Log Splitter from a floor jack - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-07-2011, 09:51 AM   #1 (permalink)
dntsdad's Avatar
Member # 125937
I carry a floor jack with me every time I go camping. I have the room and its just a "peace of mind". I used it twice this trip as I got a flat on the travel trailer going up and my brother got one on the way back. WAY BETTER than a crank jack.
Anyway, I was trying to think of a way to make a decent log splitter out of it. I have a few ideas but wondering if someone has McGyver'ed something that can be done fairly simply using an everyday, 2-ton jack. I am getting tired of being sore the entire next day from slinging the axe, and I can handle pumping a jack much easier.
Thanks
dntsdad is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 09:58 AM   #2 (permalink)
rugger's Avatar
Member # 67681
weld a splitting maul under the bumper. put the firewood on the jack. you'll probably need a something to put under the wheels to spread out the force. jack until wood splits. Hopefully the weight of the truck/vehicle is enough to split the wood.
edit: if it is a bottle jack then you'll still need something under it.
edit2: or weld a pipe onto the maul that will fit over the bottle jack circumference. Then slip it under the wood and the wood under the vehicle. I guess we're talking either a pretty short piece of wood or a tall vehicle.
rugger is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:01 AM   #3 (permalink)
Banned
jokemon's Avatar
Member # 165582
Make a 'frame' that goes up and over the jacks (idfk flat part that moves up), so the pressure of splitting the wood is pulling against the frame of the jack, no worries about it sinking in to the ground using your bumper..... My idea anyway.
jokemon is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:03 AM   #4 (permalink)
Crazy Old Troll
Screwzer2's Avatar
Member # 38193
You talking about a bottle jack?:
Or Floor style?
Google Manual Log Splitter.
Shouldn't be too hard to find plans for something like this:
"Stay Strong, Be Brave, Wait for the Signs."
óDead Dog Cafe
Screwzer2 is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:03 AM   #5 (permalink)
Member # 74720
You can also make the wedge so its detachable... Idea #1 would work well.
Blue Chip is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:08 AM   #6 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
Send a message via AIM to lttlbddy Send a message via Yahoo to lttlbddy
As already said, shouldn't be hard to design for a floor jack. Great idea.
Adjustable maul:
lttlbddy is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:10 AM   #7 (permalink)
Yota Up's Avatar
Member # 57128
Take that picture, but instead of using that beam on the lower portion, use receiver hitch tubing. Pull it from the bed, plug it into the hitch, and you'll have a horizontal splitter at waist level that you won't have to bend over to load.
Yota Up is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:12 AM   #8 (permalink)
85f150dsel's Avatar
Member # 43079
Maybe you should get out more. If you are sore from doing less than a half a cord of wood there is an issue. If you are trying to use a jack to split wood for more than some smores, you are fawking
Way too slow, go to TSC and try a display one. There is a reason there is 2 handles and it is slow as hell.
smileysarmory.com
85f150dsel is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:12 AM   #9 (permalink)
Rerock's Avatar
Member # 28604
Adjustable maul:
Adjustable height AND a foot pump? That's the goods right there!
Rerock is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:20 AM   #10 (permalink)
dntsdad's Avatar
Member # 125937
Or Floor style?
Floor jack style, although not a sleek low profile one like that. A 10 year old version with the round, removable pad.
Is this even needed in this thread? If you would rather swing an axe, then go ahead. I choose to seek alternatives that are cheap and easy to pack.
Old 07-07-2011, 10:22 AM   #11 (permalink)
Member # 17378
...I am getting tired of being sore the entire next day from slinging the axe....
You're shitting me. Sore from splitting a little camp wood?
Lucas trucks are usually dead simple to figure out, there aren't many things to go wrong with them.
Mercedesrover is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:24 AM   #12 (permalink)
Member # 9994
weld a piece of 2" square tube to a splitting wedge and pin it in your receiver. jack a log up and into it to split.
you might carry a piece of 3/4" plywood to throw under it to keep the jack from sinking.
i've never done this, but it seems like it would work.
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
jeepnmatt is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:26 AM   #13 (permalink)
Banned
Member # 158768
i'd just pay a messican to chop the wood for me.
fatdan460 is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:26 AM   #14 (permalink)
Member # 65168
I always have to laugh at those manual log splitters. I can't even begin to fathom how pumping a jack a couple hundred times is easier than swinging a maul 6 times. THe only way I can see doing that is with an air powered bottle jack.
I don't see how any but the smallest piece of wood could be spit be jacking it up under your bumper unless you drive a semi. It's just going to jack the vehicle up.
matty_fly is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:27 AM   #15 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
install PTO.
take log splitting cone of death with you camping.
if not familiar with cone of death, SEARCH.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:28 AM   #16 (permalink)
dntsdad's Avatar
Member # 125937
This is EXACTLY the idea I had in my head.
Old 07-07-2011, 10:32 AM   #17 (permalink)
Banned
Member # 158768
that has a bit of a flaw in it's design; once you get pressure on the log against the frame, what holds the jack down on the ground while you pull down on the handle? get what i'm saying?
Old 07-07-2011, 10:33 AM   #18 (permalink)
Banned
jokemon's Avatar
Member # 165582
^ Take a phattie camping with you and make the top of the splitter cage a seat
Originally Posted by sceep View Post
install PTO.
Now that's sweet!
YouTube - ‪Hydrocut screw log splitter‬‏
Old 07-07-2011, 10:35 AM   #19 (permalink)
ukjeeper's Avatar
Member # 10091
Send a message via Skype™ to ukjeeper
Thats a good point.
ukjeeper is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:37 AM   #20 (permalink)
85f150dsel's Avatar
Member # 43079
Nothing is going to be easier to pack than an axe to split wood. Also you are going to spend an hour doing something that only takes 10-15 minutes.
It seems like most people would have something better to do than try to re-invent something that is dead for a reason.
install PTO.
They also make one that you mount on your axle of your vehicle. I can't track down the video but there is one with a locked 4x4 up on jacks and 4 people going at it
smileysarmory.com
Old 07-07-2011, 10:38 AM   #21 (permalink)
GRMhick's Avatar
Member # 87
Send a message via AIM to GRMhick
x2 This is what I'd do.
. Diamonds. 35's.
. RestoMod.
GRMhick is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:42 AM   #22 (permalink)
Member # 36707
Send a message via AIM to CJesse7 Send a message via Yahoo to CJesse7
A jack to split wood? You have way to much time on your hands.
I remember when I was 10 splitting wood by hand, to heat our trailer for the winter.
A government big enough to give you everything you want, is a government big enough to take everything you have.
[COLOR="Lime"][SIZE="3"]My Reverse Flow BBQ Pit Build[/SIZE][/COLOR]
CJesse7 is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:46 AM   #23 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
You had a wood burner in your trailer? Sweet
Old 07-07-2011, 10:47 AM   #24 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
Here's what I would do:
I'm out of shape, ok I'm a shape, round, and it doesn't wear me out. Maybe if I was doing a cord or two non-stop it would but for camping?
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:51 AM   #25 (permalink)
dntsdad's Avatar
Member # 125937
Originally Posted by ukjeeper View Post
Thats a good point.
Yup. Thats the flaw that my son and I were discussing as well which is why I posted up to seek ideas. I think combining this idea, in conjunction with using the weight of a vehicle might be a winner.
Ya?? No shit??! Jesus, you must have been awesome!!! I can remember playing 4-5 soccer games a day when I was 10 as well, and then playing the rest of the day outside. Today however, I am beat going to watch 4-5 soccer games, baseball games, etc. a day and tend to watch movies on the couch after.
thanks for telling me I don't need what I want to have though
