304 flywheel on 152 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2004, 02:24 PM   #1 (permalink)
Member # 28845
304 flywheel on 152
304 flywheel on a 152 is it all the same .....balance? thanks
13lettershitspreader is offline   Reply With Quote
Old 05-15-2004, 03:42 PM   #2 (permalink)
Mechanos's Avatar
Member # 6704
Not the same.... the 4-cylinders are externally balanced and the 8-cylinders are internally balanced (or the other way around, can't remember which).
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 05-17-2004, 12:18 AM   #3 (permalink)
Member # 28845
thanks when i set them side by side you could really tell, i just drilled and taped the 196's flywheel to fit my 11" clutch......now thw the only problem is i used stock V8 mounts to put the 4 in and the carb sits kinda slanted to the passenger side hoping to get a wedge plate made so it will sit strait again though.....but i got to say for only being a 4 popper is has a lot more power than any 258 that i ever had in my scout....
Old 05-17-2004, 06:45 AM   #4 (permalink)
Member # 18671
You think thats strong?...Put a whole engine in there and you will really be impressed
no sig
Gen. Nonsense is offline   Reply With Quote
Old 05-17-2004, 07:40 AM   #5 (permalink)
Mechanos's Avatar
Member # 6704
...the only problem is i used stock V8 mounts to put the 4 in and the carb sits kinda slanted to the passenger side...
To my knowledge, there isn't any difference between a V8 mount and L4 mount when comes to the Scout II's. But what do I know........
It's
IHeavy
aka TORC
KC0UIC
Old 05-17-2004, 08:17 AM   #6 (permalink)
RustoleumWhite's Avatar
Member # 4506
you probably useing a manifold from an 80/800 Scout but have your motor set up like a SII.... so you need a Scout II 196 manifold....
If this is the case I'd be happy to trade you a SII 196 manifold for a 80/800 196 manifold.....
if you got a 152... then wedge plate is your best bet.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote
Old 05-17-2004, 09:49 AM   #7 (permalink)
"Official"
Diesel Smoke's Avatar
Member # 27575
We found out you need to knock the big weight off of the V-8 fly wheel to get it to balance. I was really worried about doing it, so my Dad took it to work and but it on a balancing arbor, then knocked the weight off. Almost perfect. I guess I should note, Binderbound was right and I was wrong.....again!
Wheeling?!?!? WTF is that?
Diesel Smoke is online now   Reply With Quote
