All-Purpose Scout 80 Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2013, 02:22 PM   #1 (permalink)
Member # 137726
I spent a couple of years building and wheeling my daily driver Toyota T100, and while fun at first I definitely found the wear and tear on the daily driver to be a drag. Not to mention the more I modified the truck, the more it sucked for on-road duties, as I’m sure most here know. I’ve always liked building things myself, so I started looking for a project that I could really get into and build as much as possible myself. I’m a mechanical engineer by trade, and find fabrication and welding to be a really enjoyable change from flying a workstation all day.
I bought this 1962 Scout 80 on Christmas day in 2010, from a family friend who was clearing out a collection of cars in preparation for a move. He has had it for 15+ years used as a utility truck to move cars around his property. My brother in law and the owner’s son both learned to drive in the truck.
My wife didn’t agree with me that this was all the Christmas present we needed.
I brought home in March 2011, and it sat for the better part of a year while I figured out exactly what I wanted to build, and collected parts.
The truck was complete when I brought it home, but had not run in ~10 years. I think the previous owner would have preferred that I rebuild it, but I wanted to build the truck with modern drivetrain, to be fairly trail capable but still comfortable enough to drive to and from the trails.
Hmm, the garage hasn’t looked this clean in a while ...
Specs (subject to change whenever my upgrade-itis kicks in)
  • Chevy 350 w/ TBI fuel injection - changed out for a 2004 Silverado 5.3 LM7
  • Chevy NV4500, converted from 2wd to 4wd
  • Jeep Dana 300, w/ 32 spline input shaft (advance adapters)
  • Front Axle: Chevy Blazer Dana 44, Ford hubs and rotors. Narrowed to Scout II width to be able to use Scout II axle shafts.
  • Rear Axle: Scout II Dana 44.
  • Gearing: 4.56 all around. Detroit locker in rear, ARB air locker in front
  • Tires: 35 x 12.5 x 15 BFG Mud Terrain
  • Front Suspension : 3 link with coilovers
  • Rear Suspension: 56” chevy leaf springs
This won’t be a fast build, but I’m hoping I’m to a point where I have the major parts collected and/or figure out, and will be able to update this often enough to keep it interesting.
MotoDave is offline   Reply With Quote Quick reply to this message
Old 12-10-2013, 02:33 PM   #2 (permalink)
Member # 137726
I really debated back and forth about what to power the scout with. I am a huge fan of small turbodiesel engines, so initially I was looking for a Cummins 4BT or Isuzu 4BD engine. I didnít have much luck finding one of those either locally or at a price I could afford, so I decided to go with the old standard, a Chevy 350 V8 with TBI fuel injection. I ended up finding one up in Fresno at a good price, the only catch being I had to drive up, pull the engine, and drive back in a day. I managed to get it done, but damn that was a long day.
I really had no clue what shape the engine was in since the truck wasnít running, but for the price it was worth it just for the TBI setup. I pulled the heads and oil pan, and nothing looked too bad. Wound up just replacing the gaskets throughout and buttoning it back up. Replaced the oil pump while I was at it, and shot it with some chevy orange paint, because secretly Iíve always wanted a shiny orange V8 engine 
I knew I wanted a manual transmission, and I knew in order to make this a dual use trail and street truck Iíd want something with an overdrive. A bit of research pointed me to the NV4500 5 speed transmission, and I was able to pick up a used one out of a 90ís chevy 1 ton truck.
These transmissions have become pretty popular lately and the 4wd versions are getting pricy. I found a decent deal on one that was local to me, only catch being that it was the 2wd version. I found the parts needed to convert it to 4wd on ebay (mainshaft and tailhousing), and set about swapping the parts over. The mainshaft is maybe the most comically large machined piece Iíve ever worked with. No, thatís not a tiny pencil.
I picked up a small parts kit from QUAD 4x4 Home Page, including new snap rings and a shim set. I also bought their NV4500 rebuild manual, which is definitely worthwhile if youíre considering rebuilding one of these. The mainshaft swap wasnít too bad, you can leave the countershaft in the case as shown in this how-to. A couple of special tools were required, I had to get a bit creative with pullers to get 5th gear and the speedometer tone ring off of the mainshaft.
All the parts swapped onto the new mainshaft (old one in the background)
I also had to strap the tranny case to my welding table and clamp a 6í piece of tube to the table, in order to be able to torque the 5th gear nut to 250-325 lb-ft with the special socket.
Done
The engine I bought came hooked to an automatic transmission, so I bought a flywheel and clutch kit. Iíve been told itís a good idea to have the new flywheel match balanced to the old flex-plate, but Iíve yet to find a shop locally to do the work.
I pieced together a set of 35x12.5x15ís, which is the size I intend to run. The guys I wheel with are mostly on 33ís and 35ís, and I feel like itís a good compromise between highway drivability, trail capability (and keeping the Dana 44ís alive). Theyíre just a tad larger than stock.
Old 12-10-2013, 02:38 PM   #3 (permalink)
Member # 137726
A buddy of mine came down for a weekend, the original plan was to shoot some sporting clays, but we got rained out. Yes, it rains sometimes in SoCal. Anyways I put him to work, and we pulled the stock 4 cylinder out of the scout with no drama. There is a decent amount of room in the engine bay.
I built some engine mounts, and got the new engine and tranny roughly into place
Once the engine was where I thought it worked best, I tacked the motor mounts into place, then boxed them in. Not my best welds, as youíll see later these get rebuilt after I got sick of looking at my ****ty welding for a while.
The Engine is as far back as I could get it, while keeping reasonable clearance for the exhaust manifolds. Iíll have to trim the firewall above the throttle pedal, but other than that it sits well.
Iím using corvette style exhaust manifolds, they do a good job of keeping everything tucked in close.
The manifold actually clears the firewall, but you canít get a wrench on the bolt.
Around this time my wife and I went through some really rough times due to some personal matters. I also turned 30 and felt like cheering myself up, so I pre-built the Scout in Lego format.
Old 12-10-2013, 02:42 PM   #4 (permalink)
Member # 137726
Oops, stock axle (Dana 27) fell out.
Iím using a stock width Scout II rear Dana 44. Threw the wheels and tires on to see how the width looks on the narrower Scout 80 body. I like it 
Am I getting this stance thing right?
The rear end sat higher than I wanted with the springs over the axle, so I flipped the setup around and am running SUA. For now I am using 56Ē chevy springs, with a few leaves removed. I anticipate needing to tune this once the truck is on all four wheels again.
I used the CAD (Cardboard Aided Design) method to make some rear spring hangers.
Shackle hangers were more of a Ďcut and see if it worksí approach.
Rear end sitting on the new springs for the first time
Old 12-10-2013, 02:45 PM   #5 (permalink)
Member # 137726
Front axle is out of a Blazer, narrowed to use Scout II inner axle shafts. The main downside I see is the passenger side tube ends up really short. I’m going to cut down the leaf spring pad, and see if I can make it work, otherwise I may look for another axle or retube this one. Trying to stick with axles from a standard application so that spares are easier to source.
Note to self: Axles are heavy. Be careful when moving them solo.
Built a better (safer) axle stand, so that I can work on the axle up on my welding table.
Hacked off the existing bracketry, which was a sketchy looking radius arm setup
Figuring out the difference in axle legnths, i.e. how much to chop off of each axle tube
Both knuckles removed
No turning back now
Old 12-10-2013, 02:54 PM   #6 (permalink)
Member # 137726
I made a simple jig to be able to measure the driveshaft angles, basically just a plate that bolts to each yoke with a sting in between. I’ll run CV driveshafts so I set the front pinion angle pointing right at the transfer case output.
A friend of mine loaned me his jig for measuring caster angle, it consists of a precision ground bar with 2 machined bolts that slide into the knuckle taper. The bolt heads are turned down so that the round bolt head centers on the bar.
Set the knuckles for 8 degrees caster. My 3 link model shows me losing ~ 6 degrees under bump, and I wanted to make sure I don’t go into positive caster to try to avoid any wobble issues.
Burned in the knuckles with multiple passes with the MIG welder, and wrapped everything up with some welding blankets to try to let it cool slowly.
Old 12-10-2013, 03:28 PM   #7 (permalink)
Member # 137726
Around this time I started playing around with the front suspension design. Iím doing a 3 link, using Johnny Joints all around. These things are massive.
Iím an engineer by day, and focused on suspension design during college, so I had some fun modeling the frame and suspension bracketry in SolidWorks.
Ignore the triangle attached to the axle, I was using it as a reference to measure caster change through the range of travel as well as axle movement, side to side.
I designed the brackets to tab and slot together for easy assembly, and had a local waterjet shop cut them out for me. The cost on the brackets was surprisingly reasonable, and they assembled just like Iíd planned.
Lower link brackets
Upper link brackets
Drivers side upper and lower brackets tacked on the axle
The cast spring perch on the passenger side was in the way of the lower link bracket, I cut away just enough to fit. Didnít disturb any of the factory plug welds, and there is still plenty of tube pressed into the housing.
Old 12-10-2013, 03:28 PM   #8 (permalink)
Member # 137726
Upper and lower link mounts mocked up on the frame. These are tacked in now, but I didn’t get a decent picture of them.
I got frustrated trying to find anything square to measure to, the stock leaf spring hangers on my truck seem to be quite a bit off from side to side. Found a pair of 5/8” diameter holes in the bottom of each frame rail that were probably used for alignment during original build, so I turned some small pins to fit tightly in each hole, and bolted up a piece of aluminum angle to act like a datum point for lining up the suspension points.
Using the latest in go-fast aerospace composite for my links (mock up links using PVC)
Old 12-10-2013, 03:32 PM   #9 (permalink)
Member # 137726
Cycling the front axle, I quickly realized my upper link would be limited to about 4”of uptravel by the motor mount. I played with CAD (cardboard aided design) and came up with these side plates, showing the additional clearance that will be gained to the upper link
Some more CAD work, and I plated in the top and bottom of the mount. The aluminum spacer is .030" wider than the finished joint when using typical spring eye bushings, and is a handy spacer to have around for making mounts like these fit with to Paul Jr'ing into place.
Added speed holes and burned in the top and bottom
Had to re-make the motor mount off the engine as well
And here it is, tacked into place on the frame.
Old 12-10-2013, 03:42 PM   #10 (permalink)
Member # 9316
Looks good. I'm interested to see how your coilovers fit. Mine got into the frame at droop. I took kind of a extreme route and tubed the front.
ROCKHEADS transplant in Indiana
CITY WORK is offline   Reply With Quote Quick reply to this message
Old 12-10-2013, 03:50 PM   #11 (permalink)
Member # 137726
I am planning to run 12" travel coilovers, probably the Fox 2.0 remote reservoir units with the larger (7/8") shaft. I have a friend with an early bronco who's running those with good results, a lot of how I'm building this truck is based off of his experience.
I am going to try to get the front end together this weekend including tires, should give me a better idea of how things line up.
I've got a few more sections to post to get caught up to where I am now, but its time to run to the parts store before they close.
Old 12-10-2013, 03:52 PM   #12 (permalink)
Member # 137726
Quick shot of roughly how the truck sits today, this is target ride height
Old 12-10-2013, 07:39 PM   #13 (permalink)
Member # 16680
nice work. Those brackets look great.
Ive got a sweet old 'stock' rack that would look good with the sleeper theme you seem to have going.
plug ugly is offline   Reply With Quote Quick reply to this message
Old 12-11-2013, 08:21 AM   #14 (permalink)
Member # 137726
Because I know people will ask, here are the numbers from the 3 link calculator:
Vertical Separation at the frame: 4.5"
Vertical Separation at the axle: 8.0"
Anti-Squat: 83%
Roll Axlis Angle: -1.06į
This is just estimated, based on the 'CG at cam centerline' method. Mainly I was focused on minimal driveshaft plunge, and not letting the caster angle go positive under bump.
Moving the upper link mount up would mean either cutting into the driver's foot well, which isn't that big to start with, or running a lot shorter links so that I can run the upper link mount on the curved part of the frame. Lowering the lower link frame mount would have reduced ground clearance even more. Anyways I feel this is a decent compromise for the space I am working with. And hell, if it sucks I'll just rebuild it anyways.
Old 12-11-2013, 10:18 PM   #15 (permalink)
Member # 137726
Hmm, definitely old school looking. Not sure I am going to run a roof rack on this truck.
Old 12-11-2013, 10:27 PM   #16 (permalink)
Member # 137726
I picked up a Dana 300 and swapped in the 32 spline input to mate with the NV4500 output shaft. I will run the case stock for now, but can see eventually upgrading to 4:1 gears and stronger outputs if needed. I guess I didn’t take any pictures of the work on the t-case.
The Jeep Dana 300 and GM NV4500 have the same bolt pattern, but the GM pattern is rotated at a different angle compared to most other round pattern transmissions. I initially bought a clocking ring but found out it won’t work for this combo (unless I want the transfer case clocked upward about 60 degrees). I made some paper templates to figure out the clocking.
I turned the ring on my lathe, and brought it over to a friend’s shop to drill the pattern using his Bridgeport mill and rotary table.
In case anyone else finds it useful, here is the hole pattern layout:
https://drive.google.com/file/d/0B7r...it?usp=sharing
The last thing I need to do on the t-case is swap in the extended length input bearing retainer that Novak makes. The pilot diameter is long enough that you maintain transfer case pilot into the transmission tailhousing. Parts for the Jeep & IH Dana 300 Transfer Cases. In hindsight it would have been simpler to use their adapter kit that comes with both the clocking ring (with a pilot) and a new 32 spline input Adapting the GM NV4500 Transmission to the Jeep Dana 300. In any case my input bearing retainer was screwed up so I’d need a new one anyways.
Had to make room in the floor under the passenger seat to fit the transfer case. I'll also have to modify the transmission tunnel cover to fit the shifters
I build a crossmember to support the transmission tailhousing, using urethane bushings in each end.
This picture makes it look worse than it is, the crossmember hangs ~1” below the frame rail. I plan to build a skid plate to protect the important parts that will mount to the crossmember.
Old 12-11-2013, 10:37 PM   #17 (permalink)
Member # 137726
I've never really liked the look of the old school gas caps that came on the Scout, they stand off of the body quite a bit. Plus mine are missing, and not trivial to find NOS. So a while ago I came across some sweet looking flush mount fuel filler caps, intended for homebuilt aircraft
ACS FLUSH FUEL CAP 10600 from Aircraft Spruce
Now, if i'm putting airplane parts on a crappy old truck, I better make them look good, right? The easy answer is to mount them on the face of the body, but I really wanted them flush. I had a big chunk of delrin left over from a project at work that came home with me, and a 5 gallon bucket of chips later I have a 2 piece die set:
I made another quick tool to center the hole saw on the existing fuel filler hole.
Slow and steady with the big wrist breaker drill, and we have a concerningly large hole in the side of the body
Using a 9/16 bolt to draw the dies together and my impact gun, the recess in the body is formed
Finished result came out better than I had hoped for using plastic tooling.
Old 12-11-2013, 11:04 PM   #18 (permalink)
Member # 137726
Tonight I was able to get the front axle cycled up to what I think will be full bump + a bit. At this point the steering tie rod will be damn near getting into the frame. There seems to be pretty decent clearance in the wheel well, Iíll throw a fender on tomorrow to see how much trimming its going to take but it looks alright so far.
The new motor mount is doing its job, plenty of clearance
I need to see what this looks like with the axle articulated, but it looks like the coilover has enough room.
The front of the wheel well will get trimmed as needed, cant check it yet because the bumper is in the way. Hereís how it looks turned hard driver
Iím going to try to get the lower link tubing bent to get rid of this issue
If anyone knows what sort of bender it takes to bend 2Ē OD, ľĒ wall tube let me know. Iím assuming the typical JD2 bender wonít be very happy?
Old 12-12-2013, 07:22 AM   #19 (permalink)
Buck Dodson's Avatar
Member # 35185
Dang I like seeing these builds by the guys that get to say " so I just turned one on my lathe and finished with my buddy's bridgeport"...
Great build. As far as bending links to clear the turning radius, I went a different direction and increased the width 3" over a Scout II axle. I know its late in the game now, but 1-1/2" wheel spacers would do the same thing.
Just make some on that lathe....
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
Buck Dodson is offline   Reply With Quote Quick reply to this message
Old 12-12-2013, 07:50 AM   #20 (permalink)
Member # 137726
Yeah, the lathe turns out to be super useful to have in the garage, I use it way more than I ever thought i would. Started out with the little harbor freight bench lathe that was purchased for one particular job, it paid for itself and the larger 12x36 Craftsman that I have now.
I've almost bought a mill a few times now, but having a buddy that's got one 5 miles away is better - I don't have to make room for it
I read through your 3 link build a few times when I was trying to figure mine out, thanks for that.
Just found out we have a big hydraulic bender here at work, I'm off to figure out if we have tube dies for it or just pipe.
Old 12-12-2013, 08:18 AM   #21 (permalink)
Member # 50955
Originally Posted by MotoDave View Post
Lower link brackets
Upper link brackets
Upper and lower link mounts mocked up on the frame. These are tacked in now, but I didnít get a decent picture of them.
Your brackets are
Sweet build....however comma with the lowrider stance how far off the ground are the bottom of the LCA mounts?
Instead of bending that 2" DOM how about fabbing some arms desert racer style using flat bar?
And most importantly would ya be interested in renting out or selling that gas cap dimple die?
472Scout is online now   Reply With Quote Quick reply to this message
Old 12-12-2013, 08:49 AM   #22 (permalink)
Perfection in Plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
nice work on the custom parts. looks like this rig will be a solid DD or great trail rig.
i really like the gas cap setup, any chance you want to sell the dimple tool you made?
carslut is offline   Reply With Quote Quick reply to this message
Old 12-12-2013, 10:47 AM   #23 (permalink)
Member # 137726
Originally Posted by 472Scout View Post
Your brackets are
Will have to measure, I think my frame height is around 19", so the brackets are about 3" lower than that.
Fabricating arms is an interesting idea, will have to ponder that. It was pointed out that any bent arm is going to want to rotate unless I have a bushing at one end, so I'll likely try to keep the arms straight.
Honestly the chunk of delrin is pretty expensive, I'm hanging on to it for another day.
Thanks, that's the hope! Still a long way to go, but I feel like its getting close to being a roller again.
Old 12-12-2013, 11:39 AM   #24 (permalink)
Member # 50955
Desert racers mount their shock in the trailing arm with a special bushing to control twist.
Old 12-12-2013, 01:06 PM   #25 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Loving the build, very similar to what I'm going to do with my 62.
How's the height in the rear with the 56" chevies? I only want to run 33's on my scout, and have been considering those springs as a good alternative. I really like keeping them spring under to control axle wrap.
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
