Breakout Traveler Build-up - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2015, 07:16 PM   #101 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
I can absolutely understand that. Around here you can get a 5.3 or 6.0 with harness, accys, ecu, and 90 day warranty for $500 from the junkyard. Wrecked trucks go for $1000. They changed the engine swap game.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 04-23-2015, 01:04 PM   #102 (permalink)
Member # 50955
Wow that's cheap.
472Scout is online now   Reply With Quote Quick reply to this message
Old 09-03-2015, 04:52 AM   #103 (permalink)
Member # 66787
Send a message via Yahoo to Tahcustomscout
I have them... Its hard enough to find time and money to work on this thing as it is.
79' Traveler,CH350,700r4,d20,BFG 33"A/T.
Tahcustomscout is offline   Reply With Quote Quick reply to this message
Old 09-03-2015, 04:54 AM   #104 (permalink)
Member # 66787
Originally Posted by ChiScouter View Post
welcome back, why are you staying with the stock axles knowing the hp that is on the way?
Old 09-03-2015, 04:57 AM   #105 (permalink)
Member # 66787
x2, there's no way I'd spend that much money and time on 44's. Or on a 350 for that matter.
They will do all Ill ever need... that is until I get a wild hair and build it up again.
Old 09-03-2015, 04:58 AM   #106 (permalink)
Member # 66787
Originally Posted by MotoDave View Post
I'm sort of in the same boat as the OP, when I started my Scout build LS based engines were still really expensive so a 350 made sense. I've watched them drop at least 1/2 in price and its tempting me to make the switch before I ever even get it running with the current 350.
Tahcustomscout, I'm digging this build and all the machine work. Keep it rolling.
Im Trying to. I think Ill be working on the links this weekend now that the weather has cooled off a bit.
Old 09-16-2015, 03:23 PM   #107 (permalink)
76scoutII's Avatar
Member # 147458
awesome build thread i just read through it over a few 15min breaks at my job. you are WAY more productive on your breaks than i am! excellent machining work and setup. i work in quality at a cnc shop and your parts look as good or better than what we ship off to aerospace industry customers. this is the kind of tech pirate needs and is what makes the site so amazing and useful. this wealth of information and knowledge shouldnt ever be taken for granted. looking forward to seeing your take on the dana20/20 doubler and a linked n coiled rear! keep up the awesome work and pics!
76scoutII is offline   Reply With Quote Quick reply to this message
Old 10-25-2015, 03:05 PM   #108 (permalink)
Member # 66787
Frame is all prepped and ready to go
So over the past few weeks I have been prepping the frame. Scraping and removing all of the old undercoating, cutting off all the old spring perches and motor mounts (where I found a couple of stress cracks). So after cutting the cracks out and replacing the metal I straitened all of the tabs and body mounts that needed attention, ground down any welds that I was not satisfied with and touched them up, then added paint.
I also fabbed up some rolling stands that hold the frame up to the required ride height for setting up the suspension. It also will help me roll it around so I have room to work. This week I hope to have the rear truss all cut out and formed so I can put it on next weekend. I am still trying to decide on whether or not to cut and dimple holes in the truss or to keep it solid to prevent bud and debris from building up in it.
Old 11-08-2015, 08:08 PM   #109 (permalink)
Member # 66787
Gotten A bit done in the past two weeks
So for the last two weeks I have been tearing down and cleaning up the axles to prepare for the Locker, Gears and Truss.
I also purchased a Variable Frequency Drive to run my Bridgeport, which came in handy this weekend as well.
I started by placing the E-Locker in the case and lining up where to drill the 15/32 hole for the wires.
Then I hit the cases again with a wire brush and cleaned the debris out of the housing.
Old 11-08-2015, 08:17 PM   #110 (permalink)
Member # 66787
Truss
I started the truss by fabricating the skeleton out of 3/8" A36 and tack welding it to the axle tubes.
Then I cut the front and back skins out of 10 ga. and welded them up completely both inside and out. After welding I cleaned everything off with a wire wheel and started installing the gears.
I did end up getting the pinion gear installed and set but ran out of time.... I was getting tired and the walking dead was coming on....
Old 02-13-2017, 04:18 PM   #111 (permalink)
Member # 66787
Made a little progress this weekend
Well I fabbed up some upper link frame mounts a few weeks ago out of some 1/4" sheet..
I made my Upper Links outof 1.5" O.D. x 1/4 Wall DOM and the Lowers out of 2" O.D. x 3/8" wall DOM. I used Welded on Johny Joints on one end and threaded Joints on the other.
Here is how she sat on Sunday afternoon.
Old 02-19-2017, 05:48 PM   #112 (permalink)
Member # 66787
This weekend I as able to finish up the frame mounts and truss for the lower links. I jigsawed it together our of 7 ga and 1/4" plate.... I am pretty please with the way it came out. Plenty of clearance for the links and dodged all of the body supports and floor boards. I have a little more gusseting to do, but I think I will wait until I see how my exhaust is going to fit before I put them one.
Now its on to the front axle and time to buy some more parts... Anybody have a lead on good deals for Coilovers right now?
Old 02-26-2017, 06:55 PM   #113 (permalink)
Member # 66787
Over the weekend I finished burning in all the components of the 4 link, then I completed a disc brake converstion. I placed the engine back in the frame and relocated it about an inch back and down from its previous location. The prior engine mounts were crap so I will being building a new set this week, as well as a new trasmission brace and cross-member, which will also be used to support the front lower links. With the engine back in place I was also able to start mocking up the front links with PVC. I also purchased the new tires and wheels, but they will not come in until the week after next.
Old 03-03-2017, 07:58 PM   #114 (permalink)
Member # 66787
Well Since I have Drill this weekend this is all I could get done. I want to triagulate my lower front links a little bit, but in order to get the right clearance I needed to build an new transmission crossmember as well... This will serve as both. I cut the plates out of 7 ga with two 3-1/2" x 1/4" wall tube inserts which will reinforce the cross member while giving me an avenue to route my exhaust.
Tacked up and in position
All welded up.
Old 03-03-2017, 08:15 PM   #115 (permalink)
Member # 9835
All your work is impressive, but DAMMM that crossmember is awesome. Is that something you could cut more of at will and sell?
Are those upper link mounts going to clear under the stock floor without a body lift?
ChiScouter is offline   Reply With Quote Quick reply to this message
Old 03-03-2017, 10:22 PM   #116 (permalink)
levi1a's Avatar
Member # 106935
So whats gonna happen if the transmission needs to come out? Digging the work though.
SEBA
levi1a is offline   Reply With Quote Quick reply to this message
Old 03-04-2017, 03:28 PM   #117 (permalink)
Member # 66787
I guess... I still have the program and just have to run it... and yes the floor actually raises up 6-8 inchs right where the mounts are.
Old 03-04-2017, 03:39 PM   #118 (permalink)
Member # 66787
Yea I know... After I mocked it up I sat there and looked at it for 45 min or so contemplating whether or not to continue. If I need to drop the tranny I will have to break the engine loose and move it forward about 3-4 inches... which I have the room to do, but it would still be a pain. In the end I opted for a more solid platform over convenience.
Old 03-05-2017, 07:39 PM   #119 (permalink)
levi1a's Avatar
Member # 106935
You could always split it in two places and weld in some square 4 bolt flanges.
SEBA
Old 03-05-2017, 09:56 PM   #120 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
I'm not really into naming projects..but I dub thee Lazarus. Arise from the dead! Top notch work. Good things take time. Took me 5 years, (including 3 PCS moves and a deployment) to get mine "done". Well, off jackstands, tagged, and insured and on the road.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 03-06-2017, 04:57 AM   #121 (permalink)
Member # 66787
Yep... You are right. and depending on how the link mounts come out and look, that option may be on the table.. It may be two weeks till I get to that point though...
Old 03-06-2017, 05:01 AM   #122 (permalink)
Member # 66787
Ha! Yea shes been laying dead a while.
Old 03-06-2017, 09:41 AM   #123 (permalink)
Member # 1956
I'm with you levi1a, been there way too many times.
Love the mount, but it needs to be removable. You never know where you at and need to drop it. If you take a 2 week trip to Moab for instance, front drive line breaks, hit the trans and need to weld a crack in it like I had to do, winching it down and up off the rollcage makes it easy. You only lose a day instead of a wasted trip. So much easier to throw a strap around the whole trans/transfer cases( I have a doubler behind a 4l80) and winch it down and back up. No scary jacks, especially on soft ground.
Another thing I have done on a Traveler build with the IH powertrain. I have cut the D20 in 1/2 as the first range box, and then used it to power a divorced 205. Worked great. Then you can have a completely flat bottom for a skidplate.
"You cannot reason someone out of something he or she was not reasoned into."
Shadow man is offline   Reply With Quote Quick reply to this message
Old 03-08-2017, 05:58 PM   #124 (permalink)
Member # 66787
I picked up my Tires and Wheels today. 37x13.5x17's. I also recieved some more rod ends to continue on my front links this weekend!
Old 03-08-2017, 06:46 PM   #125 (permalink)
chris fresh's Avatar
Member # 69678
Really nice build man. I see guy's talking about time,I know the feeling. My 800 has been tucked away for 6 years and just got back into the build two weeks ago. signed back up here today and looking forward to progress and input from the crew of guy's around here.
78 SII very healthy 327,th-350,np205,35''boggers
71 800B LT-1,400,203/205,FF14,d-60,42'' rockers on beadlocks
To my great friend rob,RIP buddy we'll never forget you.
chris fresh is offline   Reply With Quote Quick reply to this message
