Holley Carb ID - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2011, 06:07 PM   #1 (permalink)
Member # 38890
Holley Carb ID
Had an original carb on a 6500 GMC truck we use to haul a dozier. It was a 4 barrel Holley carb. It was replaced 10 years ago with an Edelbrock 2 barrel . I'd like to put a 4 barrel carb back on it, but need help with the ID of the Holley carb, which I was told could not be rebuilt. Here are the numbers off the old Holley carb.
Numbers are: 793981
LIST-7386
1186
Engine is 366, manual choke.
What's compatible, and currently available, with the above Holley 4 barrel, regardless of brand.
Thanks in advance.
God Bless,
David B.
BOFF is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 06:12 PM   #2 (permalink)
Juggernaut
Camarogenius's Avatar
Member # 49232
Send a message via Yahoo to Camarogenius
Go to Vatozone, buy an adapter plate, and put a quadrajet on there.
I'm not the best concrete guy, but I can tell you how to polish your balls.
In a society that has destroyed all adventure,
The only adventure left is to destroy that society.
Camarogenius is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 06:36 PM   #3 (permalink)
'Merica. Fuck Yeah!
86k30's Avatar
Member # 25703
Go get ya an List # 1850 Holley. Pretty close to the same on the linkage side without all the govener BS.
The facelift:
86k30 is offline   Reply With Quote Quick reply to this message
Old 06-30-2011, 09:32 PM   #4 (permalink)
Member # 38200
Shows up on here;
http://www.carbkitsource.com/carbs/n...7002-8999.html
Quick & Dirty is offline   Reply With Quote Quick reply to this message
Old 07-01-2011, 12:16 AM   #5 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
I think that truck would have a holley 4150 on it with that weird governor stuff on it. Just get a run of the mill 4150 or 4160 for it.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 07-01-2011, 05:06 AM   #6 (permalink)
85f150dsel's Avatar
Member # 43079
Did you look up the truck on Rockauto and see if their is a carb kit listed?
smileysarmory.com
85f150dsel is offline   Reply With Quote Quick reply to this message
Old 07-01-2011, 05:07 AM   #7 (permalink)
Member # 38890
It has the governor stuff on it. I'm wanting to know what cfm the original Holley carb had along with other specifics, so I can replace it with something similar.
Originally Posted by Quick & Dirty View Post
I had found that, but the Holley Carb can't be rebuilt, and unfortunately, the link doesn't give any specifics about the carb.
God Bless,
David B.
Old 07-01-2011, 05:13 AM   #8 (permalink)
Member # 38890
A GMC 6500 isn't listed on any "computer look up" programs I have found, so therefore according to most "Vatozone" employees, my truck doesn't exist.
God Bless,
David B.
Old 07-01-2011, 05:22 AM   #9 (permalink)
85f150dsel's Avatar
Member # 43079
Have you tried or had someone look in alldata?
I have the program at home but that PC is turned off so I can't check right now.
Worst case, buy a universal Holley kit?
smileysarmory.com
Old 07-01-2011, 05:57 AM   #10 (permalink)
Banned
Member # 188016
Dedicated truck Holly carburetors may look like a generic 1850 Holley with a governor but there are differences.The truck carb has jetting and air bleeds calibrated for constant heavy engine loads.Every heavy duty V-8 gas engine of the past used a Holley carb,2300 two barrel or a 4150 four barrel.That would be GM,IHC ,Ford and Dodge.The reason is the Holley design is better at constant wide open throttle.
I got the Willys is offline   Reply With Quote Quick reply to this message
Old 07-01-2011, 06:06 AM   #11 (permalink)
Banned
Member # 188016
And the list number you gave,7386 most closely matches the 7386A shown in the Holley master catalog I have. The original application is a 1976 GMC 366 engine,Federal spec,4000 rpm governor. The Holley rebuild kit number is 85R-4975-S. Actually any Holley brand master kit for a 4150 carb will work.Be sure to compare the numbers on the power valve to be sure it's the same.Summit or Jegs will have genuine Holley kits for reasonable money.
