talking heads - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-20-2004, 11:21 PM   #1 (permalink)
Member # 7646
talking heads
no not the band
in school in ~2 weeks we will be doing a head re & re so I thought why dont I grab a pare of 345 heads from a wrecker I go to (about $10.00) and do them for my scout (so I have a good set handy if I need them)
hears the question
how much should I mill off to compensate for the new style gaskets and maybe a small + in comprssion. with out altering the intake mating surface.
also any info for opening up the ehaust port would be grate.
thanks
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II
76 Scoutt II turbo 345 propane
Chief yelling alot is offline   Reply With Quote
Old 01-20-2004, 11:28 PM   #2 (permalink)
Member # 4001
about 2 inches..this will save you about 60 lbs!
Tech related: Seems to me that you could bump the compression up a huge amount on a 345 and maybe, just maybe, get some decent power vs weight out of them. What's the most that has been tried on these?
Dysfunctional Rockcrawlers
Scout Dude is offline   Reply With Quote
Old 01-21-2004, 05:00 AM   #3 (permalink)
Member # 21309
There is a guy here in MT I just talked to last week that mills his heads A LOT (can't recall an exact number, I'll ask again) and runs 9.4:1 or more in a couple of 392s he and his son built. He runs Isky custom-grind cams and says they'll put down some "decent power". He's been running this way for years so I don't see any reason why you couldn't take a pair of $10 heads and experiment.
Darel
Lots of IHs. Lots of other junk. No money.
Darel is offline   Reply With Quote
Old 01-21-2004, 06:17 AM   #4 (permalink)
Mechanos's Avatar
Member # 6704
I say none. Just mill the least amount necessary to true them up. Deck the block to compensate for composite gaskets. I'm not saying you can't mill the heads, I'm just saying that I would rather deck the block.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 01-21-2004, 11:03 AM   #5 (permalink)
Sully's Avatar
Member # 12121
Send a message via MSN to Sully Send a message via Yahoo to Sully
Why deck the block, instead of milling the heads?
Live Free or Die
Why is mankind the only species that attempts to preserve the shallow end of its gene pool?
Sully is offline   Reply With Quote
Old 01-21-2004, 11:40 AM   #6 (permalink)
Mechanos's Avatar
Member # 6704
Greater change in volume per .001" of material removed. .030" off of the block nets a larger volume than .030" off the heads.
It's
IHeavy
aka TORC
KC0UIC
Old 01-21-2004, 01:21 PM   #7 (permalink)
Member # 8920
Zero deck height. Better flame propogation. Gets rid of pinging problems so common on SVs. More power.
I took .040 off my block for zero deck. Took .008 off the heads - just to true them up. Angle cut them to ensure good intake mating. Ended up at 9.3:1 with FM hypueretic (sp?) flattop pistons.
Chief, if your heads have the AIR injection bosses in the exhaust ports (not all do) grind them out and match the port to the manifold or header gasket. Blend in no more than about 3/4" - leave any more than that to experienced porters.
77 Scout II in progress - still
Retired USAF Master Sergeant
scoutver5.7 is offline   Reply With Quote
Old 01-21-2004, 01:40 PM   #8 (permalink)
Member # 7646
well how much should I take off to compensate for the gasket?
looks like to run regular i'll keep the CR the same
there non air injection
Old 01-21-2004, 04:03 PM   #9 (permalink)
Member # 2071
Just to compensate for the gasket? About .020 IIRC.
I decked my 392 .036" which was what it needed to hit 0-deck (with a .035 stroke and topped pistons).
Somewhere over 9:1, and it didn't seem to be a pinger..
DocDan has some great stories to tell, eh, Darel?
I have a 304 that's over 10:1..the pistons come out of the deck.. makes good power.. sure surprises the Chevy powered Jeeps..
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
