vent install on shipping container? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2010, 01:19 PM   #1 (permalink)
300sniper's Avatar
Member # 26382
our rifle club needs to install some vents on our storage containers. i need to know what is the best kind to use for this application. we are thinking a whirlybird type vent but i honestly have no idea what model to use. do we need to use one or two per container? they are 40' containers and it gets well over 100 degrees out side.
It's time to switch to whiskey, we've been drinkin' beer all night.
300sniper is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:20 PM   #2 (permalink)
Member # 99624
one on each end should be good....
MOLON LABE
If I was an FBI agent on one of these stings, I wouldn't be able to resist building up a suicide vest rigged with confetti cannons.
ALLAHU ACKBAR! "pop"
D_JEEPER is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:20 PM   #3 (permalink)
LOPPY's Avatar
Member # 1108
I'd put at least three of those big round spinners. You see those on most commercial construction, so they're probably the most efficient for the buck.
Those who forge their swords into plows will plow for those who do not.
LOPPY is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:25 PM   #4 (permalink)
Dieselmh's Avatar
Member # 6417
Send a message via Yahoo to Dieselmh
Is it for ammo storage? If so, just toss a couple of lit road flares in there and it will vent itself.
Dieselmh is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:28 PM   #5 (permalink)
Member # 89191
Also I've heard of some type of paint-on gunk that people use on these that reflects like 85% of the radiant heat away . Maybe also put some 'inlet' vents on the floor, with a hole dug beneath to try and suck in cool air? You could go crazy with that too and dig a deep hole with a big pvc pipe dropping down into it from the floor vent... Like a simple, passive geothermal system.
What are YOU doing for freedom? Be a doer. freestateproject.org
4xbrian is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:28 PM   #6 (permalink)
Member # 994
even normal vents don't let much heat out. We have several on our site for equipment storage and a small wall mount fan on one end and a screened vent on the other works well. I saw you can get solar powered vents now I think that would work sweet!
for every mile of road there is 2 miles of ditch!
Chet is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:33 PM   #7 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Get a powered one
http://www.costco.com/Browse/Product...=1&topnav=&s=1
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:34 PM   #8 (permalink)
Member # 99624
line that shit with tin foil!!!
Shiny Side Out!
MOLON LABE
Old 07-16-2010, 01:44 PM   #9 (permalink)
Member # 89191
Do you have any pics of how you're set up so far?
Old 07-16-2010, 01:46 PM   #10 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
The best kind are louvered with fans.
In the cold weather, you shut the slats to keep heat in. When the fan is on, you open them to pull air from one end out of the other.
The penalty for punching someone in the mouth is way too high in our society.
Always take a poison word as a promise.
SilverZuk is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 04:28 PM   #11 (permalink)
300sniper's Avatar
Member # 26382
they're just regular 40' conex boxes with shelves running down one side where we store our steel targets and other match supplies.
there is no power in them and we don't need them to be livable. just a little more bearable when getting stuff in and out of them when it's 100+ degrees out.
Old 07-16-2010, 04:34 PM   #12 (permalink)
Ebs
Member # 20043
Would painting the tops of the containers white help?
Ebs is online now   Reply With Quote Quick reply to this message
Old 07-16-2010, 06:27 PM   #13 (permalink)
Member # 24640
Iv'e heard that the kind that spin in the wind (called whirly birds around here) tend to let rain in under certain wind conditions.
Keep in mind that if you don't have a way to let cool air in down low then the vents will have a hard time moving hot air out the top...like the eave vents that let cool air into the attic of a house. I would check with a metal building supply place...they should have something that is designed to work with the corrogations on the roof or wall of your container
jmhinescj is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 06:35 PM   #14 (permalink)
Member # 7163
Just bury them.
Oxjockey is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 07:30 PM   #15 (permalink)
Member # 89191
Sounds like you have power, how about just a big fawking fan that you leave right inside the door and turn on when you open it?
Old 07-16-2010, 08:27 PM   #16 (permalink)
Member # 9994
for the hot air to come out the top, you'll need fresh air to go in the bottom...like a chimney or a roof vent.
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
jeepnmatt is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 08:31 PM   #17 (permalink)
Member # 61545
Don't put a vent on the roof!! Too much a chance for leaks. Put a couple on the sides at the top and bottom.
hogcat is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 09:35 PM   #18 (permalink)
paragon's Avatar
Member # 40266
just go buy 2 of those rectangular or round covered roof vents. they are already screened and have a "chimney" so that when you cut the metal and tar it in, it won't leak.
put one towards either end and install something like dryer vents lower on both of the sides but towards the middle. fresh air enters from the middle and flows to the ends to evacuate the heat
I also agree with the above about the whirly birds. they allow water in
"For God and country, Geronimo, Geronimo, Geronimo"
paragon is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 09:44 PM   #19 (permalink)
Member # 72494
I would do the whirly bird's with vent's along the bottom. There's not much you could do better without going with a swamp cooler or air conditioning.
[QUOTE=southernfriedcj8;10602442]Are you hittin' on me?[/QUOTE]
[QUOTE=BeefCakeScout;10563632]I was, but if you won't kiss me after I blow you then i'll find someone else:flipoff2:[/QUOTE]
77bawls is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 10:41 PM   #20 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
This would help bigtime.
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 12:09 AM   #21 (permalink)
Member # 108445
http://storageaz.com/modifications.htm
rocket flier is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 03:27 AM   #22 (permalink)
Member # 140312
Speaking of containers. What do one of these usually cost? They would make a great, fairly secure, shed.
sometoyotaguy is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 05:19 AM   #23 (permalink)
Member # 81214
something like this
http://www.westmarine.com/webapp/wcs...classNum=10666
then you could cut holes in the sides and line them with hardware cloth
Never Monday is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 08:02 AM   #24 (permalink)
jus10keith's Avatar
Member # 110936
Cool Seal
Coat the top of them with Cool Seal. It is the stuff people put on top of their Mobile Homes/House Trailers. It is like a heat barrier/reflective type stuff and it seals the seams. Do this after you put some kind of vents in.
89YJ/302/C6/205/HP44/14B/37"CLAWS on 17s and IROKS on ReCentered H1s...up next 5.0L/AOD/205
jus10keith is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 08:47 AM   #25 (permalink)
surpip's Avatar
Member # 22748
Thats funny I was plannin on venting my connex box today. It gets stupid hot in there, and really humid. I am going to use the 8" round covered vents from the depot case they are 7 bucks and I am broke. Some tar and some self tappers and I'll call it good.
R.I.P. DOZER
R.I.P. Jason
GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS
-ALBERT EINSTEIN-
#472tellico rally
[/URL][/COLOR]KJ6IYH
surpip is offline   Reply With Quote Quick reply to this message
