Vin - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2005, 01:27 PM   #1 (permalink)
Member # 48599
Send a message via Yahoo to djm1558
Vin
I'm having a problem finding the vin on this 71 800. Any ideas where to look?
djm1558 is offline   Reply With Quote
Old 06-30-2005, 01:33 PM   #2 (permalink)
CSmith's Avatar
Member # 31658
On the vin plate on the firewall.
CSmith is offline   Reply With Quote
Old 06-30-2005, 03:19 PM   #3 (permalink)
Member # 48205
Someone might have taken the VIN plate off. My '63 didn't have it on the firewall, but I eventually found it inside under a bunch of shit. My '64 had it, but it was pretty oxidized or something, so it was hard to read. Check all over inside, maybe someone took it off and put it somewhere else.
Jake.
2xScout80 is offline   Reply With Quote
Old 06-30-2005, 04:30 PM   #4 (permalink)
Ledfndr's Avatar
Member # 45526
Send a message via AIM to Ledfndr
check on your engine or under the cowl
73' 76' Scouts
Ledfndr is offline   Reply With Quote
Old 06-30-2005, 04:32 PM   #5 (permalink)
CSmith's Avatar
Member # 31658
Look on your title and/or registration.
Old 06-30-2005, 10:16 PM   #6 (permalink)
Member # 48599
I have no response to that even though I had to laugh
Although I'd like to thank eveyone else for their constructive responses...
California DM...F'n V has a dim view of none vin plated vehicles.
Old 07-01-2005, 01:17 AM   #7 (permalink)
Web Wheeler For Hire
Eagle-Mark's Avatar
Member # 26999
Every 80 800 I've seen has a vin plate on the firewall above the master cylinder. Do you see four holes there?
Addicted and Obsessed with Fuel Injecting Anything!
GearHead-EFI.com
Eagle-Mark is offline   Reply With Quote
Old 07-01-2005, 03:55 AM   #8 (permalink)
61scout80's Avatar
Member # 16722
isn't it stamped into the frame on the front? i thought i seen something like that on the BB a while back....
61scout80 is offline   Reply With Quote
Old 07-01-2005, 05:36 AM   #9 (permalink)
Ronnie Scout's Avatar
Member # 18942
Door
For a '71 800B, VIN plate should be on the door frame, near the latch assembly, attached with screws. Should also have a VIN sticker on the tub-side of the door frame, approx opposite of the tag. Last digits of VIN should also be stamped into the frame, in front of the steering box on outside of frame.
This may apply to 1969/70 800A models also, I don't know when they switched from the under-the-hood location.
Ronnie
Ronnie Scout is offline   Reply With Quote
Old 07-01-2005, 10:53 AM   #10 (permalink)
Member # 48599
Thanks, Found it!
Old 07-01-2005, 11:01 AM   #11 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
yep, clearest place is there..
This Space for rent!
Brandon is offline   Reply With Quote
Old 07-01-2005, 11:27 AM   #12 (permalink)
"Official"
Diesel Smoke's Avatar
Member # 27575
Until you convert to power steering and weld a big plate over it
Wheeling?!?!? WTF is that?
Diesel Smoke is offline   Reply With Quote
