Member # 4506
Art Carr/Winters shifter in a Scout....
OK, I can't be the first one to put an Art Carr/Winters shifter on a 4wd version of a 727.... but I'm confused.
The linkage it nice, bolts right on, but it puts the cable 90-degrees to the tranny, right across the back of the pan, dumping the cable right were the front driveshaft wants to be. Makes routing the cable kind of a PITA as well (I'll need a longer cable, like 2 feet longer) Is there another kit? What have others done for this? I think I can route it up and over the u-joint, I'll have to pin it in place, but its just not a place I really want my shifter cable. Any thoughts (yes, I cross-posted this in Gen, since its not necessarily a Scout specific issue )(ignore the cable routing out through the tub, that was just me playing with routing when I took the picture, I've decided the better route it probably down the passenger side under the truck then a big loop up to the center hump. Naturally it goes through the tub there right above the REAR drive shaft u-joint )
I wheel a mean jackstand
wondering aimless
Member # 4586
I used one in Leona's Scout. I had to route the cable (close) to the exhaust. I used Adel Clamps to insure the cable clears the exhaust and rear drive shaft. I can take some pictures if you need. Note I got the champs from Fastenal and I used a bunch to insure there would not be issues later.
RIP Ricky, you are missed. |
Member # 4506
So you routed it above the yoke Robert? Ya, pics would be great if you had it.
Did you run a longer cable as well? Probably depends on were you put your shifter, mines pretty far back.
wondering aimless
Member # 4586
I see what I can do for pictures tomorrow. I did run it above the output, and it is behind where the stock shifter was mounted. My is on the R4, behind the LS so the shifter is different but the mounting should be the same.
#7 (permalink) | |
Member # 4506
So if I mounted it "stock", I would need to make a new bracket/cable mount and a new shift arm. If I mount it with the hardware that came with it I have to get a longer cable and run it above the driveshaft..... hmmm, wonder what will be faster/easier/best in the long run to be able to to a shake-down next weekend.............
#8 (permalink) | |
Member # 1684
S.N.O.R.T. |
My shifter is a B&M, but routes like Binder's. It comes in from the front. I loop the heavy-duty B&M cable forward around the oil sending unit (tied in place to keep it from getting too close to the headers) and then it loops back into the front of the 727 on the driver's side, away from the driveshaft.
-Tom KE7VUX |
Member # 4506
Well putting it "in line" was going to be a PITA and way too much rework. So I decided to go with a longer cable. Vendor I got the shifter from's going to take care of me... too bad the longer cables are on back-order
![]() So the stock shifters going back in for now, I'll swap the new one in when the new cable is in
wondering aimless
Member # 4586
Post up a picture of your cable, show me the ends, I have a ton of them for the ground equipment, if I have the one you need, it yours for the ride. Also will need a ball park length. Also PM me your shipping address and I shoot it off ASAP.
#14 (permalink) | |
Member # 4506
Research is showing that Art Carr made is different linkage that was in-line with the tranny. The cable has to make a big 360º loop, but that is not a big deal. But of course Art Carr went out of business last year-ish, and they and Winters didn't seem to talk or share tech. Turbo Action, who's shifter is VERY similar to the Winters uses a 360º cable routing, but they were VERY insistent that their links WILL NOT work with the Winters/Maverick/Art Carr shifter. Not even willing to talk about it. So that's my story. Looks like its fab time and hope I get it right!
#15 (permalink) |
Bruiser II
I'd put some added heat protection on there if I was you. Buddy did the B&M tucked tight also from the exhaust and it still melted. Not sure what your sleeve is made of but just given you a heads up. A kevlar hose wrap would ease the mind...
You are my Crumple Zone! ![]() BUY MY 1974 LOADSTAR 1700 FLATBED Harlem Shake Rock-Tech Offroad - YouTube My Horned Evil Cloud Experience |
#17 (permalink) | |
Member # 51801
and the Kevlar.
69 800,TBI392,TF727,D20,2to1 creeper box,d44s 4.88s detroit & lockright,hystr,power steering/Brakes,36" Super Swampers. My build Except For Ending Slavery, Fascism, Nazism and Communism, WAR has Never Solved Anything |
#18 (permalink) |
Member # 81680
Twisted Customs made some brackets and linkage pieces for the race car. 727 with a jeep dana 300. I will see if i can get some pics tonight. Bummer they don't realize how many of these transmissions are used in 4wd applications.
