What size generator can run a Hobart Handler 210? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-17-2009, 06:05 AM   #1 (permalink)
Who?? Me??
snobrder's Avatar
Member # 12698
I'm going to look for a generator to keep in my trailer for events this year but I'd like to get one that may be able to run my welder also. The welder is a Hobart Handler 210 which is a small welder but still a 220. How many watts does the generator need to be to run a 220 welder?
Mike C - SAVE TELLICO POST # 152
Thanks to: BFGoodrich, Solid Axle Ind, East Coast Diffs, Carolina Driveline, Blazer MX, OX USA, Winchline.com, Griffin Thermal Products, Sway-a-way
Eastern team #94
The INTERNET... it's not just for porn anymore!!!
snobrder is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 06:10 AM   #2 (permalink)
Cue-Ball's Avatar
Member # 17311
Use the West Virginia Formula
W = V*A
You know the voltage and you know how many amps you are running it at, so you know the wattage required. Quick google search brings this:
Current Range: 30-210 amp,
So rage is:
W = 30 * 220
W = 6600
and
W = 210*220
W = 46200
Your wattage range would be 6600 - 46200. find out how many amps you run on what settings and you should be able to find a generator to handle it.
Nex Pro Evinco [COLOR="Black"]"Death Before Defeat"[/COLOR]
Cue-Ball is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 06:12 AM   #3 (permalink)
Member # 81214
A 46kw gen will be trailer mounted.
Never Monday is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 06:27 AM   #4 (permalink)
cj7jeep81's Avatar
Member # 15718
W = V*A
So rage is:
W = 30 * 220
W = 6600
and
W = 210*220
W = 46200
that's not right. the welder may output 210 amps, but it sure isn't sucking that in. find out how many amps it takes to feed it. i'm guessing 30-40 but double check, then use that formula. i'd guess a 7k watt generator would work.
cj7jeep81 is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 06:29 AM   #5 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
My mm210 pulls in up to 30A IIRC.
Probably want your generator to be at least 8,000 running continuous.
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 06:30 AM   #6 (permalink)
CrazyHorse's Avatar
Member # 3420
Send a message via ICQ to CrazyHorse Send a message via AIM to CrazyHorse
W = V*A
So rage is:
W = 30 * 220
W = 6600
and
W = 210*220
W = 46200
the 30-210 amp is on the output though, which is only a max of 34 volts. That gives you a max of 7,140 watts, Hobarts website lists it as needing a 4,600 watt input though.
http://hobartwelders.com/products/wirefeed/handler210/
John Foottit 70 Bronco Buggy
Contact me about Custom Cabinetry www.beniciacabinetry.com
CrazyHorse is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 06:32 AM   #7 (permalink)
Who?? Me??
snobrder's Avatar
Member # 12698
Ok, I found it. According to Hobarts site if I read it corrrectly volts are 230 at 24 amps input.
230v * 24 = 5520 watts. I'm sure I want need it on the max setting so a 5500 - 6000 should do it. Thanks.
Eastern team #94
Old 04-17-2009, 06:39 AM   #8 (permalink)
Member # 9835
Ive read that migs can be funky when working off of a gen. I would do a lot more research before buying one.
ChiScouter is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 07:00 AM   #9 (permalink)
YJ4RoX's Avatar
Member # 1930
We use a hobart handler 210 off a generator here at work all the time. Runs great. Its just a small gas generator, two guys can easily lift it into a 1 ton dodge dually. I will go look at the amp/watt specs on it.
YJ4RoX is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 07:04 AM   #10 (permalink)
Member # 132811
I would suggest running a 7.5k genny which is about 5k continuous.
This is what I use to fun my Lincoln 175 mig. It works great IMO. Never had an issue. Just I made sure to run short bust welding thick steel 1 to 2 passes then let it set for a min or two, because the duty cycle will be trying to keep up.
http://www.bargainoutfitters.com/cb/...4&kwtid=239584
* 13HP 4-cycle OHV air-cooled engine
* Operating noise 76dB
* 2 AC 120V outlets, one 120V twist-lock outlet, one 120V / 240 twist-lock outlet and one 12V DC outlet
* EPA approved
* Peak power: 7,500W
* Rated power: 6,000W
* AC rated current: 50A @ 120 / 25A @240
* DC rated current: 8.3A @ 12
* 6.6-gallon fuel tank; unleaded gasoline
* Recoil start
* Weighs 198 lbs., measures 28 x 21 x 23 1/2".
1979 Bronco 390 swap c6 in process.
oldschoolrides is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 07:07 AM   #11 (permalink)
Hunt's Avatar
Member # 121053
What size breaker do you run the welder off of at home? Mine is on a 50 Amp. Many people run their welders off of standard 30 Amp dryer outlets (with the correct plug). Worst case scenario W=50*210 or 10500 I would think. ChiScouter is completely correct. Most “home use” generators produce a square wave instead of a perfect sine wave. I have hear it called “dirty AC”. Someone correct me if I am wrong. I would suggest talking to a welding shop rep. I am looking at getting a newer Lincoln Ranger because it has compensated for the dirty AC affects of the generator portion and you can run other welders off its outlets. Talk to the experts. I am not one.
Hunt is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 07:36 AM   #12 (permalink)
Ball Ground
Member # 34061
I have a Lincoln 110v 180a that I've tried to run on a 3500w gen and it won't run it.
Bull Durham Racing
Team #360
Upper2 is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 07:43 AM   #13 (permalink)
Member # 10867
Check with 100dollarman (whatever his name is) about finding you a used 15KW TQG from military surplus. It will run on diesel, has sound baffles so as not to be extremely loud, can be skid- or trailer-mounted, and has the proper sine wave for running your welder. You should be able to pick one of those up on the cheap.
BTW: That's 15KW CONTINUOUS output. The safety shutdown is set for 18KW, so you can easily run a couple welders off it, or a welder and whatever else you want. It will also run 12 hours on a tank of fuel, so no worries about refilling a hot generator.
[QUOTE=Mrs.CSR;14024539]You were good[/QUOTE]
DRTDEVL is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 07:55 AM   #14 (permalink)
Cue-Ball's Avatar
Member # 17311
I R dumb
Old 04-17-2009, 08:11 AM   #15 (permalink)
Member # 43066
Renegade™ 180
Industry-first all-in-one wire welder/generator
http://www.millerwelds.com/products/.../renegade_180/
ESPEED is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 08:59 AM   #16 (permalink)
Member # 9835
Originally Posted by ESPEED View Post
Renegade™ 180
Very sexy, sorry to admit it but there is one less kitten in the world
Old 04-17-2009, 09:11 AM   #17 (permalink)
k5chevyblazer's Avatar
Member # 16358
Send a message via ICQ to k5chevyblazer Send a message via AIM to k5chevyblazer Send a message via Yahoo to k5chevyblazer
I run mine with this with zero issues, even have welded 3/8"s no prob
Ryan Morgan
Tow Rig =
Rock Toy =
and we are on Facebook too.
k5chevyblazer is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 09:12 AM   #18 (permalink)
Member # 16358
Renegade™ 180
that is bad ass and all, but MM210 $600, Generator to push it $600. Plus you can use the welder at home/garage.
Ryan Morgan
Tow Rig =
Rock Toy =
Old 04-17-2009, 09:39 AM   #19 (permalink)
Member # 43066
The Renegade can be plugged in to the wall at home and used as a normal welder.
I linked it for the cool factor and for the specs.
Dual Power: 230 V, 19.5 A, 60 Hz, Single-Phase, or 10 HP engine @ 3600 RPM
Amperage Range
30 - 180 A
Generator Output - Rated at 104°F (40°C)5000 Watts Peak, 4500 Watts Continuous
Weight
275 lb (125 kg)
Engine
Kohler 10 HP at 3600 RPM
Looks like a 10HP 5,000w gen may work fine with a 180 welder. The 210 is not a big stretch from there.
Besides the original question was not what is the cheapest option. I have worked out of a trailer in remote locations. Having a welder and generator in one small package, that is easy to load, and takes up less space would be worth some more $$ to me.
Old 04-17-2009, 10:01 AM   #20 (permalink)
Member # 16358
I hear ya on the bling factor for sure. I doubt it would be able to handle being bolted down into the back of a flatbed. I doubt it can handle being in the rain and shit. No way would I want to load and unload 275 lbs each time I needed it. But way cool, props on that part.
edit: And I am running a MM180 not the MM210
Ryan Morgan
Tow Rig =
Rock Toy =
Old 04-17-2009, 10:02 AM   #21 (permalink)
cj7jeep81's Avatar
Member # 15718
show me where you can get a mm210 for $600. at cyberweld they're just shy of $1k.
edit: didn't know miller made a something compatible to the hh210. saw the 211 for $1k, and figured it was the latest version of the 210.
Old 04-17-2009, 10:07 AM   #22 (permalink)
Member # 16358
I had to edit my post, I have the 180, not 210
cool deal on ebay for the Renegade 180
http://cgi.ebay.com/Miller-Renegade-...QQcmdZViewItem
Ryan Morgan
Tow Rig =
Rock Toy =
Old 04-17-2009, 10:15 AM   #23 (permalink)
Member # 43066
With the Renegade you can also use the 3035 spool gun and extension and weld 45 ft away. With proper ventilation you would not even have to take it out of the trailer.
Old 04-17-2009, 12:59 PM   #24 (permalink)
Who?? Me??
snobrder's Avatar
Member # 12698
Weld on the rig while riding down the highway? Just keep the roof vent open and strap the generator to the tongue to the trailer.
Eastern team #94
Old 04-17-2009, 06:08 PM   #25 (permalink)
Member # 13342
When I bought my Lincoln SP-175 Plus, I called the factory and asked if my Northstar Honda-powered 4500/5500 genset would run the SP-175 and they said it would.
I've used it to weld at a friend's house who didn't have 220 VAC and it does indeed work.
Good luck.
Al
Albin is offline   Reply With Quote Quick reply to this message
