Possible Scout buy - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-19-2005, 09:34 PM   #1 (permalink)
chris408's Avatar
Member # 37354
Possible Scout buy
Hi, I read carefully through many websites and pages on this forum, but havnt really found answers to my questions.
1) How well does a stock 1976 Scout Terra articulate? I have read that they are setup with leaf under the axles, and I wouldnt want to do SOA, because I dont want my truck that high. So lifting options would probably be limited to shackles...are these shunned upon in the IH community?
2) Are there any weak points into looking at when buying a 76 scout? So far the owner has told me it has D44 front and rear, and a detroit locker on the rear. It has a 345ci motor and he put a 500CFM holley carb. T-19a manual 4spd. He mentioned a crack in the steering box, so it leaks a little power steering fluid. How hard will it be to find a new steering box for this truck? How reliable is the 345, and is it a GM motor?
Sorry for newb questions, but I did search pirate and google, mostly just found HP numbers on the motor. It seems to have great low end TQ. Thanks!
chris408 is offline   Reply With Quote
Old 02-20-2005, 05:18 AM   #2 (permalink)
justscoutin's Avatar
Member # 32053
the binder bulletin or justinternationals would probably find better answers to your questions, but as far as lift, you can buy some new springs that lift it 2 inches. longer shackles in the front tend to make it wander all over the road.
88 chevy crewcab 6bt nv4500
72 scout 4bt on tons
justscoutin is offline   Reply With Quote
Old 02-20-2005, 06:41 AM   #3 (permalink)
chris408's Avatar
Member # 37354
I was told lift springs make for a crappy ride, and they dont flex well at all...I guess the only option would be SOA?
Old 02-20-2005, 10:21 AM   #4 (permalink)
Member # 10807
345 is IH...that should have came up in your searching.
do you want flexable trail rig? is so SOA is it...not that hard and you can run 33's or 35's.
sprung under is better than stock but still wont' articulate good...your ride would probably be a little stiffer on the road...might be better.
snoop dogg is offline   Reply With Quote
Old 02-23-2005, 08:30 AM   #5 (permalink)
Sully's Avatar
Member # 12121
Send a message via MSN to Sully Send a message via Yahoo to Sully
Depends on your point of reference.
A set of used lift springs actually improved my ride a great deal, because my stock springs were shot to shit.
Live Free or Die
Why is mankind the only species that attempts to preserve the shallow end of its gene pool?
Sully is offline   Reply With Quote
Old 02-23-2005, 09:16 AM   #6 (permalink)
Member # 20057
depends. quality springs by someone like alcan will ride great. You can stay SUA up to about 4". Any taller and you start having problems with bending main leafs and generally crappy flex.
Based on what you've said, get some quality 2.5" lift springs and maybe some shackles that are 1" longer than stock (assuming rear shackles are not inverted, I'm not up on the 'newer' IH models).
- Rob
robselina is offline   Reply With Quote
Old 02-23-2005, 09:18 AM   #7 (permalink)
Member # 20057
oh yea, I 'think' that's a saginaw steering box, which should make it easy to replace since it's under almost every damn jeep made from the 70s and up
- Rob
Old 02-24-2005, 05:30 AM   #8 (permalink)
Tactical Turtleneck
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
Nope, they are set up like the 80/800s.
Yes it is a Saginaw box, but since there are many different versions you'd probably want to buy a used one.
As for weak points, the bodies tend to rust bad and the wiring isn't exactly the greatest. The 345 is a strong motor, and although heavy, will go for several hundred thousand miles. One thing to watch for is the cam bearings tend to come apart. Oh, and the standard alternator is only 37 amps, 67 amp alt is optional.
Urban Wheeler is offline   Reply With Quote
