The LAN cable nightmare from the motivational poster thread... WTF? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2008, 10:38 AM   #1 (permalink)
Soundguy's Avatar
Member # 32677
I see lots of data closets at work and I've never seen anything like this.
I've seen much messier closets, just nothing with this many patch cables in it, what in the hell are they doing in here?
The bad ones usually look like this but I can't imagine what all that yellow data cable above is for.
Soundguy is offline   Reply With Quote
Old 07-20-2008, 10:42 AM   #2 (permalink)
loveshackle's Avatar
Member # 9925
You just wanted to share your out of focus picture, admit it. Was this really worth starting a thread? Really?
"All great change in America begins at the dinner table" ~ Ronald Reagan
loveshackle is offline   Reply With Quote
Old 07-20-2008, 10:46 AM   #3 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
I have no doubt in my mind that THAT is a legacy SBC telco data rack room.
Chister is offline   Reply With Quote
Old 07-20-2008, 10:46 AM   #4 (permalink)
Soundguy's Avatar
Member # 32677
I just found that using google idiot, I'm simply trying to figure out what they're doing in the first picture. I can't see how they need that much cable or how it's being run. If it wouldn't have taken months and thousands of $$$ I would think the picture was staged.
Old 07-20-2008, 10:48 AM   #5 (permalink)
Soundguy's Avatar
Member # 32677
So would they just be using a shit load of patch cables going from patch panels to switches or something like that?
Old 07-20-2008, 10:49 AM   #6 (permalink)
Rerock's Avatar
Member # 28604
Agreed.
Rerock is offline   Reply With Quote
Old 07-20-2008, 10:51 AM   #7 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
Absolutely.
Out network room isnt THAT bad, but pretty close.
Hell. it could be a LOT worse.
Now here is the thing..
With THAT many cables... the built in cable management systems of the racks can only handle SO MUCH physical cable. WIth THAT much wiring, it just overflows.
Solution? Less port density on your racks.
But that means more square footage for rack space.
SO.. it just grows like The Blob
Old 07-20-2008, 10:56 AM   #8 (permalink)
Soundguy's Avatar
Member # 32677
Absolutely.
So at that point a single cable failure means unhooking it and leaving the bad cable in then just adding another correct or does someone actually take the time to remove the old cable?
Old 07-20-2008, 11:05 AM   #9 (permalink)
nahmus's Avatar
Member # 57779
I'll have to see if I have pictures of the last cable cleanup I did. It was nowhere near that, it was actually a small room. Its just that all the servers were just sitting on the floor, PRODUCTION servers sitting on the floor, one on its side. They just bought what ever size cables were cheapest and plugged them in and left them. No patch panels just direct connnect ends... It really looked like someone just threw the cables near the servers and hopes they would work.
nahmus is online now   Reply With Quote
Old 07-20-2008, 11:25 AM   #10 (permalink)
Member # 9925
"google idiot"???
Google yourself. Type "fawking blenders with bleach and tacks" and see what comes up.
Old 07-20-2008, 11:32 AM   #11 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
That all depends on the network admin at the time.
For instance, my predecessor left me shit like what you see.
OTOH, I am meticulous about my cabling. I spent one weekend at my old job and removed almost 2 industrial dumpsters full of old cable.. some of which hadnt been used in almost a decade.
Old 07-20-2008, 11:37 AM   #12 (permalink)
Soundguy's Avatar
Member # 32677
"google idiot"???
Still waiting for the funny... let me know when it arrives.
Old 07-20-2008, 11:38 AM   #13 (permalink)
Soundguy's Avatar
Member # 32677
Is most of it premade patch cables of different lengths? I can't see anyone making custom patch cords in an environment like that right?
Old 07-20-2008, 11:42 AM   #14 (permalink)
Banned
Member # 6620
Send a message via ICQ to bit breaker Send a message via Yahoo to bit breaker
it starts with 1 cable placement. more cable management, better cable placement and multi-colored cables help a lot. usually only 1 port goes bad, not both, so moving to a new port is only necessary. I have never lost a patch cable unless the little clippy thing broke then chunk the cable and put a new one in. I have had to manage network pods where we would punch down one side, that was interesting to troubleshoot.
bit breaker is offline   Reply With Quote
Old 07-20-2008, 11:52 AM   #15 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
wrong.. sorta.
MOST of the time, prefabbed patch is preferred in datacenters.. Simply because it is certified. But at the same time, there are many times that a prefab is not the right length or the right pinout. Thus you have to fab your own.
I'd probably say in my Datacenter it is about 85%/15%
Of course, this does not include the premesis wiring, which is almost exclusively custom fabbed.
I mean I can build CAT5 bale ends in my sleep.. but the factory ones are just inherently better and more reliable.
Old 07-20-2008, 11:54 AM   #16 (permalink)
bremen242's Avatar
Member # 28687
yup. That is what I do in monster COs and cross boxes. If it won't pull easy, it stays.
That is with jumper wire. I imagine CAT5 stays no matter what.
*Note - not that I like doing that, but for the last 30 years every other tech did the same thing, so it'd take me 10 years just to remove everything and hope I didn't knock 20 people out of service
bremen242 is offline   Reply With Quote
Old 07-20-2008, 11:57 AM   #17 (permalink)
bremen242's Avatar
Member # 28687
Plus, they have those nifty molded no snag plug covers.
Old 07-20-2008, 12:00 PM   #18 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
and that is the big problem. Some wires... just because you touch them, they'll go bad. 8-10 years sitting in the same spot, then you sneeze on it.. and whammo.. you just took down internet to the state of new york.
Old 07-20-2008, 12:01 PM   #19 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
which themselves are both a pain and a blessing.
Soemtimes they work great.. sometimes they get in the way.
Old 07-20-2008, 12:15 PM   #20 (permalink)
cannoncrawler's Avatar
Member # 57161
looks like it is "in the mailbox"
" Prudence, indeed, will dictate that Governments long established should not be changed for light and transient causes....But when a long train of abuses and usurpations.... it is their right, it is their duty, to throw off such Government, and to provide new Guards for their future security."
cannoncrawler is offline   Reply With Quote
Old 07-20-2008, 02:34 PM   #21 (permalink)
Shark Baiter
Chum731's Avatar
Member # 30572
The hyena picture and the cable picture got the most response of the last batch I posted - I didn't make them though...
When i worked in Atlanta - I went with Bell South down to the phone trunk in the basement of the building I worked in with the tech. Take the yellow out of the picture and replace it with copper phone cable. It was a nightmare with little orange tags hanging all over that were problem tickets...
Chum731 is offline   Reply With Quote
Old 07-20-2008, 03:54 PM   #22 (permalink)
Grim Reaper's Avatar
Member # 6726
Yellow in a Telco switch is usualy Fiber.
The switches in Atlanta that I have been in never look that bad.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR]
"He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill
Grim Reaper is online now   Reply With Quote
