Then and Now - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-19-2009, 06:20 AM   #101 (permalink)
Member # 100982
Not sure on the #'s. I'm hoping for 325+. Bought it from a friend a couple of years ago. He had bought a mid 80's tow truck for the front 60 and it had a freshly rebuilt 350 in it. I paid $50 for the motor. I pulled it down and checked it all out. Everything looked good. 4 bolt main bottom end. Installed a high volume oil pump, comp cam extreme 4x4 cam, (second largest one, didn't want to change to a high stall converter to run the larger cam) double roller timming chain, edelbrock performer heads (had them sitting around for another truck that I now don't have), roller rockers, and performer rpm intake. Hope that will get me the power I'm looking for.
rkscout is offline   Reply With Quote Quick reply to this message
Old 01-24-2009, 07:01 AM   #102 (permalink)
Member # 100982
Pulled the old motor out thurs. Ran into a problem when I tried to install the exhaust manifolds on the aluminum heads. When I tried to bolted them on, the manifold would hit the lower portion of the head and not seal. Bought some block hugger headers, but I knew that they would not fit between the firewall, because the exhaust manifolds would barely fit. Plus now I have to get the exhaust redone. Slipped the engine in to see where I need to trim the fire wall, then pull it back out. Cut the firewall, reinstall the engine, get two bolts in, look up and see that I forgot to put the flexplate back on. Pulled it out again, reinstalled the flexplate then slipped it back in. Hope to get it all back together on Sun. Get the exhaust redone next week and then fire it up to break in the new cam.
Old 02-12-2009, 10:09 AM   #103 (permalink)
Member # 100982
We'll I did get the exhaust redone a couple of weeks ago. Brought it home and it fired right up. Great. Turn the hand throttle up to 3 grand to break in the cam. After 5 minutes I see that the headers are starting to glow, crap, I check the timing, adjust the computer, still glowing. Mess with it the next day, still can't figure out why the hell it's running lean. The next day I have a side job to pull the engine, tranny, t-case and wiring harness/ computer out of a rolled '97 k1500. (engine, sm465, atlas all going into a yj. I'll be installing that also. Never done a smog legal swap before, should be interesting.) Spent the next day (missed the superbowl) dropping the pan, timing chain cover to check that I had installed the cam correctly. I did. As I'm putting that all back together I notice that the intake gaskets are oil soaked. Pulled the intake, checked the heads and intake with a straight edge. Looks good. Reinstalled the intake with new gaskets, fired it up, intake still leaks. ( leaking through the lifter valley) Pull the performer manifold off the old engine, installed the performer on the new engine, with new gaskets. Still not right. Now I'm pissed. Mon. cleaned up the old engine, repainted and resealed it, installed the roller rockers, performer rpm intake, and headers on it. Pulled the new engine out and installed the old engine back in. Old engine runs tits. Better than before. Talked with Edelbrock, their telling me that I need to use their special gaskets. I don't know. Feed up and tired of pulling engines.
Old 02-12-2009, 03:02 PM   #104 (permalink)
Member # 125848
hmmm thats odd about the new engine...I take it you didn't install the edelbrock heads because of the sealing problem you were having with the intake? That's odd...that sucks cuz the new motor with better heads/cam then the old one would definately make more power. Whats the specs on the old one? Just stock heads and cam or what? Why didnt you put the new cam in the old motor? Wouldnt work with the valvetrain and rods/heads on the old motor? Well that sucks.... I hope you get it figured out, cuz like most all of us think,the more power the better!!! I think you'd be better off with the headers, even though they're not long tubes they prob wouldnt choke the motor as much as the manifolds would, especially the new one. It just sucks it was a pain in the nuts to get them in there. You should try and grab a video or some sounds clips of the motor, I'm sure it prob sounds pretty nice.. What did you do for exhaust on it muffler/cat wise? Good luck to ya bud, I hope you get everything worked out and BTW, I don't know if I've told you this but I think your scout is one of my favorites if not THE favorite one I have....Love it!! Sorry for such a long post and so many questions, just interested in it is all..
98ZJ is offline   Reply With Quote Quick reply to this message
Old 02-12-2009, 03:05 PM   #105 (permalink)
Member # 100982
Installed some new Corbeau seats. Now that I have only the halfcab, I needed to figure a way to have my wife and daughter sit up front with me. Had my upholstery guy make me a backrest that I could bolt to the bulkhead behind the center consule. My daughter will sit on the center consule(it's padded and she's only 8) She tried it out and said she will be fine with it. Still need to add the seatbelt though. Put my swampers/allied beadlocks back on. The old girl's getting pretty wide now. 86 1/2"s up front. To bad my trailer is only 83"s between the wheelwells. Guess I'll have to go over the wells now.
Old 02-12-2009, 03:14 PM   #106 (permalink)
Member # 100982
Actually the bottom ends of both motors are nearly identical. The newer one is bored .030" over though. Running the same cam, double roller timing chain, high volume oil pump, both are 4 bolt mains. Didn't swap heads, because I'm thinking that is where my problem is. No cat, single 3", 3 chamber flowmaster. Sounds good.
Old 02-12-2009, 03:40 PM   #107 (permalink)
Member # 16680
what do you plan for a headrest for her? that bulkhed will hurt if she hits her head.
is that a blower motor in the glove box? what kind?
any shots of the doubler and mounts?
what did you stretch the WB to? looks like you just pushed the front forward?
plug ugly is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 05:13 AM   #108 (permalink)
Member # 100982
She's tall enough that her head is above the bulkhead. It's like a lowback seat. I won't be getting crazy with my wife and daughter in the rig. In nicer weather, I remove the bulkhead and bolt a highback bucket seat in the back. Yep, it's a heater in the glovebox. It is a heatercraft heater and works very well. Has a 3 spd fan. Check out post 87 for pics of the doubler. Wheelbase is now 103. Most of the stretch is in the front. Running chevy 47" front springs, and chevy 52" rears. I'm going to push the rear back another 1" when I link the back.
Old 02-13-2009, 08:27 AM   #109 (permalink)
Member # 16680
thanks, not sure how i missed those.
hard to tell from the pic, but do you have room for a t-case e-brake?
is your motor in a stockish location?
nice build btw, very motivational
Old 02-13-2009, 09:26 AM   #110 (permalink)
Member # 100982
Not sure on the diameter of the t-case e-brake, but I think it would be a tight fit. If I were to do it again, I would notch out the floorpan and push everything up to get a flat belly. Then there definitely wouldn't be room for the t-case e-brake unless you cut out the pan for it. I'm running a microlock for an e-brake. A buddy had an 800A with 304 in it, (factory) and that engine was way forward than mine is. Mines tucked back a little bit. That's where I needed it to fit the radiator in it. It's offset to the passenger side a little bit. I notched out the firewall to fit the headers.
Old 02-13-2009, 09:07 PM   #111 (permalink)
Member # 125848
Yeah thats what I was thinking too with the problems getting the intake to seat correctly. Sounds like its prob pretty stout tho. What are you running for a carb? Does it have a lopey idle with that cam in it? Have any video clips or anything of it? Thats sick...chambered mufflers sound really good too...
Old 02-17-2009, 09:06 AM   #112 (permalink)
Member # 29868
I am toyota guy, but you have an awesome rig. Great Job!
1996 Tacoma V6 5spd, duals, Dana 60, 14 bolt, 5:38's, 42" Iroks, exo-cage
1997 Dodge Cummins 5spd 4x4, 79 Dana 60 under leafs, Dana 80, 4:10s, 37's
blakeape is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 12:37 PM   #113 (permalink)
Member # 54143
Sidejob on a smog legal YJ, huh? Sounds like you need to start another thread.
I'll keep my freedom, guns and hard earned money. You can keep the "change".
93Wrangler is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 01:45 PM   #114 (permalink)
Member # 100982
Who hasn't done a yj build though. I might start a thread though, since we can't seem to find much on a ca smog legal 5.7 vortec swap. We'll have it ready for you by our Moab trip. Here's a pic of your rig for you Jerry.
Old 02-26-2009, 10:52 AM   #115 (permalink)
R290's Avatar
Member # 46467
I assume you look on the smog police web site?
http://www.bar.ca.gov/80_BARResource...uidelines.html
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 02-26-2009, 12:54 PM   #116 (permalink)
Member # 100982
The guy who I'm building it with is very good on the electrical and has called BAR on what we need to have, to be compliant. We had a whole truck that we stripped and luckily it already was a manual transmission so the computer is setup for a manual transmission. (running a sm465 and atlas 4.3 behind the 5.7 now)
Old 03-05-2009, 06:43 PM   #117 (permalink)
Member # 110178
How do you like the 37's and 38's clearance wise with the d60's.
Zukiford87 is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 08:39 AM   #118 (permalink)
Member # 100982
It's allright. The front's not much of a problem, but the rear hangs up more than I would like. Here's some pics from Hollister last weekend. No one in the club made it through the left side on frame twister. I was the first to try it, and had the smallest tires.
Old 11-09-2009, 06:45 AM   #119 (permalink)
Member # 100982
Well it's been awhile since I did much to the scout. Built some rear bars to try and keep the tub out of the rocks in preperation of the outer limits trail at the Hammers. Should have built the bars higher. It does fly well though.
Old 11-09-2009, 07:12 AM   #120 (permalink)
Member # 100982
I came down so hard on the rear bumper that it bent it up into the body. The front was flexing so much that it was grabbing the front fenders and bent them out. I also twisted the splines on the steering box at the pitman arm. Full hydro wil go in this month, then I will rework the rear body.
Old 11-09-2009, 08:26 AM   #121 (permalink)
budget76's Avatar
Member # 38264
Send a message via AIM to budget76
Rk, Looks damn good, even with the damage. It was too pretty before
Rim happen from the landing, or crawling? Looking forward to more pics, that thing's always been
76 Scout, 85 Toy. 94 Cherokee ALL SOLD
Resident Web-Wheeler
budget76 is offline   Reply With Quote Quick reply to this message
Old 11-09-2009, 10:00 AM   #122 (permalink)
Member # 100982
Rim happened when crawling. Jumped it about a dozen times. Walked off where the tires left the sand then where they landed. It was @40 feet. Had a blast doing it.
Old 11-09-2009, 12:14 PM   #123 (permalink)
JF
Member # 133890
Vids?
Nice Scout.
JF is offline   Reply With Quote Quick reply to this message
Old 11-09-2009, 06:09 PM   #124 (permalink)
Member # 125140
Sick rig! What headers are you running? What vehicle are they for? Can you post more pics of how well they fit? I still have the factory ram horns on my 350, but want to find a set of headers for it. First set i got didnt fit.
I also like your heater. What is that out of?
JERM83 is offline   Reply With Quote Quick reply to this message
Old 11-10-2009, 09:02 AM   #125 (permalink)
Member # 100982
Running Flowtech headers part number 11000FLT. Check post 102 for pics on where they hit the firewall. I notched out the firewall for clearance. The heater is a heatercraft part number 201HOR.
