Scout II BUILD with Rockwells, Cummins 12V, and 46" Claws - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-02-2012, 10:51 AM   #151 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
This is my new favorite scout Absolutely Bitchen
'71 800B is offline   Reply With Quote
Old 04-02-2012, 08:12 PM   #152 (permalink)
Engineering & Fab
Blak Falken's Avatar
Member # 206164
Originally Posted by 235frog View Post
Amazing fab work! What is the wheelbase going to be now?
The wheelbase should be right around 124" I'll have to measure it though to confirm.
Originally Posted by LibertySand View Post
Seriously, you are taking this to a whole other level! Bad Ass! I really am digging the frame plating and all the "little" things that you are doing.
Did you have any thoughts about making fender flares from tubing, kinda like Metal Cloaks fenders for Heeps rather than the Bushwacker style you used?
I was planning on building an exo-cage out of some 0.120" wall DOM tubing and then integrating some big fenders flares into the cage but I decided against it due to the additional weight and because it would move my center of mass up higher. With these fender flares I don't have to worry about smacking them on a tree or something either which is why I initially ruled out other cut-out style fender flares.
Blak Falken is offline   Reply With Quote
Old 04-02-2012, 08:39 PM   #153 (permalink)
Member # 187456
Damn dude this is one of the best Scouts I've seen. When I was a kid the mailman drove a scout and I always check em out whenever I seem em.
I follow this one along.
What kind of winch you gonna run in this thing?
[QUOTE=bigford;10609690]On a side note:
I remember telling my second ex wife " My truck comes first, then my job, then you " I never liked that woman. [/QUOTE]
EricsGreen98Tj is offline   Reply With Quote
Old 04-02-2012, 10:18 PM   #154 (permalink)
Engineering & Fab
Member # 206164
It has a Warn M8000 in the front bumper right now. When I build a rear bumper I am going to put this winch out back and get either a Warn M12000 or M15000 for the front.
Old 04-03-2012, 06:36 AM   #155 (permalink)
Member # 130003
You sir, are a craftsman and an artist!
Excellent design and execution!
Harold Phipps is offline   Reply With Quote
Old 04-14-2012, 08:17 PM   #156 (permalink)
Member # 187456
Updates?
Old 04-14-2012, 08:38 PM   #157 (permalink)
International Dan
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
This things turning into a real animal. Lookin forward to the final product and pics of it being used
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html
facebook.com/hardenedways
Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you.
binderbound is offline   Reply With Quote
Old 04-18-2012, 05:40 PM   #158 (permalink)
Engineering & Fab
Member # 206164
Updates?
I wish I had some updates, I haven't even touched it for a couple of weeks...been tied up with other stuff.
I've got some pics and tech on the Cummins, Th475 and doubler that I'll post on in the meantime.
Old 04-22-2012, 05:28 AM   #159 (permalink)
Member # 144823
Absolutely bitchin truck! The details of your fab work amaze me. Can't wait to see this one come together!
~Ole' Sarge
71 Scout, Doubled, EFI, SOA, OBA, Ram, Hydroboost, 39.5s, D60/14b, etc, etc...
Ole Sarge is offline   Reply With Quote
Old 04-22-2012, 07:38 AM   #160 (permalink)
Member # 216998
Very nice work, like all of the details. Makes me want to get Solidworks and a laser!
1939dodge is offline   Reply With Quote
Old 04-29-2012, 10:01 PM   #161 (permalink)
Engineering & Fab
Member # 206164
Ok, I had a little time to spend on the Scout so I made some progress.
I wanted to run some rock sliders on the Scout, so I was planning on making some but instead of dragging this project out any longer I found some sliders made by Trail Gear for Toyota's that seemed like a decent option. They are made from 1.75" OD, 0.120" wall DOM, they make them in 58", 67" and 78" lengths...the 67" length turned out to be perfect for my application and the price was right so I ordered them.
I wanted a slider that would actually be a slider and one that could also be used as a jack point if need be, I didn't like the 0.120" wall mounting legs they came with and plus they were to short, so I got some 1.75" OD, 0.250" wall DOM and made my own mounting legs.
I also designed some mounting fish plates and gussets which I had laser cut.
I don't have a tubing notcher so I cut the mounting legs to length and rough cut the cope in them with an OA torch and cleaned them up with a grinder. Here they are:
Check out my YouTube channel: http://www.youtube.com/user/BlakFalken
Check out my build thread: http://www.pirate4x4.com/forum/showthread.php?t=1039974
Old 04-29-2012, 10:10 PM   #162 (permalink)
Engineering & Fab
Member # 206164
For the ultimate in strength I decided to run the mounting legs through the frame and tie them into the cross-member fish plate and gusset them into fish plates on the outside of the frame.
The hole saw took to long so I rough cut the holes in with the OA torch and cleaned them up with a grinder. Here are a couple shots of the holes:
Old 04-29-2012, 10:26 PM   #163 (permalink)
Engineering & Fab
Member # 206164
Here are some pics of getting the mounting legs positioned and tacked in with the fish-plates and gussets:
Old 04-29-2012, 10:32 PM   #164 (permalink)
Engineering & Fab
Member # 206164
I set the rock sliders in at an angle of 25* from the horizontal, which gives just enough clearance to open/close the doors while providing some protection to the body.
I pulled the Scout out of the shop to put my drivers side front fender back on after cutting and fitting the flare, you can see the sliders pretty well in these pics:
Old 04-29-2012, 10:46 PM   #165 (permalink)
Engineering & Fab
Member # 206164
I also started working on the rear fenders, they are going to take alot of cutting to make the Silverback flares work. I am also going to have to cut out the rear fender wells, cut them in half, widen them out and weld them back in.
Here are a couple of pics of how the rear fenders will be cut to match the look of the fronts:
Old 04-29-2012, 11:59 PM   #166 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Nice progress Side bars and the front flares look good.
Not sure about the rear flares, though...you've got them mounted "backwards" so maybe that's why it's throwing me off?
David H. Petraeus for President 2016
guidolyons is offline   Reply With Quote
Old 04-30-2012, 08:21 AM   #167 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
Love the sliders. the rear flares are for the front correct? why not use rear flares??? Still love the terra
Edit: looked again. I see where you are going to trim at the rear of the fender.
Old 04-30-2012, 10:24 AM   #168 (permalink)
Rock Stacker
1966Scout800's Avatar
Member # 159101
Looks good, love the look of the sliders. Where are you at in Northern California?
Livin' the Dream
-RIP Fish-
1966Scout800 is offline   Reply With Quote
Old 05-02-2012, 01:48 PM   #169 (permalink)
Engineering & Fab
Member # 206164
Yeah you guys are right the flares I am using on the rear are actually fronts. I purposely custom ordered two sets of front flares for two reasons. First, the Early Bronco's have a body line in the rear quarter panel, so rear Bronco flares have that contour molded into them which I didn't want. Second, I wanted to trim the rear quarters on the Scout up higher on the back end so they would be less of an obstacle with departure angles and wouldn't get bashed as easily.
I am in the Chico area, about an hour and a half north of Sacramento.
Old 05-02-2012, 02:02 PM   #170 (permalink)
Engineering & Fab
Member # 206164
Here is how I cut out the fender and fender-well, my original plan was to cut the fender-well in half widen it out and weld it back in...after looking at it thinking about it I decided I would be better off making custom fender-wells due to the fact that the tires stick so far out of the fender-wells there would be alot of wasted/dead space in keeping with the conventional rounded fender-well.
Old 05-02-2012, 02:05 PM   #171 (permalink)
Engineering & Fab
Member # 206164
Here is how I ended up cutting it out for some custom new fender-wells.
Old 05-02-2012, 02:11 PM   #172 (permalink)
Engineering & Fab
Member # 206164
Here is how the fender ended up after cutting...I still have a little trimming to start doing here and there, then I have to fab up some new fender-wells and weld them in....gives alot more room for the 46's.
Old 05-03-2012, 02:49 AM   #173 (permalink)
Member # 144823
Looks Great! I personally really like how the front flares "reversed" in the back look. I ran the 3" cutout early bronco flares on mine, but never thought about running a second pair of fronts. Real smoooth.
~Ole' Sarge
Old 05-03-2012, 05:23 AM   #174 (permalink)
Member # 121272
It all looks really great, but you'll probably wish ya had a bit more clearance between your sliders and the bottom of your door, a good smack on the slider and you'll be stuck in your cab!
ChocFlip201 is offline   Reply With Quote
Old 05-03-2012, 08:12 AM   #175 (permalink)
wondering aimless
JetFxr's Avatar
Member # 4586
Here's a picture of my junk, I also turned the front flares backwards and cut the quarters to increase the departure angle. Oh yea the Tera top is a nice touch also
RIP Ricky, you are missed.
JetFxr is offline   Reply With Quote
