Is there a late model vehicle frame that works for a Scout 2? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-19-2017, 06:57 PM   #1 (permalink)
Member # 751481
I looked for a way to search the threads and don't see it... I'm in love with the Scout look, but would love the ride and handle of a late model vehicle. I know u could "force" anything, but do u know if anything that goes easiest???
Thanks in advance.
arkieman is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 07:47 PM   #2 (permalink)
RustoleumWhite's Avatar
Member # 4506
S-10 Blaser, 2-door has the same 100" wheel base and a HUGE aftermarket support, even for the 4wd version.
There are a couple others, but the blaser is the most common. Or you could take just about any mid-sized SUV frame and cut it down to fit. All depends on how much work you want to do.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 07:50 PM   #3 (permalink)
CSmith's Avatar
Member # 31658
If I had deep enough pockets to build a scout the way I wanted a two door JK rubicon chassis would be part of the plan.
CSmith is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 08:16 PM   #4 (permalink)
Member # 751481
Sweet! I know some companies make kits to make the conversions. Who are the respected online Scout merchandisers??
Old 04-20-2017, 10:42 AM   #5 (permalink)
Member # 9835
Anything Scout has built several scouts using a late model wrangler frame and suspension
ChiScouter is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 03:08 PM   #6 (permalink)
Bo185's Avatar
Member # 48545
Just upgrade the suspension. Why swap a whole frame just to get coil springs. Just remove the leaf springs and install X type suspensions. Be quicker easier and cheaper in the end if reusing the stock motor and trans etc.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 05:53 PM   #7 (permalink)
Member # 9835
My .02. Most every Scout I have seen on links sits quite a bit higher than I would like. If you look at the rigs done by Anything Scout they look to be riding at about stock height, or a very mild lift. I don't recall ever seeing a Scout on links riding as low as those rigs. By going to a JK frame you have a world of options for suspension kits and i am sure the frame is worlds stiffer than a Scout frame. With the vast aftermarket support for the JK I would think that one could buy brackets to install Scout or any other axles you might like to choose.
I would be shocked if anyone contemplating a swap to a frame from another vehicle would be looking to keep a 304 and 3 speed auto.
Old 04-20-2017, 06:02 PM   #8 (permalink)
Member # 9835
I have read that brand new JK frames are available for around 1K I did some searching and salvage yard frames seem to be 500 to 750. With you fab skills where would you see the costs getting ugly?
Since seeing the rigs done by Anything Scout I have really been thinking about the benefits in ride and handling by having a factory designed link suspension.
My thoughts revolve around long arms with an Air Rock suspension
Old 04-23-2017, 12:42 PM   #9 (permalink)
Bo185's Avatar
Member # 48545
https://anythingscout.com/pages/outrider-chassis
That's is interesting seen it before but never really looked into it. Plus be a drivers drop and open up WAY more transfer case option's for LS swaps.
Old 04-27-2017, 03:43 PM   #10 (permalink)
Member # 729297
Any idea what they run price-wise???
I've had no regrets...yet
Trail-Hound is offline   Reply With Quote Quick reply to this message
Old 04-27-2017, 09:28 PM   #11 (permalink)
Bo185's Avatar
Member # 48545
I am sure not cheap. Call and find out.
Old 04-27-2017, 10:32 PM   #12 (permalink)
jedrattle's Avatar
Member # 21750
I'm thinking about putting my 80 on a fs bronco chassis. I want to long travel the TTB. I need to measure it to see how it would work out
Team RattleKann
`73 Courier..all Yota underneath
`05 Cummins...tow ho
jedrattle is offline   Reply With Quote Quick reply to this message
Old 04-29-2017, 12:44 AM   #13 (permalink)
Member # 9835
If you are here to contribute why don't you ask them and post up the prices and options here?
Old 05-03-2017, 10:17 AM   #14 (permalink)
Member # 189327
I emailed anything scout to see if they would provide a price range. This is what I got from their parts department.
"Unfortunately, at this point in time we only use the chassis for our inhouse builds. We'll have a couple intense trucks at the Overland Expo West next week if your in the area.
Thanks, "
Potato Head is offline   Reply With Quote Quick reply to this message
Old 05-03-2017, 11:25 AM   #15 (permalink)
Member # 681969
So I was recently reading an article about a guy building a scout. He chose it because its a nice size split between the smaller jeeps and the full size K5 blazer or similar. However in the article he made note that the stock IH frame is very strong and also very wide - making it an ideal candidate for ton axles. So I am not sure the jeep or s10 frames would be wide enough to work on the body.
MaksWerks is offline   Reply With Quote Quick reply to this message
Old 05-03-2017, 12:29 PM   #16 (permalink)
Mechanos's Avatar
Member # 6704
Well, there ya go. If you read it on the internet, it must be true.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 05-03-2017, 06:39 PM   #17 (permalink)
Bo185's Avatar
Member # 48545
Thanks, "
Not that hard to get a roller JK frame. Slide under a SII tub and fab some mounts. I am suprised they don't sell them mounts alone in a kit. Their LS mounts are nice but spendy good for deep pocket guys.
Old 05-04-2017, 05:55 AM   #18 (permalink)
Member # 84699
My, how perceptions change. When I was looking for a chassis for a Willys wagon, I thought the Scout II WAS a modern one. (disc brakes, power steering, Dana 44s with useful ratios, a selection of bulletproof engines, choice of manual or automatic)
0
uglydukwling is offline   Reply With Quote Quick reply to this message
Old 05-04-2017, 09:03 AM   #19 (permalink)
Member # 50955
A JK frame is a lot of hassle for a few link mounts. Much easier to mod the existing frame. Not to mention that the factory frame follows the contour of the Scout body perfectly and with a few mods is plenty robust. If you want more stiffness tie in your cage and add a few cross members.
472Scout is offline   Reply With Quote Quick reply to this message
Old 05-06-2017, 07:03 AM   #20 (permalink)
Member # 9835
I wonder how much uptravel it has and the ride height compared to a linked scout frame. I am not knocking any builds but almost every linked scout is a 1 off experiment and i am sure they all have their quirks. It would seem to me that it would be much easier to dial in the suspension if starting with factory engineered specs.
Has anyone crawled under one in person? I would be interested in how much travel they have and what mods were done to the chassis. From looking at the pics I see one fishplate in the middle of the frame. I would think that the rear of the frame would need to be extended for the scoutII long rear overhang. They seem to be very tight lipped with info on their product. It seems to me like their phone responses contradict the link that BO posted up earlier in the thread.
Old 05-06-2017, 08:23 AM   #21 (permalink)
Bo185's Avatar
Member # 48545
The 2dr JK WB is only 95'' and 4dr 116 (had to look it up). I missed the fish plate I bet they cut a 4dr frame down to 100''. IMO that wouldn't be worth the hassle time wise to have to do that or ext then back. Yeah can be done but just a pain. interesting though.
a 4dr JK wb is almost same as a traveler though.
Based on the pictures looks like front of frame hangs down some and rear appears ext.
Rear of JK frame stock
They won't give out detail on swap as I assume their plan was to sell the rolling chassis but had to do shipping wise which adds expense. Be much easier to just sell conversion kit you can box up and ship. They would sell aot of those kits vs whole chassis. Guess thats why they say inhouse only.
Old 05-08-2017, 12:05 PM   #22 (permalink)
Member # 50955
Chiscouter, If I was building a lifted JK I wouldn't use the stock suspension geometry. A long arm kit gives a better ride and reduces the jacking issues you get with a short arm at extreme angles. JK's also have a lot of junk (brackets) hanging down below the axle. You can see how short JK rear arms are in the picture above. I wonder if they're that steep on a stock jeep.
Bo185, I can't speak for Anything Scout but I suspect that they're targeting the high buck yuppy "Icon Bronco" crowd. Not DIYers.
I doubt I'll ever go down the link road again, but Tahcustomscout's project is really interesting. I like how he's keeping the brackets off the bottom of the frame. Not sure how much work has gone into his geometry though.
Old 05-09-2017, 12:50 PM   #23 (permalink)
Member # 9835
I agree that when going away from stock height the JK arms and geometry leave much to be desired. Then again probably hundreds of thousands of smackeroos have probably been invested in designing, one upping and improving long arm suspensions. Everything from diy brackets to full kits are available from a good number of manufacturers. In somewhat of an old school build it yourself attitude I wish one could buy a bare frame or one with factory brackets that would bolt to a Scout tub. If a new frame is available for around 1k I would think that a company could slice and dice the frame to fit a Scout body, and add body mounts and let the buyer go from there. I would think a pro shop could kick that out in way less than a day and sell at a pretty decent profit.
I wish there was a proven link design for a Scout with good road manors and low ride height that uses the stock frame and doesn't intrude inside the body, but if it is out there i am unaware of it. It is important to me to stress that I am not knocking home builders designs. I wouldn't begin to have the knowledge to try and work out the link lengths and geometry on my own and i salute them on their efforts
Old 05-15-2017, 12:17 PM   #24 (permalink)
Member # 681969
It was in 4Wheel and Off Road magazine I believe.
Old 05-29-2017, 05:22 PM   #25 (permalink)
jedrattle's Avatar
Member # 21750
Why not get the JK's link #'s and duplicate them on to the scout chassis? Can't be that hard. I think the frame kick up is way more than a JK.
Team RattleKann
