Whats stronger? a grade 8 bolt or case hardened pin to hold receiver hitch in??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-01-2009, 10:14 AM   #1 (permalink)
Honky Lips's Avatar
Member # 67732
having a discussion with a friend, there is a 5/8" (i think) hole that holds the receiver hitch into the reciever. i was going to use a grade 8 or 10 bolt to hold it in. but he brought up the point, that the "pins" that come with reciever hitches are case hardened and they are stronger than a grade 8 bolt??? i can see that possibly. but im not so sure about it.
anyone that has any concrete proof? whats stronger "i.e. safer" to hold by reciever hitch in, grade 8 or 10 bolt, or the hitch pin?
THIS SPACE FOR RENT, INQUIRE WITHIN
That guy can go fuck himself with whatever power tools he has left.
Honky Lips is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:17 AM   #2 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
The pin will be stronger.
Pins are designed to be loaded in shear, while bolts are designed to be loaded in tension.
Schmozilla is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:18 AM   #3 (permalink)
PONY_DRIVER's Avatar
Member # 44662
Grade 12 or go home.
"I'm strangely comfortable with it."
PONY_DRIVER is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:18 AM   #4 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
the pin. greater minimum diameter.
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:19 AM   #5 (permalink)
Member # 12578
I use a grade 24 bolt. lol...whut?
Eric
ecrist is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:23 AM   #6 (permalink)
Honky Lips's Avatar
Member # 67732
ill just one up you guys and use a grade 48 bolt, ill show you!!!
i can definately see the shear strength vs. tension strength. but damm the pins just look cheap. ill stick with my pin then.
Old 05-01-2009, 10:23 AM   #7 (permalink)
Member # 44662
You're Canadian eh? We don't use metric shit here AZ boy.
Old 05-01-2009, 10:23 AM   #8 (permalink)
F2504x4's Avatar
Member # 85205
x 100
[QUOTE=Administrator;15106961]And exactly why its better I work in the backround and not meddle what makes pirate pirate. [/QUOTE]
F2504x4 is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:26 AM   #9 (permalink)
ky scrambled's Avatar
Member # 85771
Yer from Iowa, Id put a corn cob in there when ya get done "making nice" with it.
Play stupid games, win stupid prizes
Old 05-01-2009, 10:33 AM   #10 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
I've used both, but I also figured that the odds of a Grade 8 bolt sheering off before my hitch is torn apart is small enough to not worry about it.
Gut feeling odds of course.
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 10:52 AM   #11 (permalink)
Otto Man's Avatar
Member # 18977
Send a message via AIM to Otto Man
What are you towing, a trailer full of fat chicks? I've never seen a pin fail in my short life time. Hitches ripped from the frame, snapped chains, broken tow straps (With the cool decapitating hooks), bent tow hooks, yes, but never a broken pin.
Even the sheer strength of a Grade 8 bolt in that diameter is going to be ungodly strong. Unless of course, you are hauling a trailer full of fat chicks. Otherwise, you might want to use both.
Originally Posted by Sully
It's a respect issue. Just because you can, doesn't mean you should.
Would you tell your Grandmother to go suck a big black cock, just because you could?
Otto Man is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:06 AM   #12 (permalink)
Member # 6957
seen them both in action and have yet to see either fail.
ironpig70 is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:11 AM   #13 (permalink)
300sniper's Avatar
Member # 26382
i just use a piece of 3/8" zink allthread i bought from home depot and double nut each end.
It's time to switch to whiskey, we've been drinkin' beer all night.
300sniper is online now   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:12 AM   #14 (permalink)
CaryW's Avatar
Member # 22104
So how come the shear pins in a bushhog shaft are actually bolts?
Unrelated, just always wondered as I have never seen an actual pin in the shear pin holes on the shaft
It is pitch black. You are likely to be eaten by a grue.
CaryW is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:15 AM   #15 (permalink)
Member # 97412
My grandpa once used a head bold for a shear bolt in a brush hog. The PTO shaft twisted instead of the bolt shearing.
oilburner350 is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:16 AM   #16 (permalink)
Member # 35320
Send a message via Yahoo to Phonedoc
Those almost always come with a grade 2 bolt because anything stronger will break the gears before it shears.
Phonedoc is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:16 AM   #17 (permalink)
Member # 35320
That too.
Old 05-01-2009, 11:17 AM   #18 (permalink)
Otto Man's Avatar
Member # 18977
My Dad's old ass brush hog also had bolts on the PTO shaft also. My only guess is that they are uber weak, Harbor Freight bolts designed to snap at a few thousand PSI less than anything else in the driveline.
Speaking of which, why haven't those driveshaft with those sheer bolts been more popular? It seems like a good idea in point. Bomb proof your driveline and axles, making the d-shaft bolts the only semi-weak source. It is helluva lot faster, easier, and cleaner to replace a few bolts on a driveshaft than blowing a ring and pinion and such.
Old 05-01-2009, 11:18 AM   #19 (permalink)
Member # 75289
The case hardened pin. The pin is actually like two pins in one. The outer surface is hardened down to a given case depth (100-150 usually on Rockwell B). This gives the pin wear resistance and some strength. The inner portion is not has hard (Rockwell 50-100 usually) this allows the pin to flex and absorb force with out being brittle. Really case hardened pins are the best of both worlds. The bolt is just machined stock, grade 8 bolts are not hardened.
bigdreamin is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:37 AM   #20 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
uhm?
Grade 2 is a standard hardware grade steel. This is the most common grade of steel fastener and is the least expensive. Grade 2 bolts have no head marking (sometimes a manufacturer mark is present).
Grade 5 bolts are case hardened. This means that the outside part of the bolt has been hardened but that the bolt was not heated enough to harden the inside portion. This creates a bolt that is fairly hard but not as brittle as a fully hardened bolt. Grade 5 bolts are the most common bolts found in automotive applications. Grade 5 bolts may have 3 evenly spaced radial lines on the head.
Grade 8 bolts are fully hardened. This means the bolt has been hardened all the way through. This creates a bolt that is very hard but somewhat brittle. Grade 8 bolts are more likely to snap off than bend under extreme loads. Grade 8 bolts are often found in demanding applications such as automotive suspensions. Grade 8 bolts may have 6 evenly spaced radial lines on the head.
they are quenched and tempered
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:43 AM   #21 (permalink)
Member # 75289
Originally Posted by sceep View Post
uhm?
I guess I could have worded that better. I meant that grade 8 are not case hardened. Case hardened tolerates repetitive stresses better then a through hardened pin.
Old 05-01-2009, 11:55 AM   #22 (permalink)
Member # 48233
I use wooden dowels from HD. They are much cheaper
[quote=texasblake;11194923]
they may be waving like mccain for the rest of their life, but you taught them an important life lesson and they had fun doing it.[/quote]
[QUOTE=xyjbeaker;9759686]"mexican food reminds you of my face?"[/QUOTE]
Doc Holiday13 is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 11:57 AM   #23 (permalink)
Member # 41764
I don't doubt the strength of the bolt, but being the design the pin is the way to go.
Ultimate strength of the bolt is achieved when it's torqued properly, being the large slip fit of the ball mount in the hitch you're not going to be able to achieve that without deforming the reciever tube.
This all besides the point that the pin makes it really easy to pull the ball mount out to swap or just remove it to keep the ball and grease out of the weather when you're not using it.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 02:02 PM   #24 (permalink)
Member # 17351
Grade 11, case hardened, quenched, tempered, Mil-spec, Super-Duty, contractor-grade, trail rated, prescription strength
BACON!
The world is full of compromise and infinite red tape.
earlybroncoguy is offline   Reply With Quote Quick reply to this message
Old 05-01-2009, 02:56 PM   #25 (permalink)
bremen242's Avatar
Member # 28687
I think the pins are just for show.. Let the hitch rust into the inside of the receiver, and it'll never come out.
bremen242 is offline   Reply With Quote Quick reply to this message
