MON 11/12 – Axle Q and A - Daily Topic - Pirate4x4.Com : 4x4 and Off-Road Forum
View Poll Results: What's the best
Dana 44 0 0%
Dana 60 9 64.29%
14 Bolt 2 14.29%
Other 3 21.43%
Voters: 14. You may not vote on this poll
Old 11-11-2001, 09:14 PM   #1 (permalink)
Member # 5982
MON 11/12 – Axle Q and A: What do you run, what do you want, locker, spool, ARB, etc.. Is a 44 enough or it’s gotta be a 60. Are 14 bolts misunderstood? What axles swap onto my rig.
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote
Old 11-11-2001, 09:21 PM   #2 (permalink)
Member # 5982
Dream: 60 RC front and rear spool in the rear ARB in the front.
Real: Dana 44 full width in the front with EZ-locker, and Dana 60 or 14 in the rear with spool. The 60 or 14 will depend on what I can find cheap, full floater will be ideal.
After the debate about spool vs detroit in the real I think I can live with a spool. The rig will be trailered in the near future. I also like the idea of a FF is the rear for ease of trail repairs.
Old 11-11-2001, 11:39 PM   #3 (permalink)
Member # 7134
Send a message via ICQ to NotQuiteSane
I'd like RR 60's front and rear. I think the 14 bolt is slightly stronger, but I like the idea of only caring one spare R&P. stuff both with ARB's.
Reality looks like front 44 and rear 60. the 800 I'm getting has something in the back (trashlock?), so I'll probably stick it in front and a rear EZ untill I can afford better
These opinions are [u]mine[/u], [u]mine[/u] I say! Piss off and get your own.
Currently on [url=http://members.ebay.com/ebaymotors/aboutme/nqs%40tigger.tmcom.com/]ebay[/url]: Nothing
[url=http://tigger.tmcom.com/~nqs/blogger.html]As I see it[/url] -- An irregular blog
NotQuiteSane is offline   Reply With Quote
Old 11-12-2001, 07:33 AM   #4 (permalink)
Member # 4001
Well, I voted for 60's...(surprise, surprise)
Because Heaps are lighter weight, they can get away with 44's and bigger tires. Scouts, especially you Scout II owners, need a heavier axle if you are going big. I would at least throw a 60 in the rear of any Scout...not just for the axle size but for the pinion size.
Dysfunctional Rockcrawlers
Scout Dude is offline   Reply With Quote
Old 11-12-2001, 08:09 AM   #5 (permalink)
Member # 2071
Re: MON 11/12 ? Axle Q and A - Daily Topic
Originally posted by jdjanda
MON 11/12 ? Axle Q and A: What do you run, what do you want, locker, spool, ARB, etc.. Is a 44 enough or it?s gotta be a 60. Are 14 bolts misunderstood? What axles swap onto my rig.
It all depends.
Trail rig? The next evolution will be a '44 (or HP44) front, 60 rear, and 8-lug until a front 60 falls into my lap. Detroit or Lockright.
Tow-rig? RA-15 rear. I'd like a '60 front for the weight capacity and big brakes, but it'll likely get a '44 front at least as a stop-gap measure when it comes time to hang a front end under it.
"light weight" race rig? 44s front and rear. TRUSSED. 60s are too heavy to be skying. Unsprung weight is BAD for performance.
Street rig? 44s front/rear, unless I run out of front '44s, then a Dana 30 would be fine, too. I haven't broken a '30 yet.. just a few 44s.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 11-12-2001, 08:48 AM   #6 (permalink)
RustoleumWhite's Avatar
Member # 4506
Ultimate:
Terra HP 6-'s front and rear, stuffed with nice Dana gears and ARB's.
Realisticaly:
D60 Semi-rear (t-all), shaved w/1-1/2" shafts and probably a spool. Front would be a D44, standard for now, but I'm working on a HP. ARB idealy, but that may have to wait. Probably a Lock-right for now. The HP will most likely get Alloy shafts and "super" joints.
If a start busting the D44 on a regular basis, then the D60 goes in, if I find one for a decent price.
To make tommy happy: for a "light weight" race rig. Strengthend Ford 9"'s front and rear, front a 9"/D44 hybrid.
RustoleumWhite is offline   Reply With Quote
Old 11-12-2001, 09:22 AM   #7 (permalink)
Member # 406
44 front, 35 spline semi-floating 60 rear. I currently run 35's (actually they're BFG's, so they're really more like 34's), and haven't had any problems yet with the 44 front.
sdscouter is offline   Reply With Quote
Old 11-12-2001, 07:04 PM   #8 (permalink)
Member # 5982
A 44 can live in the front of a Scout II, but swap to Chery or Ford outers, the Scout II 44's use a Dana 30 outer. If you use the Ford outers you can keep the 5x5.5 pattern and have a much stronger kit.
Joe
Old 11-12-2001, 08:07 PM   #9 (permalink)
Hayraker's Avatar
Member # 5946
Joe
Keep on promoting them 44's Joe, you haven't found a cheap 60 yet have ya
Of course I will still be running the 44's until I come up with money for, new front locker, tie-rods, drive-shafts, eight hole wheels, 38" tires, get the dually hubs machined down, or swapped out, different springs, etc.etc.etc...........................Hey I'm with you man, maybe 44's will hold up.
I think I will do a scientific study and see how much abuse regular old scout 44's can take since I have that pair of 60's just sitting there in reserve. Trashing the 44's might be the quickest way for me to get started on the swap.
Gotta make it thru huntin season first
I.R.B.S.T.M.
Hayraker is offline   Reply With Quote
Old 11-12-2001, 09:00 PM   #10 (permalink)
Member # 5181
44's don't hold up that good. I broke my front locker and both drive lines at the same time and it striped the ring gear and pinion. I also snaped a stub shaft whith a 305 Chevy and 465 dana 300 combo.
Abba is offline   Reply With Quote
Old 11-13-2001, 06:33 AM   #11 (permalink)
Member # 4001
Ouch man...
Old 11-13-2001, 07:58 AM   #12 (permalink)
Member # 51
Sounds like operator error
Scouter is offline   Reply With Quote
Old 11-13-2001, 08:14 AM   #13 (permalink)
Member # 2071
Joe
From '74 up the SII D44 uses Dana 44 outers with the big-joint.
Same 27-spline count as the D30 stubs, but bigger joint.
Only problem with the stock Dana 27-spline stubs is you can elongate the holes and shoot U-joint caps out.
I haven't done that since I started welding the U-joint caps to the stub-shaft.
-Tom
KE7VUX
Old 11-13-2001, 08:16 AM   #14 (permalink)
Member # 2071
What gear ratio?
-Tom
KE7VUX
Old 11-13-2001, 03:43 PM   #15 (permalink)
Member # 6804
For axles I'm likeing what I have. 60 front with 35 spline stub shafts and Detroit locker. Those 30 spline stubs didn't hold up all that well.
80 rear with Detroit locker and alloy axle shafts. Currently working on clearancing that thing. Should end up with better clearance then a 60. Good point behind the 80 is the pinion gear is HUGE. I have a 392 with super low gears and 38's.
5:13 gears in both.
This isn't the best setup for everyone but it works for me.
Scoutaholic is offline   Reply With Quote
