Frozen hot water... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-04-2011, 01:43 PM   #1 (permalink)
Member # 46582
Frozen hot water...
anybody ever have your hot water freeze? the cold water runs like a champ but cant get anything out of the hot water. the hot water heater is in the garage on the north west side of the house in a corner with no insulation.
im thinkin about cutting open the wall to thaw it out so it doesnt burst.
any thoughts?
91superyoda is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 01:45 PM   #2 (permalink)
REDDMANIAC's Avatar
Member # 5733
the inlet froze?
REDDMANIAC is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 01:47 PM   #3 (permalink)
Dieselmh's Avatar
Member # 6417
Send a message via Yahoo to Dieselmh
Originally Posted by REDDMANIAC View Post
the inlet froze?
I hope so, otherwise it got mighty fawking cold in there.
Dieselmh is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 01:47 PM   #4 (permalink)
Banned
jokemon's Avatar
Member # 165582
the inlet froze?
^ this, hot water can't freeze.
jokemon is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 01:47 PM   #5 (permalink)
Member # 85955
any thoughts?
Well there's your problem right there.
tlcruiser66 is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 01:49 PM   #6 (permalink)
Member # 46582
the inlet froze?
yes, thats what i suspect. i followed the cold line all the way to the tank from the attic, pulled the insulation back and little to feel how cold it was and none of the lines were cold enough to the touch to be frozen. its got to be frozen inside the wall.
Old 02-04-2011, 01:50 PM   #7 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
I've had the hot water freeze between the heater and the faucet before. It doesn't stay hot for long just sitting in the pipe
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Joe_W is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 02:23 PM   #8 (permalink)
Member # 6957
I have seen boiling water freeze
Sounds like the inlet is frozen
ironpig70 is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 02:31 PM   #9 (permalink)
Member # 2059
My buddy is having this problem right now.
They did an addition to his house way back when and the pipes to the kitchen sink are in the exterior wall. The hot water pipe is frozen solid but the cold water is fine.
[CENTER]
[COLOR="Blue"]┌∩┐(◕_◕)┌∩┐[/COLOR]
[COLOR="Black"]__________[/COLOR]
[/CENTER]
Chister is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 02:35 PM   #10 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Yup, and you know why? When I crawled under the house last year to thaw it out they had insulated the cold water pipe in foam wrap but not the hot water pipe. I guess they figured "hot water doesnt freeze"
Old 02-04-2011, 02:42 PM   #11 (permalink)
Member # 6957
Not seeing why a pipe in an exterior wall would freeze any more then ran under a house.
Old 02-04-2011, 02:43 PM   #12 (permalink)
Member # 46582
any suggestions on thawing it out, been like this since tuesday. freezing cold water showers are getting old pretty quick.
Old 02-04-2011, 02:45 PM   #13 (permalink)
Cue-Ball's Avatar
Member # 17311
No you haven't
closer to the cold outside air
Nex Pro Evinco [COLOR="Black"]"Death Before Defeat"[/COLOR]
Cue-Ball is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 02:45 PM   #14 (permalink)
Banned
ScottFJ40's Avatar
Member # 11268
How much of the line is hidden behind drywall from where your service enters your house and water heater? DOH, you said it's frozen AFTER the heater?
In the future, if your area gets hit with a cold snap like this again, you should leave a small trickle of water flowing...
ScottFJ40 is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 02:47 PM   #15 (permalink)
massxj's Avatar
Member # 33456
Iv used a stick welder in the past
massxj is online now   Reply With Quote Quick reply to this message
Old 02-04-2011, 02:47 PM   #16 (permalink)
Member # 6957
Originally Posted by Cue-Ball View Post
No you haven't
Closer how? The wall should be insulated just like the pipe under the house.
And yes I have seen boiling water freeze You cannot see it in nature or real world but in physics class you can see it done.
Old 02-04-2011, 02:49 PM   #17 (permalink)
Banned
ScottFJ40's Avatar
Member # 11268
Take note of the OP's location...
Old 02-04-2011, 02:49 PM   #18 (permalink)
Member # 6957
Map gas on a torch. Find the pipe under the house and start where the water enters from the city. Leave a couple faucets open in the house to move the water. Also you can leave a halogen type light under the house to "warm" the space.
Old 02-04-2011, 02:51 PM   #19 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
hot lines typicaly freeze more often than cold lines beleive it or not.
cold lines get cuirculated more and dont ahve as much time to freeze.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote Quick reply to this message
Old 02-04-2011, 03:05 PM   #20 (permalink)
Member # 46582
new house with plastic water lines and a concrete foundation. I have chased the cold water feed to the tank and its not frozen and the hot coming out of the tank and its not frozen. there is about a 2 foot section of line I cant get to that drops down the cieling and wall and then elbows through the wall to the tank.
Old 02-04-2011, 03:07 PM   #21 (permalink)
Banned
Member # 125480
any thoughts?
http://www.pirate4x4.com/forum/showt...t+water+heater
909wheeler is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 03:10 PM   #22 (permalink)
REDDMANIAC's Avatar
Member # 5733
I would guess if there is a draft it will freeze faster if at all, circulating freezing air is a big factor in freezing pipes.
Old 02-04-2011, 03:12 PM   #23 (permalink)
Member # 103814
No you haven't : Yes. I have.
YouTube - Boiling water freezing in one second outdoors in Cold Norway
Flatline's Up! is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 03:19 PM   #24 (permalink)
Member # 46582
Old 02-04-2011, 03:20 PM   #25 (permalink)
Apple
makya's Avatar
Member # 41250
take a blow dryer and run it into the wall, let it run for a while.
Originally Posted by TatonkaII
- really? I might take one in the ass for that.
makya is offline   Reply With Quote Quick reply to this message
