Gm axles for soa - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-23-2004, 10:04 AM   #1 (permalink)
Member # 31986
Gm axles for soa
How easy is it to swap blazer or GM axles in a scout 2 for a SOA setup. I have heard that it is a fairly simple swap and that they pretty much just bolt in.
Matt
orangeamcs is offline   Reply With Quote
Old 06-23-2004, 10:12 AM   #2 (permalink)
Member # 2438
holy fawk this place has gone to hell
how bout you pull out a fawkin tape measure and check. Just because this place has gotten soft does not mean you can post dumbass newbie questions that really dont have an answer. Simple for me would probably be a cluster fawk for you. you wanna try again with a specific question?
troutbum is offline   Reply With Quote
Old 06-23-2004, 10:18 AM   #3 (permalink)
Sully's Avatar
Member # 12121
Send a message via MSN to Sully Send a message via Yahoo to Sully
The only problem is going to be clearance against the engine. In order to gain more clearance, you should probably replace the timing chain with an aftermarket unit. See this post for details.
Live Free or Die
Why is mankind the only species that attempts to preserve the shallow end of its gene pool?
Sully is offline   Reply With Quote
Old 06-23-2004, 10:21 AM   #4 (permalink)
Member # 2438
LMAO...
Thanks man I needed that...
Old 06-23-2004, 10:23 AM   #5 (permalink)
Member # 31986
How is this for specific. Is it true that if you replace your blinker fluid with halogen blinker fluid it will fix a sticky piston return spring?
Old 06-23-2004, 10:26 AM   #6 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Hummm didn't see the blinker fluid on your page?:
http://laniganperformance.com/
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
http://www.pirate4x4.com/forum/misc-...e-history.html
Old Scout is offline   Reply With Quote
Old 06-23-2004, 10:39 AM   #7 (permalink)
Member # 31986
thats because its on www.halogenblinkerfluid.com. You can also get neon winshield squirters from those guys also.
Old 06-23-2004, 11:09 AM   #8 (permalink)
International Dan
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
My bowel movements are firmer than this. There is a tiny little button that lots of us use around here, its called...the SEARCH button. Learn to use it well. Now run along and STFU
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html
facebook.com/hardenedways
Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you.
binderbound is offline   Reply With Quote
Old 06-23-2004, 12:12 PM   #9 (permalink)
RustoleumWhite's Avatar
Member # 4506
the comedy is getting worse than the tech... (spelling corrected thanks to trout's ever vigilante spell checking!)
Yes it *can* be a "bolt on" swap... the stock GM perches line up almost perfectly with the SII spring spacing... however there is MUCH MORE to it than that. A simple search will guide you with more info than you can handle... and probably a couple step-by-steps.
1/2 the guys here are running GM front axles.. in one form or another.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote
Old 06-23-2004, 12:21 PM   #10 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Originally Posted by RustoleumWhite
the comedy is getting worce that the tech...
Yes it *can* be a "bolt on" swap... the stock GM perches line up almost perfectly with the SII spring spaceing... however there is MUCH MORE to it than that. A simple search will guide you with more info than you can handle... and probably a couple step-by-steps.
1/2 the guys here are running GM front alxes.. in one form or another.
There not a perfect fit , just close enough to booty fab them in.
BUY MY BOAT
Old 06-23-2004, 12:24 PM   #11 (permalink)
Member # 4506
Hence I said "almost"
then again, I have instaled "stock" axles that required prying and hammering on the springs to get them to drop in.... so.....
Old 06-23-2004, 12:39 PM   #12 (permalink)
Member # 2438
the comedy is getting worce that the spelling...
Old 06-23-2004, 12:47 PM   #13 (permalink)
Member # 13880
Matt
and to think this is probably the most hardcore thread all month...
84runner with tons,r151,duals with 4.7s in the rear, a little tube and some tenderized sheetmetal.
[URL=www.lucky13offroad.com/phpbb2]Lucky13[/URL]
[URL=http://www.bluehost.com/track/Luckyone/text1]CLICK HERE TO SIGN UP FOR BLUEHOST.COM NOW[/URL]
Rockabilly is offline   Reply With Quote
Old 06-23-2004, 03:22 PM   #14 (permalink)
Member # 4506
Originally Posted by troutbum
stuff
there, I fixed it
Old 06-23-2004, 03:30 PM   #15 (permalink)
Member # 2438
thanks chief
Old 06-23-2004, 03:31 PM   #16 (permalink)
Member # 4506
thanks chief
hey, what can I say. Some times I type fast and my spelling is hourable....
Old 06-23-2004, 05:28 PM   #17 (permalink)
Member # 31986
Thaks for the info. Ill use the search button from now on and try not to make an ass out of myself
Old 06-23-2004, 05:42 PM   #18 (permalink)
International Dan
Member # 18592
At least your a quick learner. Most people argue for 45 post before they get pissed and never come back.
Welcom Newb
#4666 build http://www.pirate4x4.com/forum/showthread.php?t=1048195
