i gutted my 66 800. i pulled the rear diff cover off of the D44 and it has a locker of sorts in there. i have no idea what it is. will someone please tell me, and if it is something that is usable can i put it in my chebby front D44? i havent pulled the front cover yet, but im guessing there is nothing in there.
WARNING...following is more bullshitting than tech
oh ya, everything is for sale or free if you come and get it. i have the 266 v8, the t90 tranny, the twin stick xcase (rear is centered) and both the front and rear axles for sale. i may steel that locker or LS or whatever it is outta there though. axles have 3.55 gears in there and are in good shape. everything else is shot to hell, except maybe the xcase. im not sure.
im really looking for a running 350 with the clutch still attached, i need both together.
PM for Qs about the parts. they are in southern oregon.
Sully's right. They typically came with Power-Loks and you can use them in a newer conventional 44 you just need to replace the side gears from the old course spline to the fine spline. You prolly want to replace the clutch packs anyway so buy a master rebuild kit from Spicer.
You can get 30 spline side gears for the model 44 powr lok. I'd do that along with maybe some new clutch packs and use it in the front. Not as good as a locker, but I'm cheap :flipoff2:
I have a d-18 I could pull the levers off of, so there. :flipoff2: Get 30 spline side gears and new clutch packs for the powr-lok and put it in front, it should last a long time since you won't be driving on it all the time.
otherwise, if someone wants the D20 then ill run down and get some sticks for it and ill sell it to you, otherwise its worth about as much as the metal recyclers will give me for it. i have no use for it and its just taking up space.
as for getting 30 spine side gears and new clutch packs. where could i get these? im not looking to spend a lot on this thing, if it costs too much i may just weld the spiders in the current diff and call it good.
Callen
**does anyone know how long a 350/465/205 combo is? minus fan if at all possible, thanks**
