Show off your IH
Since I don't see a post here and the latest posts have brought out some purty rigs how about a thread dedicated to "rides"
I'll start but it isn't purty.. 1963 Scout 80, currently all stock awaiting restoration and build up. Here is what it will get: Engine/Cooling/Exhaust/Fuel System - HO 5.0 w/Northern aluminum radiator and spal electric fan, modified HO headers, mustang in-tank fuel pump in the toy EFI tank Engine has Saginaw steering pump, 180 amp 3G alternator, BBK air intake kit, FlowKooler hi-flow water pump, stainless rad hoses, Competition Cams Timing set, ARP bolts and studs, etc.. Drivetrain/Clutch - NP435/dual 23 spline toy tcases, TLC slave & MC Suspension - front: wagoneer 44044 springs and 9012's, rear: wagonner springs and 5012's Axles/Brakes - Front HP HD 44 w/6 lug outers and lock right, Rear disk (with ebrake calipers) 35 spline moser shafted HD D60 Interior - custom dash with autometer gauges. Steering - hi-steer with GM stuff and toy IFS box. Wheels/Tires - 15x10" mags with 37" MTR's. ![]() http://www.rivercityrockcrawlers.com...albums/Scout80 Some interesting stuff.. - the body width is the exact same as my toyota - 66" - length is approximately a foot shorter, actually as much as two depending on how I build the bumpers and my truck was shortened A LOT - when I took off the bed - It is a 63, not too interesting till ya hear my jeep was a 53. Our bug is a 73, my truck is an 83, and my ZJ is a... 93
This Space for rent! |
Member # 31414
when i first got it....
73 Scout II I-6 258ci, T-18, Dana 20 4" Rough Country lift springs F/R Dana 44 4.27 r&p open 33x12.5-15 BFG MT's ![]() 6 months ago before current build-up started... LT1 350ci, 700R4, Dana 300 twin stick same suspension, tires and axles kustom front and rear bumpers warn 8000 on a kustom draw tight mount ![]() currently... undergoing an SOA, high steer, "lockers", and misc other mods give me about a week to finish her up and ill post the finished product up. |
Member # 31228
Nice work LT1Scout!! Ill take somepics of mine tommorow in the day light. It could be the little brother to yours. My yellow is a little brighter I belive. You'rs is almost "school bus" yellow isnt it?
'68 scout 800, TPI 383/700r4 D44's '66 K20 383/400/205 60/14 '62 nova 406/th350. 11.40's @ 118 |
IH Parts for America
Here's mine. Before the paint job and after. Also a pic of my current project.
________ Harmed by nexium Last edited by ihojeff; 12-19-2004 at 10:09 AM. |
Member # 31414
yes it is. as a matter of fact a school bus pulled up to me at a red light one day and looking down i couldnt tell where the top of my door stopped and where the school bus started.
i wish your scouts "big brother" was stroked also. i almost did it this summer while i had the engine out. |
"All Whee Drive!"
Member # 6450
My 62 when I got it:
SBC350, Muncie 4 speed (M21) & D20. SOA D27s Sitting for 20 years. Now: SBC350, SM465, D18 Waggy 44s front & rear: Detroit & Spool, Discs x4. YJ 2" or 4" springs (forget) 35" Pro-Comps 32 Gallon Fuel Cell Auto-meter Gauges Herculined cab & Bed Custom Cage Toyota MR2 Seats Centech Wiring Kit Soft-Top Custom Camo Paint (Green, Primer Grey, & Primer Brown )![]() (this was before the cage & more painting). |
Member # 25311
Before...
![]() After... ![]() I'm getting ready to swap in a v-8, dovetail the rear. Cut my doors like SSII doors and boatside it. Maybe get some 40's
You son of a biscuit eating bulldog! |
Member # 20423
My 76
before. This is the one that started it all for me and IH! on 31's After. Now I have my 75 and the son joined the Navy and took my 76 with him to WA! on 33's On 35's and on 37's That about covers it.
Bill USN-1 EFI Moderator at http://www.binderplanet.com |
Member # 7646
My daly driver 1978 345/727 dana 20 AC,PS,PB,tilt
![]() my pickup all stock 304 T98 202 44sF/R ![]()
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II 76 Scoutt II turbo 345 propane |
#12 (permalink) |
Mine when I got it. Its stripped now, ready for the LT1 and the 60 front and 70 rear.
2007 Wrangler Rubicon JK on 37" Toyo MT's, 5.38's, 4.5" Spynergy with Clayton Arms, Racelines, Atlas 5.0, Clayton Skids, Alloy shafts, Reid knuckles, Rescue Green with Half Doors |
#13 (permalink) |
Member # 31228
bill usn-1: Thats a bitchin rig! nice work!
Mochamike: Im not a fan of fender trimming but you did an excelent job and it looks great! Jason861: you park like I do..
#15 (permalink) | |
Member # 20423
Which one. I like both of them!! And they only get better!
#16 (permalink) | |
Member # 31228
I think I like the purple one the best but they're both sweet! Here's mine. I dont have much time and I'm working on a college students budget but its coming along. The 383. I pulled apart the TPI intake to install the adjustable regulator. Otherwise the intake/runners/plenum/rail was bought brand new in 1986 and never used. A buddy of mine gave it to me. it has been up in the rafters of his garage since '86. This is just a shot of my front shock setup. you cant see it but I built shocks for dual shocks on each side. I've still got a lot of wiring to do, get some drive shafts made and finish up the motor. Heres whats done so far 383 w/ hydraulic roller cam 10.0:1 flat tops, S/R torquers with 2.02/1.60's Comp roller rockers Affordable Fuel Injection computer/wiring harness *if it helps anybody whos doing an SBC swap, the headers are from a 2wd 70's chevy pickup and are hooker comps. They fit great the way I have mine setup. I had to heat and move the pass side collector out a little to clear the front driveshaft but other than that, they fit and are a good set of long tubes to use. th700r4 with all the beefiest parts I could find for it. NP208-- When I blow it up Ill get a Dana 300 I think and advance-adapter-it in there. F/R dana 44's SOA with 4.88's and lockers. Front is cut and turned with castor added. Rear is buggy leaf with traction bars. The leaf springs are re-arched scout II and I hate them because they are STIFF! I'll either pull a leaf out of them or go to a 44044 or something The SOA destroyes any thought of decent steering geometry what-so-ever so Im on the lookout for some flat tops for a highsteer swap.
'68 scout 800, TPI 383/700r4 D44's '66 K20 383/400/205 60/14 '62 nova 406/th350. 11.40's @ 118 Last edited by Buckshot33; 12-19-2004 at 01:54 PM. |
#17 (permalink) |
Member # 6704
When I first got it:
What it looks like now:
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
#18 (permalink) |
Dads
http://www.ofoto.com/BrowsePhotos.js...1&sort_order=0 Mine http://www.ofoto.com/BrowsePhotos.js...1&sort_order=0 havent had time to load before and after pics, and the death fangs are going once i get time to install the new springs ive got |
#19 (permalink) | |
Member # 20423
Better get another job so you can finish that thing!! Sleep when your dead!!
#20 (permalink) |
Registurd Abuser
Member # 34995
My 800B
Before
[IMG] [/IMG] After [IMG] [/IMG] Still got a long way to go. Damn bills anyhow
'71 800b, 305 Vortec, 4L60e/241d/241c 60, 14, 37's |
#22 (permalink) |
Member # 32759
A couple pics of mine. Mine is nowhere near as pretty as the rest of yours, but I wheel mine hard. One pics is just me posing on the edge of the forklift but I had 32" of air under the rear tire.
Here's the spec's '80 Terra 392 .30 over comp rv cam and valve springs 76 1/2 F250 knuckles out on Scout 44 tube w/ hi steer (thanks Casey) Moser short side/Yukon long side stock stubs OX joints IH D60 FF rear narrowed to Scout width w/ Moser axles 4.88's detroits f/r T-19 wide D20 Granite Motorsports roll cage 5 points w/ Corbeau baja's 35" Geolanders (soon to be 36" Iroks) To-do list: Lower gears possibly dual transfer cases but at least Jack Obrien 3.6:1 Different outers- tired of oddball brakes and axle shafts sidearm lockbox possibly bob the rear hydro assist rear shocks Maybe someday I'll post some good pics of wheelin' instead of my poser crap. KZ |
#23 (permalink) |
Registurd Abuser
Member # 34995
LT1scout
not on dial up....dont know why they are so friggin huge. did not mean it to be that way.
#24 (permalink) | |
Member # 31414
because they're 1200x1600. google for a program called irfanview. its free and easy to use. once installed go to image, then resize/resample, make it 600x___ or so. then it wont fook up the whole thread. |
