Member # 1586
Shackles.....
I am looking to get some new front shackles (maybe rears soon too) and was wondering what different people are running and what seems to work well.
I am sprung over (saggin springs) and would also like to have the shackles give me an inch or two of lift. They are stock shackles on the front right now. Thanks for any replies...... I can't build any where I am currently so thats not an option right now....... |
#2 (permalink) | |
IH/Rover Moderator
Re: Shackles.....
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html Last edited by Old Scout; 11-08-2001 at 08:18 AM. |
Member # 1586
Nope, .......weak I know. I left most of my tools at my parents house (400 miles away) since there is NO room in this fawkin studio apartment.
Come awn, somone atleast point me in the right direction....thanks. |
A buddy of mine with a Scout used lift shackles from a flat fender Jeep (45-? I think) which were good for 2" of lift. The only problem that he ran into though was that the bolts were too small for the shackle holes, but fit through the stock bushing with sleeve just fine. He solved this by putting in a spacer on the shackle hole. Damned stupid if you ask me because it was just so thin. Personally, I would have pressed out the bushings and installed new ones with a larger hole, or just popped out the sleeve, drilled them slightly larger, and popped in a larger sleeve. Hope this helps. Let me know if you need some more info.
Member # 5982
What you own a Scout with no tools
Are you nuts man? Too bad I just cut off a pair. Even auto parts stores can sell you a pair extended shackles. It's going to do wonders for your steering unless you have enough turn in the knuckles. You could also go to a local metal fabricator and have something whipped up. If your bold, buy some metal from Home Depot, 3/16 or 1/4 will work, buy some flares and start cutt'n.Joe
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
#6 (permalink) | |
Member # 1586
Ok, I lied.....I have some tools, just nothing to cut with. Seems like that (making your own) is the prefered method for Scout's......I will have to look into that then. I was kind of hoping to just go and pick up something sheap somewhere.......anyone want to make some and sell them to me cheap????
Member # 1586
Oh, and I was curious too......if I were to go and cut some metal from Home Depot or where ever, wouldn't I need to weld a support across the middle??? If not then maybe I should go snatch me up a hack-saw.......
#8 (permalink) | |
IH/Rover Moderator
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
#9 (permalink) | |
Member # 4001
BTW...Where are you located?
Dysfunctional Rockcrawlers |
Member # 1586
I am in LA right now, but might be back up there before too long.....
How heavy steel should I go for, like 1/4 inch??? And as far as making them so I get a little lift out of them, I want about 2, how long do I make them? I recall hearing somewhere that every inch over stock gives you 1/2 an inch of lift.......does that sound right? Or should I lift it to the sky with 18 inch shackles on the front???? Hehe.....and yes that last comment was a joke
#11 (permalink) | |
Member # 4001
#12 (permalink) | |
Member # 1586
Right on, thats what I was thinking. So I am going to try and pick up a piece of metal. I will let ya know how it turns out. Thanks again. |
#13 (permalink) | |
I try to use 2"x3/8" thick steel strap. Stock are 3" center to center, so I go with ~4.25". If they won't cut it, hack-saws are cheap! ![]() Use a 7/16" drill bit to punch the holes.. a quick can of spray paint.. ta-da. I find it easiest to cut the steel in my chop-saw, stack the four pieces on my drill press, and punch two holes in 'em.. Using my 1/2" hand held drill takes longer.. and a hacksaw would SUCK. Too-long shackles will not ONLY foul up your caster, but they'll also increase leverage on your shackle mounts. I have a few friends that have ripped the shackle mounts off the frame b/c of extended shackles.
-Tom KE7VUX |
#14 (permalink) | ||
Member # 7953
My engineering classes tell me that longer shackles exert no more leverage against the frame mount than lift springs which move the axle away from the spring the same amount. Leverage is always calculated at right angles. The distance the force is from the fulcrum dictates the amount of leverage, not whether the lever arm is curved or straight. So, a lift shackle that raises the frame 1 inch, would be no more prone to ripping a shackle mount, then a lift spring that raises the frame by one inch. Or am I missing something in the equation?
Hooper [URL=http://www.ihssii.org]The SSII Registry and Gallery[/URL] [URL=http://www.ihssii.org/Hooper]The Hooper Truck[/URL] [b][color=orangered]Stripling Warrior 4x4[/color][/b] |
#15 (permalink) | |
Member # 5982
Sound right?
#16 (permalink) |
Member # 4001
Ah, Jeez...just weld your mounts on there better then....
#17 (permalink) | |
Member # 7953
Hence my argument that extended shackles offer no more leverage against the mount than lift springs offering the same vertical lift. I am pretty sure on this, but... Patrick
#18 (permalink) | |
Thus you can "slam" the shackle mount when you twist the spring axially. The longer the shackles, the more the deflection available, the more torque to the mounts. Why do you think long shackles get cross-bars n' such to help stiffen 'em up - because they flex! When the shackle flexes you change it from pure up/down/front/back to side to side twisting forces, too. A shorter shackle minimizes that..
-Tom KE7VUX |
#19 (permalink) | |
Member # 7953
![]() You are right, the slop in the shackle allows the springs to get farther off center line, and the longer shackles magnify that leverage, as well as allowing for more slop. That makes sense. It is not an even, steady force against the mount, rather it is a light pressure, than a solid hard pressure when the slop is gone.
#23 (permalink) |
Member # 5733
Im concerned about the metal fatigue for aluminum, also about the ability of aluminum to be easily gouged, especially when the "shackle" is pivoting in its mount & comes in contact with the steel frame, make sure to keep good bushings in em'. I like the look of those anyhow. Might as well polish them!
#24 (permalink) | |
Member # 4214
" You may be a cunning linguist but i'm a master debator " |
#25 (permalink) | |
Member # 5733
