Powerglide to BD265 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-10-2004, 12:43 PM   #1 (permalink)
FCwheeler's Avatar
Member # 10674
Send a message via AIM to FCwheeler
Powerglide to BD265
I wont say why I am doing this yet, and i dont think that anyone has done it...
What i need to know is if BD265's are internally or externally ballanced (i dont have the motor here to look at yet), and if externallly, what the balance weight and location (in degrees offset from the dowel pin) is. I am not sure if anyone would know this, but i figured it wouldnt hurt to ask.
Also, if anyone has fabicated a flex plate, what would you reccomend for thickness of plate to cut it from. Will 3/16 be sufficient without the reinforcement that the stamped ribs provide on factory-style flexplates? Also, what type of interference fit is necessary to locate the ring gear onto the flywheel? Any ideas on this are appreciated.
Final plan: BD265/'Glide/NP435/NP205. 109" WB fullsize-based buggy, (mostly just body skin and tube) D70 rear/D60 Front, Cantilever radius arms front and rear, F150 coils (with cantilefer setup, they should flex ok). Low COG. Droop biased shock valving, possibly with forced articulation capabilities.
Expected time of completion: Fall 2004
FCwheeler is offline   Reply With Quote
Old 04-10-2004, 01:27 PM   #2 (permalink)
Member # 7134
Send a message via ICQ to NotQuiteSane
Jump over to BB or JI and talk to Donnelly. he's into the 6's.
NQS
These opinions are [u]mine[/u], [u]mine[/u] I say! Piss off and get your own.
Currently on [url=http://members.ebay.com/ebaymotors/aboutme/nqs%40tigger.tmcom.com/]ebay[/url]: Nothing
[url=http://tigger.tmcom.com/~nqs/blogger.html]As I see it[/url] -- An irregular blog
NotQuiteSane is offline   Reply With Quote
Old 04-10-2004, 06:38 PM   #3 (permalink)
International Dan
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
He's just gonna tell you not to waste your time trying to mate an auto to that engine. He likes the manuals behind the old six bangers.
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html
facebook.com/hardenedways
Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you.
binderbound is offline   Reply With Quote
Old 04-10-2004, 11:38 PM   #4 (permalink)
Member # 7646
well that big 6 will keep yor front wheels on the ground
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II
76 Scoutt II turbo 345 propane
Chief yelling alot is offline   Reply With Quote
Old 04-12-2004, 07:38 AM   #5 (permalink)
Member # 29271
The predominance of the IHC-6's were offered with manual transmissions, but I don't think I would tell anyone "not to waste thier time" trying. I would if we were talking about an SD33 though.
IHC did offer the Borg-Warner auto behind the 6, but not usually behind the BG-265 engine, as most folks who bought the 6-cylinder option with auto chose the BD240 or BG241. The nice thing is you can get the auto stuff usually for nothing from what I am told because nobody wants it.
With regard to FC's question(s).
IHC 6's, at least the "tilt valve"models are internally balanced. I have never seen the flex plate for one of the automatic trans equipped versions, but cannot imagine that they would need a flex plate with a greater thickness than 3/16".
As far as "interference fit" goes, I would use standard machining practice and use .005" undersize, just like a dowel pin hole.
A BG265 is a heavy engine, really heavy. Close to 700lbs, possibly more depending on what it's trimmed out with. Chief is right, you won't have any trouble keeping the front end down
IHC-6 is offline   Reply With Quote
Old 04-12-2004, 08:13 AM   #6 (permalink)
FCwheeler's Avatar
Member # 10674
Thanks, that helps out a lot. I am kind of scared of using the BW auto, though, as i have been unable to find much in the way of rebuild parts or infomation. I was just considering the 'glide cause they are easy to addapt to use different bellhousings. The main reason behind using an auto is to minimixe breakage, and maximize control on the trail. I know that many would consider the weight of the bg-series I-6 excessive for a buggy, but this setup isnt for comp, just trails. I will post more on the project when i actually get something done on it. thanks,
-Ryan
Old 04-12-2004, 08:42 AM   #7 (permalink)
Member # 29271
-Ryan
The reason why you aren't finding a whole lot on the Borg-Warner trans is because you aren't searching with the right name for it.
It is more widely known as the "Ford FMX". Try searching with Google using that name, and see what you find.
Although not a popular choice in transmissions to many, it is quite durable and easy to repair.
I agree that a powerglide would be infinitely adaptable, but a 2-speed automatic isn't what I would choose, especially for a trail rig with a BD/BG motor. Remember, these engines only have 4 main bearings, and don't like any RPM's over 3200 typically.
IHC-6's have a bad habit of throwing rods if overreved, or windowing the cylinder head with a piston periodically. They make gobs of low-end grunt though.
Old 04-13-2004, 08:09 PM   #8 (permalink)
International Dan
Member # 18592
IHC-6, welcom Newb
#4666 build http://www.pirate4x4.com/forum/showthread.php?t=1048195
Old 04-14-2004, 07:08 AM   #9 (permalink)
RustoleumWhite's Avatar
Member # 4506
IHC-6, welcom Newb
bought time he converted to the "dark side"
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote
Old 04-14-2004, 07:37 AM   #10 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
let the sites join as one....
Assimilation is only just beginning....welcome newb.....heeheheee
www.markyoungrocks.com
Harvester of Sorrow is offline   Reply With Quote
Old 04-14-2004, 04:57 PM   #11 (permalink)
Member # 9763
Send a message via AIM to Klasick68
If you can find a BW auto setup, that might be a good way to go, I'd probably look in 2wd halftons, not sure, but they seem to be the most likley to have been ordered with anauto behind a BD/BG. Anyone know what the first gear is?
BTW, 109"wb, + all that shiat = shortass rear shaft, maybe a 420 would be better to back it with for length?
68 1200, 440/727/205, 60F 14B
Klasick68 is offline   Reply With Quote
Old 04-22-2004, 09:19 AM   #12 (permalink)
txs
Member # 1846
3/16" would be way overkill for a flexplate, 426 hemi flexplates are only .110-.112" thick. Most flexplates have an offset front to back to locate the converter into the pump, that might be tricky, I think if you got the od right you could tack the ring gear on, I would use a 1/4" square cross section ring to reinforce the joint between the ring and the flex plate.
txs is offline   Reply With Quote
Old 04-29-2004, 12:13 PM   #13 (permalink)
Member # 15721
I'm curious as to what you're doing about the bell housing? Are you building a spacer/adapter? Regardless, how about modifying the existing flywheel vs fabricating a new flexplate?
Ken
It’s not broken, it just needs to be fixed.
IHWillys is offline   Reply With Quote
