Member # 6708
ok, here is the deal. My GF is looking for her first 4x4. She is considering a '67 scout with 4cyl. My question concerns the engine and parts avalibility. How good is the 4-cyl? I know it is the half-a-v8 engine IHC used many years. Can a IHC V-8 be swapped in later. Are the parts for the '67 (scout 80?) still out there? I know there is a dedicated network of Scout Enthusiests out there but I'm ignorent of how wide spread it is compared to say Early Bronco or LandCruisers. What later (stronger) axles are a bolt in swap? Anybody make Lift kits or is everything piece together? Thanks for listening to a Ford nut invading your space.
eric
'There will be pork in the tree tops by morning!'-Lion in Winter. 'Dear,dear.....what ever shall we do with mother.'-Lion in Winter. "Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson 'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!' |
Member # 6708
Thanks, I did search and found some answers but still haven't found info on lifts. Every reference I've found talks about swaping later SII springs or T-all springs. I assume nobody makes springs new/aftermarket. Any opinions on the merits of this stock '67 800 as a good starting point for wheelin'
Eric
Member # 5982
There was a topic on building an 80 not too long ago. Mr Scout sells lift springs for the 80/800. You can also use CJ springs, but they don't work well in the front due to weight.
Joe
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
Member # 6708
Thanks, The only other question is what areas on the 800 are prone to rusting?
Eric
#6 (permalink) | |
Joe
These opinions are [u]mine[/u], [u]mine[/u] I say! Piss off and get your own. Currently on [url=http://members.ebay.com/ebaymotors/aboutme/nqs%40tigger.tmcom.com/]ebay[/url]: Nothing [url=http://tigger.tmcom.com/~nqs/blogger.html]As I see it[/url] -- An irregular blog |
#7 (permalink) | |
Member # 6708
__________________________________________________ __ Damn, thats where I went wrong, Thanks Joe ![]() and here I was only concerned with topside and bottomside. ![]() Eric
Member # 7430
Specific rust area's on the 80/800 series are the bottom/front section of the rear quarter panels, and the rockers. My 80 had problems on the inside of the bed, but I dunno if this is a normal problem or rig specific.
"Man, your playlist has Merl Haggard and Megadeth- You're like the Hillbilly From Hell!!" |
BTW, the 80/800 buildup post can be found here
Member # 6708
Thanks all for the help. Found it all and it is helpful.
to all ![]() Eric
#11 (permalink) | |
Member # 4001
With that in mind, my only rusted on one side then...the inside...
Dysfunctional Rockcrawlers |
