#27 (permalink) | |
Member # 29177
![]() I'd like to do the conversion myself since my choke isn't working so well. Last edited by Blind Driver; 11-02-2008 at 04:41 PM. |
#28 (permalink) | |
Member # 1684
S.N.O.R.T. |
#29 (permalink) |
Member # 32598
I finally made a little progress on my Scout. It doesn't look like much but it is a 76' Scout II body on a shortened 76' J20 frame my Scout frame was junk.
D60 rear, 8 lug d44 front 4:56's, 360 AMC, T18,D20. I used the stock J20 springs spring over in the front, inboarded F250 rear springs with a couple leafs removed. So I have done a ton of work to build a Scout that looks like it has a 6" lift and 3/4 ton axles. Edit: The body is not going to set that high I got it setting on some blocks to give a little more room when working, the body should drop about 3" ![]() ![]()
55' Willys Wagon 360 AMC,Howell injection,DUI,th400,203/205 doubler Last edited by OzarkMountainCJ5; 11-02-2008 at 06:12 PM. |
#30 (permalink) | |||
Addicted to Gear Oil
Member # 56050
http://www.binderbulletin.org/forums...ad.php?t=47254
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
#31 (permalink) |
Member # 122705
I'm pondering of what i can do to get some susspension under my scout, maybe start out with a spring under.. anyone direct me to a something that i can virtually bolt on with not much modification? the thing is i dont own a welder or anything to do heavy mods quite yet. and im interested in getting a welder if anyone knows of someone that has one for sale..
HRTK |
#33 (permalink) | |
#34 (permalink) |
International Dan
Scott- watch the classifieds over on race-dezert.com cheap shocks pop up all the time. You can get decent shocks with coils a lot of times for less than what your gonna spend on the bargain basement FOA's.
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html facebook.com/hardenedways Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you. |
#35 (permalink) | |
International Dan
#4666 build http://www.pirate4x4.com/forum/showthread.php?t=1048195 facebook.com/hardenedways Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you. |
#36 (permalink) | |
AF6 OD
Member # 46467
The one pictures is a 73 or earlier. here a link with pictures on pan types. You will need a Scout Oil pump and pickup. Double check to make sure the pickup is about 1/4 off the bottom of the pan. http://www.pirate4x4.com/forum/showt...hlight=oil+pan Or move the engine back a few inches. http://www.ihonlynorth.com/forums/fa...ack-2-5-a.html
73 IH Scout |
