anther 80 build - Page 10 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-16-2011, 11:12 PM   #226 (permalink)
Member # 16680
well, this is a lousy update, for no other reason than to try and motivate myself.
I deliberated over how to do the 'boatsides', and finally decided on this. I am not ready for a buggy yet, and want to be able to drive to the trails, bomob through snow/water, etc and not get soaking. This was really the only way without major floor changes, that I could mount the cage, and protect the tie ins. SOOOO, it will look like this with 4 lower tie ins like the two pictured below.
here is the pass flor board to go in, have a drivers just like it
and some bling
plug ugly is offline   Reply With Quote Quick reply to this message
Old 12-17-2011, 11:36 AM   #227 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
Damn you
This is why I will probably never finish what I am doing now .
That looks sweet............ Keep it up
'71 800B is offline   Reply With Quote Quick reply to this message
Old 12-17-2011, 02:52 PM   #228 (permalink)
Member # 105834
Looks good Damon, but what is that orange crap in the third pic. Just get rid of that, no I will just come and take it away so it's out of the area. I ment 4th pic.
war pony build
war pony is offline   Reply With Quote Quick reply to this message
Old 12-18-2011, 03:53 PM   #229 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Originally Posted by plug ugly View Post
whats the white star for?
Floor pans and rockers/boat side look good, don't forget to add a few strategic drain holes in your floor pans. I didn't, and after a recent rain storm. I had 4" of water sloshing around until I drilled a few drain holes. The plus side is that means the POR-15 and Al's Liner sealed it up well
guidolyons is offline   Reply With Quote Quick reply to this message
Old 12-19-2011, 07:41 AM   #230 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
I just stole your boat/rocker sides...Thanks!!!
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 12-19-2011, 08:28 AM   #231 (permalink)
Member # 16680
you have to notch the floors just a bit, unless you go with something smaller han 2" square. About an inch up the rocker and 3" in the floor.
Old 12-19-2011, 10:24 AM   #232 (permalink)
Member # 11615
Hmmmm...would some 1-1/2 x 2 or 3 laid flat have saved any room from having to notch the floor you think?
Old 12-19-2011, 02:27 PM   #233 (permalink)
Member # 16680
no, you will still have to notch. Oh, I have about an inch bodylift too.......
I had thought about putting some 2" tube "outriggers" that stuck out from the frame about 2", but wanted to save the clearance instead of the floor.
__/ /
____/
Old 12-28-2011, 08:38 PM   #234 (permalink)
Member # 16680
few new things.
had S/K bend up some more metal for me.
new rear deck lid made of 12g. Has some cross pieces underneath it will bolt to. Should make a weather 'proof' trunk when the tailgate goes back on.
New rear bulkhead made of 16g. This will sit right behind the back seat.
Old 12-28-2011, 10:22 PM   #235 (permalink)
guidolyons's Avatar
Member # 56050
__/ /
____/
[Slight hijack]
HoS, how bad are your rockers now? Did you see how I did my mini-boatsides? I cut just below the door, and bolt on (through rocker and through floor). They don't tie into the frame, but they are plenty strong, similar to the bolt on sliders for jeeps.
What if you run the support bars parallel to the floor like Mocha Mike's?
Old 12-29-2011, 06:33 PM   #236 (permalink)
Member # 16680
started on the drivers floor. Its a little bigger over all, but should add needed foot room for me.
I actually really like doing the floor. kinda geometry, math, and fab with some new techniques I read about to put the bends in this 12 gauge
Old 12-29-2011, 06:43 PM   #237 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
Make sure you drill plenty of holes for water to drain out of. (It will fill up on Fordyce).
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 07:27 PM   #238 (permalink)
Member # 16680
I have never had water issues on Fordyce. We will see with this thing, maybe a lower stance, but with 42's, Its pretty tall no matter how little lift.
Old 12-30-2011, 08:22 AM   #239 (permalink)
Member # 11615
few new things.
I am going to be doing something very, very similar to my rig when it comes time to work on that area. I really want something over the fuel cell to act as a shelf. I don't have a tail gate....so I am thinking of incorporating a *box* and shelf into one hinged thing-a-ma-jig to replace the tailgate. Keep spares etc. in it.
Yours should look pretty pimp when finished.
Why a bulkhead?
Old 12-30-2011, 08:28 AM   #240 (permalink)
R290's Avatar
Member # 46467
12 ga is not to bad to bend. I've used the cutoff wheel to make some slits in the past to make bending easier.
You have a shop press? They work great at bending stuff.
Where did you get those tall jack stands with the screw tops? I could sure use something like that.
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 12-30-2011, 11:22 AM   #241 (permalink)
Member # 16680
harbor freight ones cut down to this size.
The bulkhead was to seal it off to weather.
Old 12-30-2011, 07:09 PM   #242 (permalink)
Member # 105834
The floor is looking good . You gona bend the edge for the tunnel?
war pony build
Old 12-30-2011, 07:24 PM   #243 (permalink)
Member # 16680
I dont think so. The plan is to do a 2 piece tunnel, a front raised half and a rear half at this 7" height for seat cage clearance. I have a clear picture in my head, just not sure what is going to fit and what isnt. The plan is for the tunnel itself to have a break that would come down the edge of the vertical sides of the floor.
Old 01-15-2012, 04:01 PM   #244 (permalink)
Member # 201355
Scout
Love the 800's, your build is great. I always made mudders from them here in Florida. What do you do for a living, your metal work is great? Now I am Jonesing to go get my Scout out of the woods and mess with it. I haven't seen it since about 1989. I know its still there just hate to see how bad it looks after sitting out that long with no roof. Keep it up and post more picks!
bearle is offline   Reply With Quote Quick reply to this message
Old 01-17-2012, 09:13 PM   #245 (permalink)
guidolyons's Avatar
Member # 56050
Figured I'd reply here, as not to hijack that other dude's thread completely.
I need to look to see where your shifter is on the tranny Guido. mines right at the front lip of the stock tunnel cover, and I think a klune/205 combo is like an inch shorter than the 203/205 isnt it?
It came out pretty close to the stock location, I had to trim some for the shifter and for triple shifters anyway, so I made a trim panel. My Jed's 203/205 is ~19.5" from face to yoke, not sure what a Klune/205 is I'd guess it is few inches shorter.
Old 01-18-2012, 07:23 AM   #246 (permalink)
Member # 16680
thanks. I went through your build last night, just didnt make any mention of it. How long is your rear shaft? I think my tranny is forward of yours by an inch or so (hard to tell exactly from pics). And I think Otherwise we should either be dead on (tranny's are the same AFAIK) or I might be an inch shorter. My shaft is short enough that I am limited in my pinion droop to 5" before the H in the cardan botoms out. Now, running gear height plays a factor as well, so I guess we could measure there also????????????? If we care enough I guess.
Anyway, thanks for following up.
Old 01-18-2012, 07:05 PM   #247 (permalink)
Member # 16680
Here is an old pic of my doubler set up. I have since removed the front 3/4" spacer with the ZF so its about 18.5 now
Old 01-18-2012, 08:24 PM   #248 (permalink)
guidolyons's Avatar
Member # 56050
I might have more details in my build over on JustIH, I have more pics there of the build than I do here.
My rear 'shaft is ~20" at ride height, not sure what the angle is but it's not severe, BUT your drivetrain is mounted a bit higher than mine. My 205 hangs down about 3" below the frame rail and the rear output is tilted down a bit to help with rear driveshaft angle.
It looks like it hangs down a lot, but it's less than 3" (still need to finish my skid)
Sorry, I don't have a great pic of my rear driveshaft angle handy.
Old 01-18-2012, 09:56 PM   #249 (permalink)
Member # 16680
Yeah, thats a big difference. You seem to have a lot less lift than I do also. The bottom of my frame rails is 24.5"
Old 01-20-2012, 12:06 AM   #250 (permalink)
Member # 16680
Got a little time in the garage. here are some in progress pics
Got the new bulkhead mocked in. Still need to finish welding
Weld flange is on the back side
the rear deck lid fits over the new bulkhead
Cut 22" out of the rear inner fenders. Gives a lot more foot room for my kids and should make for a better B pillar cage mount
Also gives a lot room for the front eat to move back some
