#2 (permalink) | |
Tactical Turtleneck
Which TF? The IH pattern or the Chrysler one? If it's the IH pattern I don't see why not, as all IH motors had the same bellhousing.
Member # 29450
Aa
AA makes an adapter for both the auto and the manual. The manual wasn't listed on their website(just in case someone cares). And on Urban Wheelers comment, ussually if you post something on the IH forumn you're talking about an IH product.
Member # 1684
The one for a TF comes with spacers for the flex plate and a new flex plate too I think. I think the one for a stick will also need some sort of spacers too.
I would bet they won't interchange.
S.N.O.R.T. |
Don't know about the auto but I'm sure where there's a will, there's a way. The standard, however goes between the IH tranny and a sbc bellhousing. This set up wouldn't work with mine as I had right-hand-drive clutch linkage and wanted to retain the rare IH linkage since it worked and was cheaper than redesigning everything. So I fabbed a 1/2" plate ring with a dual bolt pattern on it and ground off about 1" from the input shaft of the IH T-19. Used a stock chebby pilot bushing, chebby press. plate and Scout disc. Works great!
You never know when you might need to know how to jump out of a perfectly good airplane! |
