anther 80 build - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-21-2011, 03:06 PM   #101 (permalink)
Member # 105834
Looking good Damon; You have tons under you so don't be afraid to raise the C/G a bit. Get that flat skid plate.
war pony build
war pony is offline   Reply With Quote Quick reply to this message
Old 01-24-2011, 08:48 PM   #102 (permalink)
Member # 16680
got some different headers, ford small block guys take not. These fit much better. was able to pull the motor up and back, I think this is where I will stab it. Crank bolt appears to be at 35 at ride height, top tranny bolt is about 41
old header clearance, this was actually touching
new header clearance didnt move the motor at all
header comparo. These are summit cheapo headers on the bottom, smog leagal for the year with block hugger headers on top, non smog.
link to headers, will work on 351 or 302
http://www.summitracing.com/parts/SU...5&autoview=sku
new height
old height. its not much higher, but further back by 2" or so
plug ugly is offline   Reply With Quote Quick reply to this message
Old 01-26-2011, 02:10 PM   #103 (permalink)
R290's Avatar
Member # 46467
Don't forget to leave a bit of room for insulation.
A lot of newer trucks have a foil and fiberglass shield which helps reflect heat and insulate the floor pan from transmission and engine heat. Would be nice to fit one of those in there.
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 01-26-2011, 05:34 PM   #104 (permalink)
Member # 16680
Im gonna coat the headers, coat both sides of the fireway with spary on insulation (lizard skin), make heat shields along the exhaust, and "rhino" line it. If its still too hot, Ill do some sort of other shield.
Old 01-27-2011, 09:58 PM   #105 (permalink)
Member # 16680
motor is mounted. needs finish welding and some gussets. Ill have to trim the pass footwell just a little bit.
drivers side will have no cutting
motor is offset 1 7/8
I figured cut once, fill later
Old 01-27-2011, 11:25 PM   #106 (permalink)
Member # 105936
Motor Mounts and Driveshaft
Very nice!
Going with a driver side drop really does reduce the amount of firewall cutting that's necessary.
How long do you expect your rear drive shaft is going to be? Is your transfer case level with the bottom of the frame? I ask as I have a NP241C sitting in my Scout 80 right now that I'm finalizing the position for. It looks like my rear drive shaft will be just a little longer than yours so I'm curious how your driveline angles are going to work out.
You also mentioned that you sourced your motor mounts from a Bronco vendor. I would appreciate it if you can say who and provide a part number.
Thanks
Pete
OC IH is offline   Reply With Quote Quick reply to this message
Old 01-28-2011, 08:39 AM   #107 (permalink)
Member # 16680
the rear shaft is gonna be about 28 to 29 inches with a double cardan rear shaft. The front shaft is gonna be at 48 or so, I may look at doing an intermediate shaft????????
Belly pan is totally smooth, 205 is above the rails.
motor mounts can be had from Toms Bronco parts, Driven Auto or Jeffs Bronco graveyard.
Old 01-28-2011, 10:05 AM   #108 (permalink)
ChestonScout's Avatar
Member # 109153
That does look a lot better with the new headers
RIP TTC
Dont let the haters get you down, alexray55!!! I would rather see ten homebrew rigs built with ingenuity and sweat than ten rigs built with a checkbook or credit card.
ChestonScout is offline   Reply With Quote Quick reply to this message
Old 01-28-2011, 10:25 AM   #109 (permalink)
Member # 16680
top tranny bolt is at 44", belly 24.5, crank at 35. Should be pretty stable.
Old 01-29-2011, 02:47 PM   #110 (permalink)
Member # 105834
Looks good , keep up the work and the pics.
war pony build
Old 01-30-2011, 01:39 AM   #111 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Glad to see you making some more progress.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 09:31 PM   #112 (permalink)
Member # 16680
got another day in the man cave, worked on tranny mounts. Motor is tilted back about 3.8 degrees, I think factory is 5.0, so should be fine.
a little under an inch clearance for the 205 to the bottom of the frame
the weight of the motor brought the back down some, frame is now just under 25"
Old 02-13-2011, 11:40 PM   #113 (permalink)
Member # 16680
duplicate pics from anotherthread, just wanted to add these to the build thread
heres what I cam up with
I hadto drillout the clutch mc a 1/16th to fit the wilwood m/c
Old 02-24-2011, 08:13 PM   #114 (permalink)
Member # 104800
Nice build!
Thanks for the reservoir. Glad I could help out with some build money.
csmith24 is offline   Reply With Quote Quick reply to this message
Old 02-24-2011, 10:19 PM   #115 (permalink)
Member # 16680
thanks Casey. It did help, as a matter of fact.
Old 03-07-2011, 06:03 PM   #116 (permalink)
offroadguys's Avatar
Member # 168359
Looking good... I see you have some rust, I think it was a factory option.
Anyone BUT Obama 2012!
offroadguys is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 08:33 PM   #117 (permalink)
levi1a's Avatar
Member # 106935
This is gonna be a sick as rig. Frame plates are .
SEBA
levi1a is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 01:43 PM   #118 (permalink)
Member # 16680
how would you guys flange this cradle to make it removeable? Or would you make it removeable? I would like to be able to drop the oil pan without lifting the motor.
Old 03-09-2011, 02:15 PM   #119 (permalink)
Debauchery Wizard
BeefCakeScout's Avatar
Member # 80219
awesome MSPaint skillz
I'll shit in your sunroof
BeefCakeScout is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 02:26 PM   #120 (permalink)
Member # 105834
Like BeefCakeScout ,But I think I would use two bolts on each side.
war pony build
Old 03-09-2011, 02:46 PM   #121 (permalink)
R290's Avatar
Member # 46467
It if was a bit wider, maybe you could wiggle the pan out. Not sure where your links are going. The headers are going to be right there too. Plates on each side bolted in, or just one big bolt down the middle?
Or a combination of the two. Weld some flat bar to craddle so it overlaps the motor mount This would prevent it from twisting. The big bolt straight down will not let it spread. Trying to think of the forces on that cross member
73 IH Scout
Old 03-09-2011, 02:48 PM   #122 (permalink)
R290's Avatar
Member # 46467
I'm too slow.. I like beef cake idea too, easy and pie It really boils down to access and it hard to see the other side.
73 IH Scout
Old 03-09-2011, 03:23 PM   #123 (permalink)
Debauchery Wizard
Member # 80219
Old 03-09-2011, 04:17 PM   #124 (permalink)
Member # 14640
As shown, with or without the cradle, all the forces will try to rip the mount (horizontal square tube) from the vertical inner frame wall.
Perhaps forget the cradle and reinforce/triangulate the mounts instead?
Note, orange is drawn in 2d, but intended in 3d, say about 6" front to back?.
Orange "captures" the frame on three sides using a short plate on the outside, a tall plate on the inside, and a flat plate on top to tie the two together; plus 2 or 3 plate triangles (shown striped) as gussets. Essentially you're making the frame stronger and taller at the engine mount area.
Basically, you're almost double boxing the frame at the mount, while vertically entending and gusseting the inner wall.
Red is drawn 2d and intended as 2d: Plate triangles welded to the front and rear faces of the existing horizontal square tubing.
Its important to make the vertical orange plates extend above and below the existing frame rail. You might box the rail entirely and add a bottom orange plate, too. Make the side plates too short and they'll want to punch through the existing frame rail side. You want to instead press evenly along the whole surface of the frame rail side, especially the 90 degree bends at the top and bottom.
If you still want to stiffen from frame-rail to frame-rail, then add some sort of strut-tower-to-strut-tower bridge type stiffener (like the ricers use) over the top of the engine: Shown in blue with hex = bolt heads for cross-engine-piece removal.
I have seen this done with roll cage tubing using a tubing bender instead of square tubing and a band-saw Then make the removable joints flanged and sleeved (like header/collector flanges) for easy crossover tube removal.
Monkeyplasm is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 04:29 PM   #125 (permalink)
Member # 16680
ILl gusset the the engine mounts for sure, and coil over hoops will go just forward on the enging mounts, which will be tied to the tube fenders and cross over the engine. Im just trying to figure a good way to mount he cradle.
The oil pump sticks pretty far down, its hard to get the pan off without a lot of clearance
