#601 (permalink) |
Member # 105834
I hope you could decipher my attempt to measure that cooler. I have a new crank adapter coming to use the Isuzu auto fly wheel. just one more step in the forward direction. Hope you can get some time for yours.
#602 (permalink) |
Member # 19510
SUMMER 2013 ! Just sayin
77fj40, 1 TON www.wfoconcepts.com 530-268-9494 tlca# 12281 semi_budget 1ton build /forum/toyota-land-cruiser/530636-semi-budget-1-ton-buildup-thread.html linking the rear http://www.pirate4x4.com/forum/toyot...king-rear.html |
#604 (permalink) |
Member # 105834
It's just about time to rebuild the transmission. Yesterday I built this jig to hold the trans for rebuilding. This is why you have that extra engine stand and that box of " what will I use that for" some where in the shop.
#605 (permalink) |
Member # 144823
Nice, I am a big fan of making life easier with your scrap metal as well!
~Ole' Sarge 71 Scout, Doubled, EFI, SOA, OBA, Ram, Hydroboost, 39.5s, D60/14b, etc, etc... |
#608 (permalink) |
Member # 105834
So any one have an opinion on automatic full manual reverse shifter with or with out engine braking? I plan to go 5 pinion planetary and the beast sun shell. Borg Warner clutches and a 10 vane pump. If any auto guys can add to my list to buy let me know.
#609 (permalink) | |
Addicted to Gear Oil
Member # 56050
Standard 5 year build plan
![]() Glad to see some more progress
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
#610 (permalink) |
Member # 100982
Hey Dan, I'd suggest getting the one with engine braking. I'm running a tci full manual reverse pattern v/b with engine braking. I do feel it holding me back a little. Mine's a th350 though. I also went with a low stall converter with an anti-ballooning plate in it. I also found a 36 tooth second gear sprag (same as an upgraded th400 one) as I broke the hardened 18 tooth upgraded one. Most of my stuff is all tci. The thing with the full manual v/b I was told, is you can get a lot of line pressure, and that holds very well. I have a huge drop in oil temp now.
#611 (permalink) |
Member # 144823
x2 on the low band apply. I got my rev man valve body w/ low band apply from Cope racing for my 727. As John explained to me, typical racing valve bodies do not apply full pressure in reverse (allowing the clutches to slip), since racing applications don't need a lot of power backing up. The low band apply in a rock crawler will extend the life of your trans and give you full power when rocking the truck. My 727 has been beat on for over 3 years now with no issues.
#614 (permalink) |
Member # 105834
Andy , I was told it would be very hard on the T converter. I did want to go that way , if you know if this is not true then let me know.
#615 (permalink) | |
Member # 215461
The only think I can think of is IF the gears were shaped differently front to back, like a differential ring gear. I would like to know the reasoning behind whoever told you that. It may be a valid reason, but I can't think of it. |
#616 (permalink) | |
F=ma
Member # 23259
I would be interested to hear the transmission shop's justification. Maybe when they hear "diesel" they think you have a high-torque Duramax or Cummins? |
#618 (permalink) |
Member # 105834
So I did speak with the TCI guys again and they think the engine braking will be OK. I am in the middle of the trans rebuild and I am held up on parts. Some how they got returned. Should be in next week,so in the meantime I got the disc brake brackets for the 70. The calipers from Napa look nice all painted right out of the box.
#619 (permalink) |
Member # 105834
I got some things done. The transmission is built and installed. The NP 203 is put together and in. The NP 205 is also in and with the shift rail mod. Now I am making the pinion angel right so I can get the drive shaft ordered. I have rear brakes to put in when I get the pinion set.
#621 (permalink) | ||
TITUS
Member # 93509
#624 (permalink) |
Member # 105834
I picked up the rear drive line today from drive line services in west sac. It's short, only 24" but looks great. Glenn you can bring that diet Pepsi.
I will order the ARB next week and get the 70 all done.
#625 (permalink) |
Member # 19510
whatever discount
77fj40, 1 TON www.wfoconcepts.com 530-268-9494 tlca# 12281 semi_budget 1ton build http://www.pirate4x4.com/forum/showthread.php?t=530636 linking the rear http://www.pirate4x4.com/forum/toyot...king-rear.html |
