Most effiecient shape of a house? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-07-2010, 09:37 AM   #1 (permalink)
The Adam Blaster's Avatar
Member # 1479
I'm just thinking about what homes are more efficient = less costly to keep heatd/cooled?
Is a 2-storey the worst?
Would a single story with a full sized basement be that much better?
I know windows are pretty bad insulators, so the smaller and fewer the better...
I currently have a 2-storey that seems to be VERY expensive in terms of utilities, gas, water and electricity, but I think that is more a function of how expensive EVERYTHING is in Alberta as opposed to other provinces...
EDIT: I should note my house is only 5 years old, so you wouldassume that it would be quite efficient. However, it was built during a recent housing boom that is still going on, adn I'm pretty sure the contractors rushed everything, and cut every corner possile.
The word vagina roughly translates as "sword holder" in Latin.
The Adam Blaster is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:40 AM   #2 (permalink)
Bones's Avatar
Member # 3007
My raised ranch seems pretty efficient. Faces north (sucks ass in the winter), tons of shade, reasonable size 950SF up, 450 finished down. Basement/garage is very chilly, utilities are reasonable I think as well.
I need to get some insualtion blown in the attic before this winter.
Bones is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:43 AM   #3 (permalink)
Member # 34987
One stories seem to be less costly to air condition.
The following tends to help:
1. Ceiling fans
2. Foil Radiant Barrier (tech shield or retro fit)
3. Thick attic insulation
4. Properly sized/balanced AC system
5. Shaded or double pane windows with non-metal frames
1 TON SAS'ed C1500 ECSB on 37s
axisT6 is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:44 AM   #4 (permalink)
#1 BURRITO IN NM!!!!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
i grew up in/ parents still live in a 2 story, 1500sqft house that uses a max 2 cords of wood per year as its only heat, and has no cooling.
south facing lower story is 95% double pane glass, red brick floors, large eave on lower story.
in the summer the sun never hits the brick due to the eave. in the winter it shines on the brick almost the whole width of the hosue and heats it up.
wood burning stove is a design my dad came up with, and built 25 years ago.
when he built the house it didnt pass final inpection because there was only a single heat source in the place. he went and bought electric baseboard heaters and screwed them to the wall in every room. not a single one of them has ever been wired.
its is one of the most efficient houses i've ever been in.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:44 AM   #5 (permalink)
Member # 29527
I would think a single story fully above ground would be the worst. A two-story should be better, with a basement better yet. Best would be underground I guess.
[QUOTE=JK3078;17652386]To fucking ignorant[/QUOTE]:rasta:
CrustyJeep is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:44 AM   #6 (permalink)
Creepy, Old Stalker
Chister's Avatar
Member # 2059
I would think "shape" has very little to do with it.
The MOST efficient home is a cave that stays at 72*F year round, uses LED lighting at night, and solar tube lighting during the day.
Chister is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:46 AM   #7 (permalink)
sceep's Avatar
Member # 10798
^^ this. i had a buddy growing up who's parents had built a 2500sqft underground home.
it was ALWAYS comfortable in that joint.
Old 07-07-2010, 09:47 AM   #8 (permalink)
Member # 38130
i have a earth contact home and love it
we do not need to turn the AC on till mid june
the winter month are cooler but we like a cooler house
saying mid june around here most will go from heat to AC
we have from late march to mid june with nothing running
and from late sep to first of oct to mid nov with nothing running
it would be hard to move out of a eath contact home (been here 8 years now)
doing the lead sled thing now
*TECHTAFAB welding*
toywelder is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 09:49 AM   #9 (permalink)
Blue Haired Troll
Screwzer2's Avatar
Member # 38193
Two story rectangular house with a single, standard gable roof would be the most efficient for a lot of reasons:
1. Every corner in a foundation costs you in terms of at least labor, and usually materials.
2. Stacked plumbing reduces materials and labor.
3. Shorter electrical runs.
4. Smaller roof, and again, every new surface costs you.
5. Way more energy efficient. Heat rises so warm the first floor in the winter and cool the second floor in summer. The other space gets conditioned semi-for-free. Smaller actic means there's less heat gain/loss.
If you really want to get efficient you could build what I did. A 325 sq. ft. tiny house (although I got fancy and made two roofs):
It has a kitchen/eating area, laundry room, bathroom, sleeping loft, and storage (over the door, left side of photo). Its hydronically heated by the same water heater used in the sink.
"Liberal hopes need to be matched by conservative caution."
Martin Peretz, former editor-in-chief of The New Republic
Screwzer2 is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 10:07 AM   #10 (permalink)
Member # 8203
The most efficiently shaped house is a cube, as it defines the largest possible interior volume with the smallest possible exterior surface area (barring any crazy round or shperical shapes, which are typically impractical for a home, unless your'e a yurt fan)
The deeper you can bury your cube, the better, since earth is a great insulator.
If you take exception to living inside a Hellraiser cube, you're next best bet is to first seal and then insulate your home. I live in a converted summer home that was 1300 SF and had friggin foil backed R3 in the walls. I spent $350/mo in january to heat the place. 2 years ago we gutted the drywall, added real insulation, sealed houe wrap and added 900 SF by way of a second floor. these day's I'm miffed if my heating bill exceed $200/mo, which has only happened once, and that was when my BiL crashed with us and abused our thermostat for 6 weeks straight.
super cool turbo 4runner
Sundowner is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 10:09 AM   #11 (permalink)
Member # 157845
Easy to maintain but melts when it rains. Luckily I can just re-shape it at the end of the storm and the neighbors think I put an addition on.
89' YJ 350, 60/14b, ARB's, 42's, PROJECT
A penny saved, is not much...
MASS CRAWLER is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 10:14 AM   #12 (permalink)
Member # 111602
no cubes...
geodesic domes are the shit.
heater in the middle with a fan on the ceiling and a loft.
Whaddaya mean, "out of the box"? This thing is "the box"!
Thanks buccaneer
coppermtn is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 10:52 AM   #13 (permalink)
Member # 19304
Send a message via MSN to gipper Send a message via Yahoo to gipper
and QUIET.
EDIT: pics? Do you have earth roof, or just 3 walls like a walkout basement?
For sale: 1984 CJ7 ... 4.10's, superwinch hubs, more.
gipper is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 10:53 AM   #14 (permalink)
Member # 19304
nice yurt.
Old 07-07-2010, 10:56 AM   #15 (permalink)
Member # 110749
Why doesn't this surprise me?
AIRBORNEDF is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 10:57 AM   #16 (permalink)
Anphaqueue II
CDA 455's Avatar
Member # 95025
^^^I also agree.^^^
ΜΟΛΩΝ ΛΑΒΕ
For the best deal on 8 lug disc brakes click here--> www.lugnut4x4.com
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 11:00 AM   #17 (permalink)
Member # 7163
Smaller is not necessarily efficient. Efficient is the ratio of size to resources consumed.
Oxjockey is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 11:02 AM   #18 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
The most efficient shape is a circle. However, people don’t like circles and they are hard to build and utilize.
The second is a square. The least amount of surface area and the most amount of square footage.
So a perfect square would likely be a 2-story.
The most efficient design is likely underground. You have an R value that is off the charts. The down side is that lighting sucks, ground water, and finding the ideal site. Costs are likely going to be high.
I have a design in mind when I build one.
It will be about 40’x40” square, and full basement. The outside will have a wrap around porch around 3 sides. The side without is the north side, because you don’t need shelter from the sun.
Outside will be planted with deciduous trees. So in the summer you are shaped by trees and the porch. In the winter the leaves drop and allow some sun to help warm the house.
The basement will daylight on the down hill side and have a patio under the porch/deck.
Basements are cheap square footage in my area. You don’t need siding and windows. Just block, foundation drains and gravel.
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 11:05 AM   #19 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
My current house has a 2 car garage under the house. That was the worst idea ever. I have good quality garage doors and it is insulated from the house. It will get down to 40 in the garage when the temps are in the teens outside. It adds two more large exterior surfaces to the house. Bedrooms are above the garage, so the floors stay cool and the bedrooms stay cool. DO NOT put a garage under your house. It is a hole that eats heat in the winter and gains heat in the summer.
Old 07-07-2010, 11:05 AM   #20 (permalink)
Member # 19304
WOuldn't the roll out stuff work better and be just as easy covering that limited amount of square footage?
Old 07-07-2010, 11:12 AM   #21 (permalink)
bigbroncojeff's Avatar
Member # 43837
Around here anything surrounded in deciduous trees is going to do better than someone with the newest, built to the best efficiency standards, cube house, sitting out in the sun...
RIP SPRING CREEK OFF ROAD
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
bigbroncojeff is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 11:13 AM   #22 (permalink)
Bones's Avatar
Member # 3007
Possibly, I am no expert on the matter though. Rolled costs more IIRC
Old 07-07-2010, 11:13 AM   #23 (permalink)
Member # 9423
Location: Newcastle, CA. But don't ask me where the Old Castle is
Send a message via Yahoo to evenBIGGERrock
out here in the central valley, people with 2 stories pay out the ass to cool their places in the summer. A big thing that started showing up a few years ago is not only dual zones (one up stairs, one down stairs), but even 2 separate AC units. It helps, but they still pay way more than anyone with a single story.
Vast majority of houses out here are on a slab so no telling the diff between having a basement or not. My personal opinion is it helps out this way. Doesn't get real cold in the winter so the biggest concern is cooling in the summer and being glued to mother earth I think helps with that.
Ceiling fans are a huge help. I can keep the thermostat on the edge and if the fans are off the house feels stuffy and one is tempted to bump the temp down, but kick the fans on and it feels nice. I haven't crunched the math, but I know the fans don't draw that much so my guess is running them is still cheaper than running the AC just that much more.
With our current house I do know one down side to its shape. It's 2500 sq ft single story ranch style. But it's a lot longer than it is wide and sometimes it can be tough to get the two furthest bedrooms on even temp with the rest of the house. They tend to be a little warmer in the summer and colder in the winter than the rest of the house. So with that, I'd be inclined to agree that a cube would be more efficient (going with standard construction methods of course)
Mantra: The more you learn, the more you realize how little you really know.
Translation: If you think you know it all.....you don't know jack.
evenBIGGERrock is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 11:28 AM   #24 (permalink)
Member # 19304
YEs, but with only 1000sqft to cover, it probably offsets the cost of renting the blower and the hassle of getting it all up there. With the rolls, you just take them up and be done with it.
Also, lowe's frequently puts the attic stuff rolls on sale.
Old 07-07-2010, 11:44 AM   #25 (permalink)
TEX
Member # 603
Yup. The more cube-shaped it is, the lower your material costs too because of the reduction in exterior walls/roof.
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote Quick reply to this message
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
