Ford (Sterling) 10.25 rear axles? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-15-2004, 07:22 PM   #1 (permalink)
Member # 21309
Just out of curiousity, what is the opinion of these rear ends? My father in law gave me his '95 F250 Powerstroke, and after I wring a few more miles out of it (it's got 225,000 now) I was thinking that rear end (and perhaps the motor) could find its' way into my Traveler. Everyone wants a Dana 60, lots of people have 14 bolts if they don't mind plowing up some mud, but I've heard virtually nothing about the big Ford rears. Even on the Pirate Ford board no one really talks about them much. Are they junk or is it just that the other stuff is so much more readily available? I know you can find popular gearsets and lockers for them, that's not the issue.
Darel
Lots of IHs. Lots of other junk. No money.
Darel is offline   Reply With Quote
Old 06-15-2004, 07:31 PM   #2 (permalink)
Member # 18056
Send a message via AIM to fiend
It's a good rear, 10.25 ring gear, 1.5" axle shafts, 35 spline. Has Arb's for it, a detroit, I think a mini spool also.
fiend is offline   Reply With Quote
Old 06-16-2004, 05:08 PM   #3 (permalink)
Member # 22556
I think the 8-lug pattern is metric
75scoutCo is offline   Reply With Quote
Old 06-16-2004, 06:26 PM   #4 (permalink)
Berd's Avatar
Member # 24846
IIRC the metric lug pattern didn't start until the Super Duty in 1999
Berd is offline   Reply With Quote
Old 06-16-2004, 07:49 PM   #5 (permalink)
Member # 18056
Correct.
Old 06-16-2004, 08:37 PM   #6 (permalink)
Member # 26338
there are a few minor problems with them, like the axle seals some 93 year model axles got the new improved axle seals that stopped the leaking problems, and 94- up got them, the new inproved seals are like 40 bucks a side from ford, and that seems to be the main weak point in them, and sometimes you get a pinion leak i have heard but never experienced it.
78 bronco 460/c-6/sterling 10.25/ 7 in of lift on 38's, with lincoln locker and hydro assist.
95 bronco daily driver
76 wagoneer
47 jeep/willys truck
stx4wheeler460 is offline   Reply With Quote
