IH 727TF to Ford NP205....? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-03-2006, 02:02 PM   #1 (permalink)
Member # 11594
Send a message via AIM to slipscomb Send a message via MSN to slipscomb Send a message via Yahoo to slipscomb
Has anyone ever tried or successfully mounted a Ford 205 t-case behind the Scout 727 auto? I'm swapping in a Ford High Pinion 60 and going with 39.5 Boggers so I am going to need to upgrade from the Dana 20. From what I gather, Advance Adapters has discontinued the Atlas for the Scout (Texas style mounting).
Sean
You never know when you might need to know how to jump out of a perfectly good airplane!
slipscomb is offline   Reply With Quote Quick reply to this message
Old 01-03-2006, 02:11 PM   #2 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Why not just build a IH/jeep-dodge TF727 hybrid and get the Atlas?
Have you asked STAK about a Texas pattern 3 spd case?
http://www.stak4x4.com/
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 01-03-2006, 02:51 PM   #3 (permalink)
SSGTWC's Avatar
Member # 10775
Send a message via Yahoo to SSGTWC
Sean
I take it you're talking about a married 205?
[QUOTE=CAMO;4]
[B]
build what ya can with what you have and plan on redoing it a few dozen times as you learn the required skills
[/B][/QUOTE]
Never, underestimate the amount of stupidity in people!
SSGTWC is offline   Reply With Quote Quick reply to this message
Old 01-03-2006, 03:22 PM   #4 (permalink)
BAMF
Munchies's Avatar
Member # 42606
Jeep 300 bits to a doubler setup? Not tooo bad
Munchies is offline   Reply With Quote Quick reply to this message
Old 01-03-2006, 04:22 PM   #5 (permalink)
Binder's Avatar
Member # 1684
IH 727 to Ford 205? First you would want to change the 727 output to the jeep one mentioned above. Then you would have the right pattern but wrong clocking so you now need a clocking ring. Then you have a 23 spline female to a 31 spline male. Don't know how you can make that work short of a custom shaft or input gear so I would just drop the 205 and get a atlas to fit the Jeep 727.
S.N.O.R.T.
Binder is offline   Reply With Quote Quick reply to this message
Old 01-04-2006, 01:36 AM   #6 (permalink)
Member # 11594
The problem I'm having is that the IH 727 case seems to have the Texas style bolt pattern molded right into the housing. I prolly could get the output shaft in but wouldnt have the round bolt pattern. And Staks is just out of the budget.
Sean
Old 01-04-2006, 01:40 AM   #7 (permalink)
Member # 11594
Same problem as I described above......changing the output doesnt change the bolt pattern on the housing. The Jeep Atlas wont bolt to the Texas style bolt pattern. I thought about using a Dodge output FOR a 205 and making my own adapter from the Texas style bolt pattern to the round Ford pattern and using a dodge 205 input in the Ford 205 case. This perhaps my best option?
Sean
Old 01-04-2006, 05:11 AM   #8 (permalink)
justscoutin's Avatar
Member # 32053
you need an output shaft and adapter from a jeep or dodge 727, then you need a dodge 205 input. should bolt it all together then.
88 chevy crewcab 6bt nv4500
72 scout 4bt on tons
justscoutin is offline   Reply With Quote Quick reply to this message
Old 01-04-2006, 11:06 AM   #9 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Sean
727 hybrids 101.
The 727 is a two piece case and you can build many different combos by swapping the front housing and the rear housing. There all compatible! Each rear housing has it own corresponding output shaft, so a complete tear down and rebuild is required.
So you have:
Front housings:
BB Chrysler
SB Chrysler
Jeep
IH SV
Land Rover V8 ( factory built adapter for IH pattern bell housing)
Outputs:
IH Texas pattern
Jeep round pattern 23 spline
Dodge round pattern 23 spline
Land Rover LT231
BUY MY BOAT
Old 01-04-2006, 02:39 PM   #10 (permalink)
Member # 2071
727 hybrids 101.
So you have:
Front housings:
BB Chrysler
SB Chrysler
Jeep
IH SV
Outputs:
IH Texas pattern
Land Rover LT231
What does the front of the SD33 727 look like? Is it an SAE pattern, or something entirely different?
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote Quick reply to this message
Old 01-04-2006, 02:44 PM   #11 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
IIRC the SD33/727 was a BB mopar bellhousing with a adapter to the SAE #4.
BUY MY BOAT
Old 01-04-2006, 02:46 PM   #12 (permalink)
"Official"
Diesel Smoke's Avatar
Member # 27575
If I remember correctly it is a SB Chrysler (whatever the 400 is). I don't know why they used that, going to either the SB Chrysler or the IH took an adapter.
Wheeling?!?!? WTF is that?
Diesel Smoke is offline   Reply With Quote Quick reply to this message
Old 01-04-2006, 02:50 PM   #13 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Big block Chryslers:
361
383
400
413
426 wedge and hemi
440
BUY MY BOAT
Old 01-04-2006, 02:57 PM   #14 (permalink)
"Official"
Member # 27575
361
383
400
413
426 wedge and hemi
440
I stand corrected!
Old 01-04-2006, 03:07 PM   #15 (permalink)
Member # 2071
Front housings:
IH SV
So, OS, is the Rover 727 a new casting of the IH 727 case? Then an adapter slung on the front (just like the SD33's BBMopar adpater).
If so, when did LR use the 727.. what years.. and how recently was the IH 727 case still being cast?
I have quite a few spare cases, but I've also broken a couple.
-Tom
KE7VUX
Old 01-04-2006, 03:17 PM   #16 (permalink)
Member # 11594
727 hybrids 101.
So you have:
Front housings:
BB Chrysler
SB Chrysler
Jeep
IH SV
Outputs:
IH Texas pattern
Land Rover LT231
Thanks Old Scout. I finally got ahold of James from ORD(OffRoad Design) and he suggests using an output shaft and tail housing from a '92 Dodge Cummins then I will prolly have ORD make the final adapter and use a spud shaft between the output shaft and the input gear in the Ford 205. Now....OS, you pointed out that Jeep and Dodge use a 23 spline output from the tranny but isnt the Scout a 23 spline output for the "bull gear"? Is there a length difference in the Scout and Jeep/Dodge shafts? Can I just replace the rear housing adapter? I'm gettin closer! Thanks for the input guys....
Sean
Old 01-04-2006, 03:23 PM   #17 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Rover put the 727 in there Range Rover Classics from 82-85 and then used a ZF Hp22 four speed auto. I suspect that they bought surplus IH 727s from Chrysler since the Scout was dead by two years!
Rover didn't import the RRC into the US until 1987 so finding Rover 727's in the US is a bitch. I'd love to have the Rover output since the Rover Lt-230 transfer case is 3.25:1 and Atlas strong.
BUY MY BOAT
Old 01-04-2006, 04:39 PM   #18 (permalink)
Binder's Avatar
Member # 1684
Sean
If your going to make a adapter and spud shaft why change the 727 output? Use the Texas stuff.
S.N.O.R.T.
Old 01-04-2006, 04:40 PM   #19 (permalink)
Binder's Avatar
Member # 1684
Sean
No. Both outputs are 23 spline but that's the only thing they have in common.
There's more stuff inside the trans that need to fit on the output shaft.
S.N.O.R.T.
Old 01-04-2006, 04:49 PM   #20 (permalink)
Member # 11594
That is a possibility! The spud I was talking about however, is an OEM part that comes from the Dodge. I wish I could find someone to make a "custom" spud shaft then I would just make it fit the IH output to the Ford input but I still might be able to use the stock Dodge spud and make a custom adapter and use the Dodge input gear in the Ford 205! Savvy!
Sean
Old 01-04-2006, 05:11 PM   #21 (permalink)
Binder's Avatar
Member # 1684
Oh, I see. So your going to also change the 205 input gear to the dodge input. If you do this you still need the clocking ring which I think would make the spud too short.......Come to think of it I think the dodge 727 has a long adapter on the front of it changing the bolt pattern from 8 bolt to 6 so the spud should be real long. If this is true you should be able to use a long clocking adapter in place of where the dodge adapter would be. You could also re drill the input pattern on the front of the Ford 205 to match the clocking of the Dodge 727 output. This way you would only need a spacer and could customize the clocking as flat as you want it.
Also IIRC the Dodge and Ford use a different size input bearing and retainer for the 205. Not sure how that would all fit together.
S.N.O.R.T.
Old 01-04-2006, 05:24 PM   #22 (permalink)
Member # 11594
As far as clocking the 205, I can clock it where ever I want as I will be hand making the adapter. I just need to match the length of the Dodge spud shaft from the IH output shaft. As far as the input bearing on the 205.....I prolly will have to find a special bearing which shouldnt be too hard but I am also wondering if the Ford bearing will work with the Dodge input gear?
Old 01-04-2006, 05:55 PM   #23 (permalink)
Member # 35721
why dont you just get a klune v in front of the 205 and this would make it a whole lot easier. the scout 727 has a "texas" pattern. the 80-85 fullsize jeep has a 727 with a six bolt "round pattern." the dodge 727 aslo has a round six bolt pattern, but the rear adapter is about 2-3 inches longer than the jeeps. all ford 205s came in a 6 bolt round pattern. but have a 31 spline female input gear, chevys 205 either have a 10,27male, or rare 32 female input.
on the scout tranny you cant just take the rear adapter from another truck and put it on the scout tranny. you will need to remove BOTH rear output shaft and rear adapter from one 727 (jeep,dodge,whatever) and install BOTH on the scout 727. the output shaft on the (jeep,dodge,whatever) will fit into the scouts 727, but not with the scout "texas" pattern.
i went with a klune v to a chevy 205, you can use a ford 205 also (different adapter) i took a 85 jeep wagoneer 727 and swapped the rear output shaft, along with the rear adapter, over to the scouts 727. the klune has a 23 spline female input for my 23 spline output of the 727, then the klune has a 32 spline male rear output, to go into my 32 spline female input of the 205. then your done...
73 Scout II,350tbi,700r4,twin sticked np205,4:1klune,60f,14b,4link fr/rr,coilovers fr,42"pitbulls
ih4ever is offline   Reply With Quote Quick reply to this message
Old 01-04-2006, 05:59 PM   #24 (permalink)
dukguy's Avatar
Member # 29450
So no one ever made a divorced driver drop 205?
dukguy is offline   Reply With Quote Quick reply to this message
Old 01-04-2006, 06:07 PM   #25 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
I've seen them in a late 70's F250.
BUY MY BOAT
