steering & sway problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-12-2005, 09:19 AM   #1 (permalink)
Docfranco's Avatar
Member # 33649
I have a 1980 Scout 2 with a parts mike high steer setup, running deaver springs all around and SOA. I still have the flat spring sway bar between the shackles, which helps some. But i have some issues when i hit dips or bumps, the front wheels seem to pull to the right then back. I also have a lot of sway around corners. I am thinking of some rockequipment sway bars front and rear to help with the handling.
I realize its all a compromise to find the flex, decent ride and some stability. Anyone else find a good compromise that works?
Docfranco is offline   Reply With Quote
Old 07-12-2005, 12:17 PM   #2 (permalink)
Member # 32314
That sounds like bump steer? What are "deaver" springs? are they lift springs?
I assume you went Partsmike all the way? (knuckles, super arms, tie rod and drag-link)
I just finished my junk - cut and turn, stock springs, parts mike knuckles, superarms, drag and tie, bilstein long travel w/ f250 towers, no sway bar - drives AWESOME.
c r a c k e r is offline   Reply With Quote
Old 07-12-2005, 01:29 PM   #3 (permalink)
IH Parts for America
ihojeff's Avatar
Member # 21419
Sounds like you have bumpsteer but with a hysteer setup you should be fine. Are you sure the steering box isn't off center? What I mean by this is when the front tires are pointing straight ahead is the pitman arm also straight ahead or off to the right some? If its off to the right adjust the draglink so the pitarm is pointing straight forward then readjust your steering wheel.
I've personally seen rock equipments swaybars. Have yet to try out a set but will someday.
Deaver is a company in socal that build custom leaf packs.
________
How to roll a blunt
ihojeff is offline   Reply With Quote
Old 07-12-2005, 01:53 PM   #4 (permalink)
Docfranco's Avatar
Member # 33649
The deavers are 3 in lift springs custom made and are an 11 spring pack, great flex but i think that is where part of my problem is. I did go with parts mike knuckels arms ect. I do still need to get a shorter pitman arm to match the length of the steering arms, but i dont think that should be part of what is going on. Maybe I am expecting to much...
Old 07-12-2005, 03:44 PM   #5 (permalink)
RustoleumWhite's Avatar
Member # 4506
With lift spring on top of a SOA, even with high-steer the draglink *typically* is still at an angle. Hence you will get a degree of bumpsteer, probably roughly equivalent to that of a 4" spring lift SUA.
With soft springs it might just be accented do to bodyroll ect.
Stiffer shocks might help, but sway bars would be cool. A "steering stabilizer" would help mask the bump steer but slowing the reaction of the steering when you hit a bump..
maybe a cheap "fix" to make it more tolerable.
just my thought off the top of my head.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote
Old 07-12-2005, 04:25 PM   #6 (permalink)
Docfranco's Avatar
Member # 33649
I am running Edelbrock IAS shocks which seem pretty stiff. I guess i will look into getting a set of sway bars for both ends and see how that helps.
Old 07-13-2005, 12:17 PM   #7 (permalink)
Member # 32314
I have a brand new steering stabilizer that I put on last friday (rancho set) - I found that I don't quite have enough clearance for it at full stuff, so I might be able to sell to you at discount if you are interested.
I'll try removing it soon to be sure I want to run without.
PM me if interested
Old 07-13-2005, 05:01 PM   #8 (permalink)
Docfranco's Avatar
Member # 33649
Thanks, but i am leaning towards doing a hydro assist to help my steering out. I think that will accomplish some dampening effect...
