Banned
Member # 82469
axle life expectancy
Hey, what are everyone's thoughts about the apprx. "life span" of the 30 spline rear shafts in my D44('77 terra with 35's and 4.10's locked) I am replacing the fronts with 4340 inners/outers and yukon super joints...alas, I cannot seem to locate "off-the-shelf" stuff for the rear or if I even should mess with it..the front is locked ,too...........I wheel it pretty hard sometimes...
Member # 65726
call jeff at ihonlynorth.com he can hook you up with alloy rear shafts, for a good price. With those axles you should be good, if your using a detroit locker. The stock carrier wont hold up.
#3 (permalink) | |
"Official"
Member # 27575
Wheeling?!?!? WTF is that?
Banned
Member # 82469
Thanks for the tips...I did try for those Alloy rears through 4wheelparts and the part# said "no longer avail." even though just two weeks prior, I had gotten a price quote from the same people....anyway, Thanks again!!!
#5 (permalink) | |
IH Parts for America
________ Glass weed pipe |
Dana 44 Polisher
Member # 13731
I'll comment on life expectancy.
I ran a similar set up (35s, 4.27's, locked) and in two year of wheeling (15-20 runs, some daily driving and light hauling duty). I broke an axle shaft at the splines, twisted 2 other shafts (found them during normal maintence) and chewed the teeth off a ring gear. So..... Life expectance is not so good! ![]() Get the alloy shafts if you have the wallet for it. Or pack a lot of spares, which then makes your truck heavier, which then makes you break stuff faster, which then makes you carry more spares....
Buy my stuff!!! High Pinion Dana 44 for an Early Bronco Almost brand new 39.5x13.5x15 IROKS |
Member # 4506
However, a drop down to 33's and 4+ years on the same (used/Junk pile) rear shafts and I haven't busted one (yet).
Even with the new 4:1's.... but then I really haven't gotten out much in the last year+. So I guess if you wheel it, it WILL break, eventualy, fit it sits on the trailer (or under a tarp) they hold up REALLY well
I wheel a mean jackstand
#8 (permalink) | |
After ~1year with 36s and a LS/4.09s in the back, I snapped a rear shaft. IIRC I broke another shaft somewhere over the next year or two, then wiped out the 4.09 R&P. Now it has new 4.09s and a LockRight and more stock shafts.. for another season or so. Just paid for my 70HD. Still need gears and a Detroit..
-Tom KE7VUX |
