brake line (hard line) size considerations? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-14-2017, 11:37 PM   #1 (permalink)
chris fresh's Avatar
Member # 69678
14 bolt and KP60 with 42's. Using a scout 2 master and booster and getting ready to plumb front to back. Of course braided from the drops to calipers, But trying to decide what hard line size? I'm doing stainless and already have a roll of 3/16 and some how a roll of 5/16,Thought maybe I'de order 1/4 run the same front and rear. Don't remember front being larger for any reason. What say you guy's?
78 SII very healthy 327,th-350,np205,35''boggers
71 800B LT-1,400,203/205,FF14,d-60,42'' rockers on beadlocks
To my great friend rob,RIP buddy we'll never forget you.
chris fresh is offline   Reply With Quote Quick reply to this message
Old 03-19-2017, 10:32 PM   #2 (permalink)
JRC
Member # 24914
I'm running a similar setup 14b/KP Dana 60/40's with discs front and back. Noticed IH put different size lines, but went with 3/16" CuNi for both and seems to work fine. Previous owner put an Astro hydro-boost and master cylinder in which seems to need more pedal travel than i'd like, probably due to the Astro having rear drums and smaller calipers. I might eventually put a master cylinder in from a 2500 to bring it in.
73 Scout II (Shrek) 5.3L/4L60E/Atlas 3.8, D60/14b Deaver leaves, Fox shocks, 40" Toyo MTs
JRC is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 10:07 PM   #3 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
I ran all 3/16" on mine. D60/14B disc/disc with 1970 Corvette MC.
Typically disc brakes run 3/16" and drums run 1/4".
The Cunifer/copper-nickel/CuNi brake line is more expensive, but won't rust, bends and flares easy.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 07:24 AM   #4 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
3/16" stuff on my rig.
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 09:28 AM   #5 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Stainless is a bitch, get a roll of 3/16" CuNi. It's a little spendy but it's better than conventional steel and stainless steel in every way.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 07:04 PM   #6 (permalink)
Member # 69678
Well I ran the 3/16 stainless I had. Ran the front line. I was actually impressed with it. bent and flared easily.Guess if using the right tools,It's not bad. Just need to order another roll to run the back. This is all on my 800 build, which I will update shortly. Made a lot of progress in the last 3 weeks after a LONG time tucked away.
Old 03-21-2017, 07:06 PM   #7 (permalink)
Member # 69678
Is this the stuff with a sort of dark green jacket on it? Protective coating if you will? If so,That's what I used on my 78.
Old 03-21-2017, 07:32 PM   #8 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Are used to work with Russell performance, and I never saw convincing reason to go above 3/16 or #3 hose. More capacity leads to spongeier brakes.
:tank:
Old 03-21-2017, 09:03 PM   #9 (permalink)
guidolyons's Avatar
Member # 56050
No. That's just coated steel. The green coated stuff you get at Oreilly is Edelmann RhinoHide. A 25' roll is about $25.
Cunifer is one common name brand http://www.cunifer.com/
You can get the copper nickel at O'Reilly under the Edelmann Copperhead brand (might Have to order it not all stores carry it in stock) A 25' roll is about $50.
3300CN 25' roll
Pre-flared straight lengths available too.
Cheaper on amazon of course.
Name:  cuni amazon.jpg
Old 03-21-2017, 10:09 PM   #10 (permalink)
total newb's Avatar
Member # 464641
Mostly correcr.
Gms ran 1/4 from prop valve to t on rear axle, t to drum was all 3/16.
Cant say as lto all makes, but ive yet see a light truck or car, disc or drum, with anything other than 3/16 at the brake assembly
My new years res. Everyone that is not me can get fucked.
