:08 AM   #5 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
I went to clemson too.....so please use small words and speak slowly!
The formula they used is:
length (per foot) = circumference+(pitch^2)^.5/pitch
however, the (pitch^2)^.5/pitch really equals one so it comes out to:
length = circumference + 1
I understand this is probably a close approximation of the actual length and not as accurate as a calculus method would get it, but I still don't fully understand where it's coming from.
Old 07-10-2008, 07:14 AM   #6 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Not if the exponent is .5/pitch since pitch is variable.
EDIT
Your talking about a helix, here is a link.
ROXROES is offline   Reply With Quote Quick reply to this message
Old 07-10-2008, 07:16 AM   #7 (permalink)
Member # 12499
If it's a spiral, isn't the pitch constantly changing?
Sounds like it would require the utilization of calculus concepts.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 07-10-2008, 07:23 AM   #8 (permalink)
Schmozilla's Avatar
Member # 38562
I get 96.94 inches per wrap with that formula...2 wraps = 193.28 inches
EDIT: With Calculus I get 191.727 Inches
For the calc...
Parametric equations :
x= r*cos(t)
y= r*sin(t)
z= ct
to make z=6 inches when t= 2*pi c= 3pi
SO the length of that helix over 1 foot (4pi)=
Integral from 0 to 4pi of (sqrt(x^2 +y^2 + z^2)dt
sub the parametric equations in and you get
(sqrt((r*cos(t))^2 +(r*sin(t))^2 + 3pi(t)^2)dt from 0 to 4pi...
any way all that shit = 191.7272
Old 07-10-2008, 07:27 AM   #9 (permalink)
Member # 6562
If it was installed poorly, yes
This sounds just like an auger. The flights (or wire) can have an exact, constant pitch along the rotation of the shaft.
Kinda like when you look at an auger in one spot and rotate it, that spot will appear to move down the length of the shaft. That is the pitch, or gap remaining constant.
3/4 Ton YJ
PhatXJ is offline   Reply With Quote Quick reply to this message
Old 07-10-2008, 07:28 AM   #10 (permalink)
cool story
ROXROES's Avatar
Member # 97574
Pitch is defined as change/revolution. If it is revolving around a pipe with a constant OD then the pitch will be constant. I meant variable as the pitch is a variable in the equation, not the application.
EDIT
Drew this up quick, this is 6" pitch, 30" OD. This is the segment he would be calculating.
Old 07-10-2008, 07:30 AM   #11 (permalink)
Member # 12499
We are discussing two different things. A spiral starts in the center and moves outward (or at least, that's how I was visualizing it), thus the radius is constantly changing. What you've described is not a spiral, but a fixed diameter pitch.
Old 07-10-2008, 07:33 AM   #12 (permalink)
Member # 6562
Right, but a wire wrapped around a pipe is not a spiral in that sense. It's more like a spring spiral with a fixed ID and OD. The pitch will remain constant (if it was built, and installed correctly).
What you are describing only holds true if the OD of the pipe changes diameter throughout its length. Edit: and even if the pipe size changed, the pitch could still remain constant. The length of wire per foot would change though.
3/4 Ton YJ
Old 07-10-2008, 07:35 AM   #13 (permalink)
cool story
ROXROES's Avatar
Member # 97574
I think they just had poor wording on the problem. Spiral is a rather broad term. It states "pipe" in the problem which would have a fixed OD.
We're discussing a "helix" here:
he·lix Audio Help /ˈhilɪks/ Pronunciation Key - Show Spelled Pronunciation[hee-liks] Pronunciation Key - Show IPA Pronunciation
–noun, plural hel·i·ces Audio Help /ˈhɛləˌsiz/ Pronunciation Key - Show Spelled Pronunciation[hel-uh-seez] Pronunciation Key - Show IPA Pronunciation, he·lix·es. 1. a spiral.
2. Geometry. the curve formed by a straight line drawn on a plane when that plane is wrapped around a cylindrical surface of any kind, esp. a right circular cylinder, as the curve of a screw. Equation: x = a sinθ, y = a cosθ, z = b θ.
Old 07-10-2008, 07:35 AM   #14 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
It's basically a helix, as described a couple posts ago. If you read the original question, it is basically a wire wrapping around a pipe. An auger flight is a good example.
We did just find an error in the way we were looking at the equation, it should be:
(circumference+(pitch^2))^.5/pitch
I was missing a set of parenthesis.
I foung this little explanation about calculating the railing length around a spiral staircase, which is ultimately the same thing:
http://www.newton.dep.anl.gov/askasc.../math99080.htm
Old 07-10-2008, 07:36 AM   #15 (permalink)
Member # 12499
OK, I read the original post and now I see that it isn't that difficult of a calculation.
Old 07-10-2008, 08:07 AM   #16 (permalink)
Member # 6562
Using this formula, I come up with 188.495" wire length per foot.
This is using 0" as a diameter of wire, which is unknown at this point, and will have an effect.
Formula is shown on this web page with the online calculator.
http://deepfriedneon.com/tesla_f_calchelix.html
3/4 Ton YJ
