Then and Now - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-31-2008, 05:44 AM   #26 (permalink)
Member # 100982
Rear body work done and in primer. Also built a new rear bumper, 3"x3" angle welded to 4" flatbar.
rkscout is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 05:49 AM   #27 (permalink)
Member # 100982
Now it was onto the hood. I had been putting this off till now, because I knew it was going to be a ton of work.
Old 10-31-2008, 05:53 AM   #28 (permalink)
Member # 100982
Originally Posted by war pony View Post
Looks good Doug, Nice progression pics
Thanks, Dan. Anymore progress of yours? Heading over to Shellville this weekend to help a buddy try and finish up his buggy before we head to the Hammers on the 12th of Nov.
Old 10-31-2008, 07:46 AM   #29 (permalink)
Member # 56574
You need to move those 5 point "neck" harness mounts up higher The mounting should be not more than 4" below shoulder height. Some one is going to snap their back
63 Scout 80, 350 sm465 kluneV np205, 1 tons, 42" Pitbulls
scout254 is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 08:23 AM   #30 (permalink)
Member # 100982
Yea I know I need to change that. I left it lower so I could still get into the back. What do you guys suggest? Hoop behind each seat? or? I put the backseat in when I take the family. Put in a hoop (black) and also tie it in to the top and side (blue)? Maybe?
Old 10-31-2008, 08:36 AM   #31 (permalink)
Member # 100982
Here's what the cage looks like now. What other bracing should I do? Do you think that 1 1/4 .120 wall tubing would be fine for the seat belt brace or should I use 2" .120?
Old 10-31-2008, 10:39 AM   #32 (permalink)
Member # 100982
Here's what I'm thinking.
Old 10-31-2008, 02:40 PM   #33 (permalink)
Member # 100982
I think this will work.
Old 10-31-2008, 03:18 PM   #34 (permalink)
Member # 100982
Finished up the hood, then finished the body work on the front end. Used the forklift to see where I still needed to trim the fenders at.
Old 10-31-2008, 03:26 PM   #35 (permalink)
Member # 100982
Body work was done, so now it was time for paint. Plan was for desert tan flat, changed my mind at the last minute and went with dodge ice silver. It's great having a friend that has his own paint and body shop. He shot the color and clear for me at my shop, hell he even buffed it out for me. 2 coats color, 3 coats clear.
Old 10-31-2008, 03:29 PM   #36 (permalink)
Member # 100982
Put the front sheetmetal back on, needed something to break up the color. Brett said he had some paint at his shop and would bring it over.
Old 10-31-2008, 03:32 PM   #37 (permalink)
Member # 100982
Fresh from paint.
Old 10-31-2008, 03:35 PM   #38 (permalink)
Member # 100982
Hung the doors and put the cage back in. We'll see how long it takes it get dented again.
Old 10-31-2008, 03:49 PM   #39 (permalink)
Member # 4239
Bad ass build, makes me want to find a 800 to build.
TERRA-IZER is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 03:55 PM   #40 (permalink)
ScOuT LoVeR
fullthrottle(tm sct)'s Avatar
Member # 54463
Send a message via AIM to fullthrottle(tm sct)
very nice 800 indeed.
R. R. Johnson
99 Grand Cherokee
05 Jeep Sport
fullthrottle(tm sct) is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 04:16 PM   #41 (permalink)
RustoleumWhite's Avatar
Member # 4506
What was the actual time line for the build.
I know sure as shit you didn't do it in the week you've been updating this thread
clean.
How long ago did you finish it?
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 04:41 PM   #42 (permalink)
just4cuz's Avatar
Member # 98655
How much weight did you lop off?
just4cuz is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 06:03 PM   #43 (permalink)
Member # 105834
Have fun in Shellville, I took a nice ride in a biplane over in Shellville, Not too much on my junk as of late, Waiting on funds for the doubler. I may bend some tube around the holidays, looks like you have that down.
war pony build
war pony is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 08:10 PM   #44 (permalink)
BLK Scout 800's Avatar
Member # 29630
Send a message via MSN to BLK Scout 800 Send a message via Yahoo to BLK Scout 800
Nice build! I hope the 1ton's hold
"Truth is, everybody is going to hurt you; you just gotta find the ones worth suffering for." -Bob Marley
BLK Scout 800 is offline   Reply With Quote Quick reply to this message
Old 11-01-2008, 05:08 AM   #45 (permalink)
Member # 100982
It took two months from when I first started removing sheetmetal to final assembly. Finished the dovetail and paint in march of this year. I not going to say finished, because it will never be done. Weighted it after paint, 5160lbs with tools, spare parts, doors on, and without me in it. Much happier with that, than the 5900lbs that it was. I hope the 1tons hold, I upgraded to yukon 4340 shafts a couple of weeks ago. Had smoke coming off all four tires getting up this waterfall. Nice being able to throttle down when I need to now. Didn't used to do that with the 44. Figured I'd better upgrade the fronts before the hammers. Running my 37" Cooper STT in this climb. They do much better on the road than my swampers, great off-road to. They stick very well. Amazingly I never touched the bank. It stopped an inch from hitting the windshield frame. Backed up a little and brought the front end back down then made it all the way out. This was a couple of weeks ago at Cow Mountain.
Old 11-01-2008, 05:20 AM   #46 (permalink)
Member # 100982
Didn't take long to get the first dents into it. First run out with new paint. Hollister in April, running through the ravines.
Old 11-01-2008, 05:30 AM   #47 (permalink)
Member # 100982
Back to pulling dents and paint. Here's a few pics from the mini rubicon at Hollister. Definitely feels lighter and the visablitity is so much better.
Old 11-01-2008, 05:46 AM   #48 (permalink)
Member # 100982
Bought some new shocks and outboarded the rears. Welded on some new front upper mounts. 14" travel ranchos. Looks close to the coolers, but there's 2 inches of clearance.
Old 11-01-2008, 07:06 AM   #49 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Dang man. Awesome job on that Scout. Great, now I miss Snoopy.
Snoopy is offline   Reply With Quote Quick reply to this message
Old 11-01-2008, 07:26 AM   #50 (permalink)
Member # 100982
Ok, I've got to throw this one in. Johnson Valley portapotty.
