#78 (permalink) |
Vortec Scout II
Shit if you cutting the collector off just weld V band clamps on them!!! Be as to remove and won't leak.
'73 Scout II Vortec 6.0L 4L65e np241 '73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's '01 VW Beetle TDI-50mpg or better! ![]() GM Gen III/IV V8 swap info TECH: Gen III/IV "LS motor" to Early GM Auto Trans |
#79 (permalink) |
Fuck that was a good time reading all of that. I had forgot what a cluster "certain" PBB IH dudes can be. No sense of humor at all.
So glad that this truck was purchased for a price that is more realistic. It sounds like you got it for what it was actually worth too. Did you respray it or was it resprayed when you picked it up...? It looks really nice now. And as far as the transplant goes...that will be one nice running truck when you are done with it. Bravo. .
www.markyoungrocks.com |
#82 (permalink) |
Member # 31658
Fedex dropped of my new radiator today. It's a Champion radiator that I bought off eBay for $200 with free shipping. It's 3 row, fully welded aluminum for a '66-'67 chevelle. It has dual mounting flanges. If I cut the front flanges off it will damn near be a direct bolt in.
#83 (permalink) |
wondering aimless
Member # 4586
Cory, if your swap is anything like mine, you will need to pull a leaf or it will be nose high. Those darn LS power plants are way light and you are pulling a ton of weight off of your front axle. Leona's Scout is now heavier on the rear axle than the front axle.
RIP Ricky, you are missed. |
#84 (permalink) |
Member # 31658
It already rode like shit with the 345 in it. It's a good excuse to put coils in the front.
Your headers showed up today too. Looks like they will give me plenty of room. Thanks again. ![]()
#85 (permalink) |
Vortec Scout II
Get them coated be worth it!
Looking GOOD!!!
#86 (permalink) |
Registurd Abuser
Member # 34995
Is the SII frame that much different than the 800 frame? My pickup manifolds fit between the frame with room to spare. Looks like you are gonna be done with your swap way before me
#91 (permalink) |
Vortec Scout II
Looks pretty good so far look like headers fit great.
Mines actually lower than that. As I was going to use the mech fan, but decided to lower the motor making the fan uses less and ended up with efans. I didn't push mine to far back to save drive shaft length in the rear. Its already lighter up front so pushing it back its gain alot and the angle was better for the rear shaft. Also the truck pan clears great but I am SOA.
#92 (permalink) |
Member # 31658
I couldn't really go much further back because the heads would have been up to the firewall. If I would have gone forward much more the mechanical fan would be too close to the radiator. I centered the crank between the frame rails and I mounted it as high as possible and still have the plastic engine cover fit under the hood because I'm concerned about clearance between the front diff and the right header collector and oil pan. I think I'm going to add some bumpstops for peace of mind. I'll take some more pictures in a while. I'll be using an 80's K5 transmission crossmember to install this morning.
#97 (permalink) | |
Member # 105936
Mine is in at 7 degrees to fit. |
#98 (permalink) | |
Member # 9835
Im also looking into OBA. There are pics of a York on a 5.3, based on your pics I think it may be too tall to fit under the hood Those pics were most helpful. I really like what you did with the headers |
#100 (permalink) | |
Member # 31658
