anther 80 build - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2011, 04:38 PM   #126 (permalink)
Member # 14640
Originally Posted by plug ugly View Post
ILl gusset the the engine mounts for sure, and coil over hoops will go just forward on the enging mounts, which will be tied to the tube fenders and cross over the engine. Im just trying to figure a good way to mount he cradle.
Given the quoted text above (engine mounts reinforced and frame rails tied together), then why use a cradle at all? Seems like it would be in the way and totally redundant. Maybe I'm just being about it?
Monkeyplasm is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 06:01 PM   #127 (permalink)
Member # 16680
I don't know. I thought adding a cradle would make the mounts super bomber and eliminate a lot of the fframe flex. most factory rigs have a sort of cradle. Now, i know lots of the suspension stuff hangs off it too, but ????
plug ugly is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 06:30 PM   #128 (permalink)
Member # 100982
I don't have a cradle in mine. I do still have the factory crossmember under the radiator though. I would try and wrap it around the top of the frame.
Scout build thread-
rkscout is offline   Reply With Quote Quick reply to this message
Old 04-17-2011, 09:18 PM   #129 (permalink)
offroadguys's Avatar
Member # 168359
Update?
Anyone BUT Obama 2012!
offroadguys is offline   Reply With Quote Quick reply to this message
Old 04-18-2011, 11:39 AM   #130 (permalink)
Member # 16680
nothing accomplished. Decided to scrap the rear leaf springs, and have been working on a 4 link with coils.
Old 04-21-2011, 09:38 PM   #131 (permalink)
Member # 16680
Started working on my truss todaytoday. Not very fancy, made from 2x4x.25. Its still a little long, and I need to figure a good way to tie it into the housing.
Need to add some material to my frame, figured I would use some 3/16 2x4 nd incorporate the body mount into it. This will be the cut line.
Old 04-22-2011, 03:54 PM   #132 (permalink)
Member # 100982
Looking good. I tied my truss into the diff cover. What coils are you going to run?
Scout build thread-
Old 04-22-2011, 04:21 PM   #133 (permalink)
Buck Dodson's Avatar
Member # 35185
And here's how I did mine...
This is a Ruffstuff diff cover and the bolts go all the way through the truss.
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
Buck Dodson is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 04:56 PM   #134 (permalink)
Member # 16680
early bronco coils, 3.5" lift progressive rates with Duff shorty upper buckets.
Buck, I was looking for pics of yours, but couldnt find the thread. Where did you put your upper link mounts at the frame?
Old 04-22-2011, 05:05 PM   #135 (permalink)
Member # 100982
[QUOTE=plug ugly;12808951]early bronco coils, 3.5" lift progressive rates with Duff shorty upper buckets.
Buck, I was looking for pics of yours, but couldnt find the thread. Where did you put your upper link mounts at the frame?[/QUOTE
He had pics in my thread of his, looked through my thread, but it's only a red x now. Here's how I tied my diff into the truss.
Scout build thread-
Old 04-22-2011, 05:11 PM   #136 (permalink)
Member # 16680
The only issue I am having is that to get the pinion pointed in the right direction, the diff cover is a good few inches back from the truss. Im on duty for af ew days, so my head is swimming with ideas. Id like to find someone that can weld a web in there, along the top of the housing. Sterlings have been known to spin tubes. I dont think I would be comfortable mig'ing the web. Ive been told to use a nickle rod, but thats beyond my ability.
Old 04-22-2011, 05:19 PM   #137 (permalink)
Member # 100982
What's the problem with rolling the truss back so it's even with the diff cover?
Scout build thread-
Old 04-22-2011, 08:31 PM   #138 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
I welded angle iron onto my truss.
On the dif cover, I ran 1/4" plate over the angle....
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 09:42 PM   #139 (permalink)
Member # 16680
wont sit flat
Old 04-22-2011, 09:51 PM   #140 (permalink)
Member # 35185
Shhhhhh...
http://www.binderplanet.com/forums/s...highlight=link
Buck Dodson
Old 04-22-2011, 10:01 PM   #141 (permalink)
R290's Avatar
Member # 46467
wont sit flat
Compound angles. Easy for me to say cut and reweld.
can you make something like this, looks a lot like what Mike posted
Edit... why not use some Ni rod and weld to the housing?
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 10:21 PM   #142 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
Wish I had that piece that attaches to the dif cover when I made mine.
Old 04-22-2011, 10:24 PM   #143 (permalink)
Member # 125922
This is what I built with the diff cover helping out a little, I built the diff cover too.
scouttanks is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 10:33 PM   #144 (permalink)
Member # 168359
One of the reasons I like this vintage scout is (aside from being pre-smog) the super shitty fabber friendly interior
You should see mine......
Old 04-23-2011, 07:46 AM   #145 (permalink)
Member # 16680
thats what I was thinking. A single web welded to the housing. I just dont know how to stick weld.
I like the diff cover idea, but it would require lots of fill pieces at off angles to fit right and I am looking for a cleaner solution.
that 60 looks nice Scouttanks
Old 04-23-2011, 11:16 AM   #146 (permalink)
Member # 125922
Thanks, its not to hard to do off angles but it dose take time fitting it. The rear is a dana 70U BTW.
Old 04-23-2011, 02:50 PM   #147 (permalink)
Member # 105834
You don't need to know how to stick weld with the NI rod. It is kinda like soldering. Just pre heat, cool very slow and peen the snot out of it.
war pony build
war pony is offline   Reply With Quote Quick reply to this message
Old 04-23-2011, 03:10 PM   #148 (permalink)
Member # 16680
whats peen?
Old 04-23-2011, 03:33 PM   #149 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
whats peen?
Chip the slag off..... As in ball-peen hammer.
Old 04-24-2011, 12:23 PM   #150 (permalink)
Member # 105834
whats peen?
Peen, as in relive the stress of the weld. Use a slag hammer to put indentations into the weld and this action will help to relive the heat and cool cycle of the weld.
war pony build
