Then and Now - Page 17 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-11-2012, 09:53 PM   #401 (permalink)
AF6 OD
R290's Avatar
Member # 46467
Originally Posted by rkscout View Post
Opps
That last shot looks like it just got tired and decided to take a nap.
hope nothing broke.
73 IH Scout
R290 is offline   Reply With Quote
Old 02-12-2012, 04:40 PM   #402 (permalink)
rkscout's Avatar
Member # 100982
Nothing broke on the flop, but I did snap a rear axle shaft earlier in the week, and also cut a tire early on too. It was a fun week at KOH. Our team ran a 6 min, 48 sec in qualifying which put us 52nd. Lost 4 tires during the race, and had issues with vapor lock on the first lap which put us pretty far behind. Got it cleared up by the second lap, but time was not on our side. We were a mile from the finish line and a half hour past the time limit when the pass side rear axle shaft sheared its bolts and went flying from the car, shortly after the front pass side went. They tried winching it up the last hill put kept breaking the winch rope. It was a big disapointment to be so close and not finish the race.
Scout build thread-
http://www.pirate4x4.com/forum/showt...hlight=rkscout
rkscout is offline   Reply With Quote
Old 02-19-2012, 08:58 PM   #403 (permalink)
ddestruel's Avatar
Member # 20999
Eegads that thing has changed alot since i got that old front end from you......
funny thing was you were one trip away from grenading that diff in a bad way.... the R&P was ready to let go..... when i opened it up and cleaned it out to swap in my gears the Ring gear and the pinion had huge spider cracks all the way through. and all teh teeth wiggled at the cracks
I'll have to poke over one of these days and take a look after going through this thread its a whole different critter been busy on my own build.
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA, front 608.9 and some bolt on stuff.
I miss my old 4bt powered chief
Support Frank the Tank
ddestruel is offline   Reply With Quote
Old 02-22-2012, 11:32 AM   #404 (permalink)
Member # 16680
I had been asked a few questions on the heater that I had used. I gutted all the old heater stuff and went with a Heatercraft model 201HOR. Here's a link to it.http://www.heatercraft.com/ProductIn...oductid=201HOR It comes with two 2 1/2" ports. I needed one 2 1/2" port and two 2" ports so I cut the port for the defroster ducting out of the old heater box and screwed it onto the new heater. I then ran some flex tubing to each of the defroster ports and to the new vent box. I looked on heatercrafts website and I can't fix the vent box on it anymore. Plug, I would probably run a second heater in the back for the kids. It heats up the half cab very well. Snug fit in the glove box, but it all fits. With the original heater and fenderwells removed, I built a new battery box and hung it from the firewall.
I dont know why I am having such a hard time figuring this out, but where is the heater? Glove box? I know thats what you said, but I dont 'see' it.
94 Mall Rated Bronco-R.I.P.
1961 Scout 80 stretched and linked
wt4x4.com
PM me for CPR/First Aid Instruction for you club
plug ugly is offline   Reply With Quote
Old 02-22-2012, 11:47 AM   #405 (permalink)
rkscout's Avatar
Member # 100982
No kidding, I had no idea. Sounds like I pulled it just in time.
Post 74, 5th pic, it took me a little while to find it. Yep, it's in the glove box.
Scout build thread-
Old 02-22-2012, 11:53 AM   #406 (permalink)
Member # 16680
thanks. I think that is the same post I quoted, but for some reason, I can see it there. I looked at the link you posted, and the plenum seems quite different in shape. Did you alter that too when you added the different sized ports?
wt4x4.com
Old 02-22-2012, 12:39 PM   #407 (permalink)
rkscout's Avatar
Member # 100982
I used the HeaterCraft 201HOR model. My poor paint skills of what I did in yellow. I can get some pics of the bottom of it tonight if you want.
Scout build thread-
Old 02-22-2012, 03:28 PM   #408 (permalink)
Member # 16680
not necessary, but thanks
wt4x4.com
Old 04-17-2012, 09:49 PM   #409 (permalink)
BigHarvey56's Avatar
Member # 141716
Did you hear we are going to try and qualifiy for KOH 2013 in New Mexico next month?
if you can't drive over it DRIVE THROUGH IT!!!
BigHarvey56 is offline   Reply With Quote
Old 04-18-2012, 09:45 AM   #410 (permalink)
rkscout's Avatar
Member # 100982
Yea, I talked with Jimmy a couple of weeks ago and he told me. As much as I want to be there to help, I'm not going to be able to make it down there.
Scout build thread-
Old 04-26-2012, 05:06 AM   #411 (permalink)
Member # 144823
Awesome build... Subscribed.
Sucks about all the carnage. Now you can toughen it up!
~Ole' Sarge
71 Scout, Doubled, EFI, SOA, OBA, Ram, Hydroboost, 39.5s, D60/14b, etc, etc...
Ole Sarge is offline   Reply With Quote
Old 04-26-2012, 01:10 PM   #412 (permalink)
Member # 16680
hey doug,
so you have the vents on the heater facing down? Any problems burping the system that way?
wt4x4.com
Old 04-26-2012, 04:00 PM   #413 (permalink)
rkscout's Avatar
Member # 100982
hey doug,
No problems burping it.
Scout build thread-
Old 04-27-2012, 08:00 AM   #414 (permalink)
Member # 16680
what adapters are you running to go from the 3" at the heater to the 2" at the defroster?
wt4x4.com
Old 04-27-2012, 08:02 AM   #415 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
Maybe use an exhaust reducer from vatozone or something like it.
'71 800B is offline   Reply With Quote
Old 04-27-2012, 03:56 PM   #416 (permalink)
rkscout's Avatar
Member # 100982
I cut out part of the old heater and screwed it onto the new heater. I'll get some pics tonight that will explain it better.
Scout build thread-
Old 04-27-2012, 05:54 PM   #417 (permalink)
Member # 16680
I went ahead and order the vintage air set up. It has 2" ducts and a bottom dump for the floor. Has variable heat selection too.
would still like to see pics of your set up if you can get them. Thanks a lot.
wt4x4.com
Old 04-28-2012, 06:28 PM   #418 (permalink)
rkscout's Avatar
Member # 100982
Pics of the ports on the bottom of the heater. It had two of the bigger ports, I cut out one of the ports and then cut out the ports from the factory 800 defroster ports, then screwed it to the bottom of the new heater. The two smaller ducting goes to the defrosters and the larger one goes to the drivers side to blow heat onto me.
Scout build thread-
Old 04-28-2012, 07:26 PM   #419 (permalink)
Member # 16680
thanks a lot.
wt4x4.com
Old 06-12-2012, 09:21 PM   #420 (permalink)
rkscout's Avatar
Member # 100982
Did some work on it last week to get it ready for the rock race. Added a door bar with some aluminum sheeting to keep my feet and hands in, and a window net. Also added an X to the B-pillar, and an anti-submarine belt.
Scout build thread-
Old 06-12-2012, 09:22 PM   #421 (permalink)
rkscout's Avatar
Member # 100982
Had my upholstery guy build me a window net.
Scout build thread-
Old 06-12-2012, 09:28 PM   #422 (permalink)
rkscout's Avatar
Member # 100982
Now for the carnage. Broken rear driveshaft. Going to upgrade to some 1410's now. Bent pass side motor mount, bent tube on engine hoop where the coilover attaches. Broken end on air bump and a cut tire.
Scout build thread-
Old 06-12-2012, 09:33 PM   #423 (permalink)
rkscout's Avatar
Member # 100982
Lower footwell near the firewall was starting to buckle and crack. Fixing that and will plate it. Going to tie the engine hoop to the cage, and add another down tube from the engine hoop to the firewall. Then I need to figure out a better engine mount, and then tie the seats into the cage.
Scout build thread-
Old 06-13-2012, 02:35 PM   #424 (permalink)
Buck Dodson's Avatar
Member # 35185
I just watched the in cab video. I'm suprised there isn't more broken shit...
Looked like fun.
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
/forum/international-harvester/850321-so-you-think-you-want-do-3-link.html
Buck Dodson is offline   Reply With Quote
Old 06-14-2012, 08:56 PM   #425 (permalink)
rkscout's Avatar
Member # 100982
Looked like fun.
It was a blast, I had so much fun. Already looking forward to the next one. I need to get the front coilovers dialed in better so it doesn't land so hard when I get some air. Thinking about some coilovers for the rear too. Need to truss the axles out to the ends, and add an antirock swaybar to the rear.
Got the drivers side of the engine hoop tied into the cage, waiting on finishing the pass side till after I get the motor mount fixed. Also added a down bar to the engine hoop and plated around the coilover upper mount. Then I'll tie the seats into the cage.
Video's of the race.
Qualifing Run. Second fast time, fastest was our ultra4 car.
Scout Qualifing Run Lakeport Rock Race 6/9/12 - YouTube
First heat. In car.
Jimmy & Doug Racing Lakeport Rock Race 6/9/12 - YouTube
Same race.
rook races lakeport 6-09-2012 - YouTube
Scout build thread-
