Whats the best thread sealant for natural gas lines? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-05-2009, 11:31 AM   #1 (permalink)
Member # 2499
I need to repair some natural gas lines at our business that are black pipe. Whats the best paste sealant for natural gas? Thanks.
72 k5
OneTonK5 is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:32 AM   #2 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
Either tape or dope for NG.
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:33 AM   #3 (permalink)
ndeepoffroad's Avatar
Member # 79902
My step-dad is a plumber...we use teflon tape and then "Pro-Dope" on top of the tape...
Pro-Dope is in a yellow can and can be picked up at a Winnelson or similar commercial plumbing supply.
EDIT: ProDope is made by Hercules chemical company...it is gray. You don't HAVE to use the tape with it, but on an old joint (repair) or on a coupling (known to be leak prone) we always used both and tested them to 35psi.
EDIT: PIC....
5th Annual Rally in the Valley
April 28-May 1, 2016
ndeepoffroad is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:40 AM   #4 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
I've used the extra thick (yellow) teflon tape with fine results.
Mo is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:45 AM   #5 (permalink)
TexasBlake's Avatar
Member # 9722
yellow teflon tape stuff.
TexasBlake is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:46 AM   #6 (permalink)
Nightshade's Avatar
Member # 40793
Send a message via AIM to Nightshade Send a message via MSN to Nightshade Send a message via Yahoo to Nightshade
Superglue and bubblegum
I'd rather die on my feet than live on my knees.
Nightshade is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:49 AM   #7 (permalink)
Member # 12499
Permatex teflon pipe dope. When you do not want it to leak.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:52 AM   #8 (permalink)
Member # 129581
heat shrink tubing and a lighter.
Muddy Oval is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:57 AM   #9 (permalink)
Member # 59753
Both of these work good. BUT wrap the tape on opposite dirrection of the threads.
[QUOTE=ChevyGal;9752200]I personally think it's cool Janet Reno likes to wheel. :)[/QUOTE]
Alfred W. is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 11:57 AM   #10 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
I like to sweat solder the lines myself.
ZJim is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 12:01 PM   #11 (permalink)
Member # 79902
If you are looking at the end of the pipe, "clockwise"....and apply the pipe dope in the same direction as the tape...or it will unravel it.
Old 10-05-2009, 12:18 PM   #12 (permalink)
rugger's Avatar
Member # 67681
I use regular old pipe dope. If the connection leaks then I didn't wrench it hard enough.
rugger is online now   Reply With Quote Quick reply to this message
Old 10-05-2009, 12:26 PM   #13 (permalink)
Mike327's Avatar
Member # 64019
White teflon tape is used about 99% of the time offshore in the oil and gas field.
I know the voices in my head are not real. But damn they sure come up with some great ideas.
Mike327 is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 12:28 PM   #14 (permalink)
Member # 2499
I know how to wrap tape....have always used rector seal but have found a few leaks in some old lines.
72 k5
Old 10-05-2009, 12:37 PM   #15 (permalink)
Member # 12499
I used to use Rectorseal, but it dries out, the Permatex stuff doesn't as it comes in a tube that can be sealed up well.
Old 10-05-2009, 12:40 PM   #16 (permalink)
Member # 102123
This
[QUOTE=monkeyevil;10413721]Tranny's are the gateway drug to gay.[/QUOTE]
72 Chevy 454/465/205 33's
89 Chevy Suburban 454TBI/400/205 6" Procomp lift on 37's
94 Chevy ext. cab 350/4L60e/241 6"BDS lift,35" MTZ's
randy92782 is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 12:40 PM   #17 (permalink)
Bobzooki's Avatar
Member # 9419
Just weld 'em.
The N.A.A.C.P. is a RACIST organization.
Bobzooki is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 01:15 PM   #18 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
I've had really good luck with this stuff: http://www.gasoila.com/products/item...adsealant.html
I've seen 2" fittings crossthreaded together and still sealed with it... LOL
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
