Member # 529
Scout box porting questions - Also check balls quesiton - Teflon ring question
1. How many balls total are in the piston/gear assembly of a scout box?
2. When porting, I did the bottom rib and hit a port which is a no brainer. I did it on the side facing the passenger. Like to pic here: (not my pic) http://www.rcrc4x4.com/ProductReview...m/DSC00132.JPG I am in quite a ways for the second port and I am not seeing a port. Do you drill all the way into the housing? 3. Where can I get a teflon ring at? (rebuild Kit)? Last edited by weigellj; 05-23-2004 at 08:55 PM. |
#2 (permalink) | ||
Member # 18671
no sig Last edited by Gen. Nonsense; 05-23-2004 at 09:55 PM. |
#4 (permalink) | |
Member # 6704
2) First off, if this is on a Scout II, then porting the bottom rib on the passenger side puts the port and line headed right out into the engine mount and clearance is really tight. Yes, you want to go all the way into the bore for the spool valve.... the red line in this pic shows the region you need to hit. You can drill into this from anywhere convenient around the circumference of the case. 3) As far as I know, the Teflon o-rings are not available individually... you have to buy either a complete gasket/seal kit or a rebuild kit to get the rings.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
Member # 529
1. Well it looks like I am up the creek then. I have 21 balls. I suppose you need the 22 in order for everything to work right? Will balls out of a GM saginaw box work?
2. Box is going on a cruiser so I should be good to go in both locations for drilling 3. I am heading to the parts store at lunch to check out the rebuild kits. Thanks |
#6 (permalink) | ||
Member # 18671
![]() Quote:
no sig |
#7 (permalink) | ||
Member # 6704
/forum/international-harvester/121913-rebuilding-scout-ii-power-steering-box.html Quote:
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. Last edited by Mechanos; 05-24-2004 at 10:52 AM. |
Member # 529
yeap, I read that thread last nite. I though I got all the balls, that is really the only thing stopping me now. Finding another scout box is going to be diff, but a standard GM is easy enought to come by.
I got a rebuild kit at the parts store waiting for me only 1 size 13/16. How do you tell what size you have 3/4 or 13/16 Where would you meausure the box? It shouldn't matter as far as the teflon rings between the two? Thanks Lee |
#9 (permalink) | |
Member # 6704
The simplest way to tell the two boxes apart is to use an 11/16" 12-point socket. If the socket will fit over the input shaft and engage the splines, then it is a 3/4" input shaft. If the 11/16" 12-pt will not fit over the input shaft, it is 13/16".
#12 (permalink) |
Member # 529
Well I found my my ball, used the rebuilt the kit and put it all back together.
Teflon rings are a pita to get on. Any tricks to those for future reference? I used petrolium and it seemed to work fine, just a real tight fitting. It seems to turn fine to the right and the left as in there is power. Truck is on jack stands. Only thing I did not do is take off the pitman and turn stop to stop. Turning now, I don't get to the stop of my gear box, just the stop of the axle stops. The wheel turns harder to the right than it does the left. Also going to the left, it seems to want to turn on its own from about 1/2 turn from center? Side note, none of my hydro assist is working either, I got a post in general 4x4. I got a feeling I got something screwed up. Possibly air in the system? When I shut the truck off it hiss's? |
#13 (permalink) | |
Member # 6704
It doesn't surprise me that the hydro assist isn't working if the truck in on jackstands. There needs to be resistance on the pitman arm when you're turning the steering wheel to develop enough torque to operate the spool valve. With no resistance, the mechanical part of the box (worm gear) is moving the rack forward which turns the sector shaft, but the hydraulics are really in play yet. If there is resistance to the pitman arms movement, the resulting torque opens the spool valve and allows hydraulic fluid to flow. Unhook the ram from the tie rod/knuckle, etc. and put the truck back down on it's wheels. Then start it and turn the steering wheel all the way to one side, then back the other way. Repeat until you get all the air out of the ram. Then hook it back up and see what you think.
