newb question 304 vs 345 vs 392 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2005, 08:11 PM   #1 (permalink)
Member # 53048
**binderbulletin isnt working for me right now** ive searched quite a bit but i cant figure out what the difference is between the international v-8s. does the 304 have the same block as the 345, just different stroke/bore? and where does the 392 fit in. can i get these cubes from a 304 motor by using a 392 or 345 crank and boring it out?
BTW, im looking at buying a 77 scout its got the 304 im pretty sure and a 727 auto. front and rear d44s. me and my dad are going to crank it up tomarrow and talk prices w/ the owner
thanks, jake
1999 ram 2500 cummins d25 coils, 2"spacer, 37s.
work in progress--1978 cj5 258/t-18/d20
dirty_dodge is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 08:18 PM   #2 (permalink)
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
It isn't working for anyone right now.
same bore, different block, different stroke.
It's bigger than a 345 or 304
No. Keep trying the BB, and look in the FAQ for a list of interchangable parts. The block of a 304 has a shorter deck height than the 345/392 block.
thanks, jake
Well, when you get it figure out what you are going to do with it and post up.
[QUOTE=Proeliator;13948509]
Also, instead of mounting the nitrous bottle between the seats, I'd install a cheese toaster.[/QUOTE]
Urban Wheeler is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 08:22 PM   #3 (permalink)
Member # 53048
so what your saying is, the 345 and 392 are the same blocks but the 304 is different...that kinda sucks. im sure a 304 is stout enough to be built up to have some decent hp and tq though.....right..?
Old 10-24-2005, 10:05 PM   #4 (permalink)
Member # 40702
Keep this one around. We need a grasshopper!
TheCopperCowboy is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 10:35 PM   #5 (permalink)
RustoleumWhite's Avatar
Member # 4506
All three blocks are different, and can not be realisticaly turning into any of the others.
They are stout and good for most needs in stock(ish) form. You can add a certain amount of hi-po parts if you really want to build it.
If the 304 works, leave it for now. If it needs to be replaced, unless you go with some other brand, look for a 345, the extra "seat of the pants" power is noticable. A 392 could be swapped in as well, and if you find one why not, but it is not *required*.
Like UW said... get it and figure it out, then figure out what you want to do with it and post back.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 10:39 PM   #6 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
@ 700lbs it's a overweight pig.
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 10:46 PM   #7 (permalink)
Member # 4881
The IH SV engines (266, 304, 345, 392) are a family of truck engines that were designed for high torque low reving engines. Heavy suckers too. A 304 is about 700 lbs. They can be made to rev higher but to what end?
These engines are built to run 200+K miles easy if you take decent care of them. My 345 has about 180K on it and it is still going strong.
The folks that race IH rigs often run built up 304's. I have a buddy with a '79 304/727 w/ 4.10's and it is one capable rig in mud.
You will be surprised how much torque a 304/727 can put out. My oldest has a '75 SII 304/727 w/ 3.07's even and he twisted a stock rear drive shaft with it. Had to drive home in FWD.
What do you plan on using the SII for?
DougS is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 10:46 PM   #8 (permalink)
chris408's Avatar
Member # 37354
this page might help you out...
http://www.binderbulletin.org/faq/7.htm
[COLOR="Red"][B]The time is near at hand which must determine whether Americans are to be free men or slaves.[/B][/COLOR]
George Washington
[COLOR="Red"][B]Americans have the right and advantage of being armed-unlike the citizens of other countries whose governments are afraid to trust the people with arms[/B].[/COLOR]
James Madison
chris408 is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 11:21 PM   #9 (permalink)
BLK Scout 800's Avatar
Member # 29630
Send a message via MSN to BLK Scout 800 Send a message via Yahoo to BLK Scout 800
For most of us that play in the rocks 225+lbs off the nose from a sb chevy is always
The 304 is on its own when it comes to performance and the 345/392 have an ok following. I hear you can put 345 heads on a 392 (or is it the other way?) :scratching head: and get power their
"Truth is, everybody is going to hurt you; you just gotta find the ones worth suffering for." -Bob Marley
BLK Scout 800 is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 11:21 PM   #10 (permalink)
R290's Avatar
Member # 46467
A little tip, when youíre looking at the engine from the driverís side. Look at the base of the carb and locate the throttle return spring, the spring will be attached to metal tab. You will most likely have to rub it to see the engine size. It's a lot easy to look here then the on the other side of the block near the motor mount for the engine size stamp.
These engines have a lot of low end power, but they are not a GM350. They are heavy duty truck engines.
R290 is offline   Reply With Quote Quick reply to this message
Old 10-25-2005, 12:36 AM   #11 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
But some of use would never think of chebby power and go mopar!
BUY MY BOAT
Old 10-25-2005, 12:44 AM   #12 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
I see the BS BB line has made it's appearance.
It's been discussed here at great length here before.
A 345 only produces 5 ft lbs more torque than a ford/chevy/dodge of 5.xx Liter displacement. It tips the scales at over 200 lbs more so it actually makes far less power.
BUY MY BOAT
Old 10-25-2005, 04:13 AM   #13 (permalink)
Member # 26369
Well, what I meant was that they are the same in that they share the same deck height and intakes. The bore is different, something like 0.125 bigger.
Old 10-25-2005, 11:52 AM   #14 (permalink)
R290's Avatar
Member # 46467
Sooo, when it's all said and done, the IH 345 is the same as the other big 3, except they have 225 more pounds of steel. Thats some serious (BEEF)
Old 10-25-2005, 02:03 PM   #15 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
BUY MY BOAT
Old 10-25-2005, 02:43 PM   #16 (permalink)
Member # 26369
How about a view from another angle? The IH motor is in the way!
Old 10-25-2005, 04:42 PM   #17 (permalink)
Member # 2071
..with a deep skirt high-nickel block, forged crank and rods, etc.
The short history.
304 is a bored 266. SIMILAR block, but different.
345 is a stroked 304. Taller deck. Again, SIMILAR, but DIFFERENT.
392 is a bored 345. Block was cast with the bigger bore in mind. SIMILAR, but DIFFERENT.
You certainly can't make a 304 into a 392, since even if you could punch it out (going from a 3 7/8" piston to 4 1/8" is a LOT of overbore!) and/or drysleeve it, you'll have a hard time adding to the deck height to get the stroke to fit.
304 can be a very snappy engine, but it's still a heavy pig as everyone else mentions... and for the weight, my 392 makes more power.
If I were smarter, I'd toss my 304 aside and put in a built 401.. still pretty "correct" for the chassis, but lighter.
But while I like to think I'm pretty smart, the stubborn seems to be winning.. so I run a 304.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote Quick reply to this message
Old 10-25-2005, 06:01 PM   #18 (permalink)
Binder's Avatar
Member # 1684
Their all three variations of the same boat anchor.
S.N.O.R.T.
Binder is offline   Reply With Quote Quick reply to this message
Old 10-25-2005, 07:01 PM   #19 (permalink)
Member # 13578
Well that makes my boat anchor way over priced.
IH SV vs. chev, ford, mopar argument would have to one of the biggest waist of time sine whatís the best color
Eric
If it on my scout Iíve fix it or replaced it at least once.
Doh !!!
"Its (scout) four-wheel-drive capabilities are equal to anything this side of full tracks"
eric knutsen is offline   Reply With Quote Quick reply to this message
Old 10-25-2005, 07:07 PM   #20 (permalink)
Member # 53048
your talking about an AMC motor, right?
btw, if i get the scout i will use it as an all around trail rig. no type of terrain inparticular. although we do have a lot of pavement around here, thats what the jeeps for
Old 10-25-2005, 10:04 PM   #21 (permalink)
Member # 2071
Yessir, AMC 401.. aka the "IH" V-400 as installed in the Light Trucks. IH only put the 232/258 I-6 in the Scouts (800 and II), but they used the 401 in the T'all and pickup.
Technically, they never put the 392 in a Scout, but the 152/196/266/304/345 found their home.. so a 401 is almost as "correct" as a 392 swap. ("Correct" in this case just means I can argue it's use for purposes of making a racing class that prevents "non-OE" engine swaps)
-Tom
KE7VUX
Old 10-25-2005, 10:12 PM   #22 (permalink)
Rock Tractor's Avatar
Member # 11635
I'v seen a few trucks with a 258.
KJ6FOR
Dysfunctional RockCrawlers
Rock Tractor is offline   Reply With Quote Quick reply to this message
Old 10-26-2005, 08:03 PM   #23 (permalink)
Member # 53048
heres anothing newbie question. so are you saying a 401 amc will bolt up to the 727 in the scout? that would mean that all amc bellhousings are the same as IH v-8 bellhousings
Old 10-26-2005, 08:29 PM   #24 (permalink)
Mechanos's Avatar
Member # 6704
No. There were two different tranny cases.... one with the IH pattern and another with the AMC pattern.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 10-26-2005, 09:42 PM   #25 (permalink)
Member # 13578
The RangeRover V8 should bolt in. To the auto anyway.
Eric
Doh !!!
