anther 80 build - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-21-2011, 08:57 PM   #151 (permalink)
Member # 159101
Plug,
Any updates? I love the build and been following it, just curious.
Livin' the Dream
1966Scout800 is offline   Reply With Quote Quick reply to this message
Old 05-21-2011, 10:04 PM   #152 (permalink)
Member # 16680
no, Ive been working a lot of OT, and just got back from taking the boys to Disneyland. I should get some "me" time in the coming weeks.
the body is off, Im working on the rear 4 link, and waiting to take the body to my cousins powdercoating shop to sand blast the thing.
Thanks for the interest
plug ugly is offline   Reply With Quote Quick reply to this message
Old 05-23-2011, 08:31 PM   #153 (permalink)
Member # 159101
Sorry plug but what hydroboost did you go with? Was it from an astro van if I recall? I'm getting ready to put a boost in my rig just trying to sort out some details. Thanks
Livin' the Dream
Old 05-23-2011, 09:13 PM   #154 (permalink)
R290's Avatar
Member # 46467
I know you might have said, but the bronco gas tank will not fit?
The 800/80 frame is like an 1" wider then the Scout II gas tank
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 04:07 PM   #155 (permalink)
Member # 16680
not in stock form. The bronco tank is 31.5 by 21 by 15.5. The intent was to use a bronco tank thats 25 gallons, and only 13" tall as opposed tot he 33 gallon tank I have. When I stretched the rear frame, I did so with 2x4 to make it 2" wider, and allow the bronco tank to fit. I was going to run leaves, and planned on using the bronco tank. Changing to the rear 4 link, Im not sure I will have the clearance AND be able to run a rear winch as planned. So the verdict is still out at this point. I have a scout II tank, but would like more gallonage 9at least 25) so I may look at building my own, just not sure I have the fab skills to make a good one.
My hydroboost is a a chevy unit, but from VANCO. Not sure how it differs from an astro van unit. I 'think' some of the astros are 2 bolts instead of 4, but cant say for sure.
Old 05-24-2011, 09:13 PM   #156 (permalink)
R290's Avatar
Member # 46467
My bro gave me a nice big piece of 1/8 aluminum diamond plate that I could use to make a tank. You really need to make a cardboard / wood mock up tank, so you know just how to cut the metal. Plus I'm running F.I, so for me buying a weld in sump would make that easier. If you decide to build a tank and need it welded let me know, I'm pretty good with the TIG welder.
I like the welding part.
The 33 gal bronco tank is super cheap, just over a C note
73 IH Scout
Old 05-24-2011, 09:37 PM   #157 (permalink)
Member # 159101
Thanks plug, I don't think vanco is around anymore after what happened with brandon???? I'll just be hitting the pnp soon. Anyways, I take it you wanna mount the tank between the frame rails. I'm just curious because I was going to mount a twenty gallon in the bed and build a shelf above it similar to mocha mikes. Just wanna hear your reasoning. Thanks.
Livin' the Dream
Old 05-24-2011, 09:55 PM   #158 (permalink)
Member # 51801
My vote is build your own.I built mine and it works well.Kind of wish it was a little smaller (29 gal )and I had some clearance problems at the start but Im happy with it.I think there are a couple of pics in my build.You can do it!!!
69 IH 800,TBI392,TF727,D20,2to1 box,tons with 4.88s,power steering/Brakes,36" Super Swampers.
rgwestra is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 10:22 PM   #159 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
Check out Scout Dude's (Joel) build thread for tank ideas...
http://www.pirate4x4.com/forum/showp...8&postcount=35
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 05-25-2011, 09:27 AM   #160 (permalink)
Member # 16680
Vanco is still in business, I have spoken with the recently.
Craig, thanks for the offer, I might take you up on that.
Id like to build my own for sure so I can run an intake "ford" pump to run my FI also. Just have to look at teh cost comparison basis, and fitment when everything is in as far as suspensions etc. I figured a nice "dog leg" tank would work, but with the 4 link and lower lift height, it may get tight. I dont want to sacrifice much, if any, floor space.
Old 05-25-2011, 10:33 AM   #161 (permalink)
R290's Avatar
Member # 46467
Alive and well, that were I got mine http://www.vancopbs.com/
He answered the ph eveytime I called.
73 IH Scout
Old 05-25-2011, 03:58 PM   #162 (permalink)
Member # 159101
Alright thanks just didn't know what was up after reading Brandon's thread over the hydroboost. Plug, I also vote build your own by the looks of it you have the fab skills . Much more options you can work with.
Livin' the Dream
Old 05-27-2011, 08:06 PM   #163 (permalink)
Member # 16680
so i had about 4 hours this afternoon, and have to work all weekend. here is a few pics of shtuff I have been tinkering with here and there.
A full day or more was spent chipping this tarry crap off. It came off easy enuf with a harbor freight air chisel.
th white crap, seam sealer I imagine, is a PITA to get off. I used an air hammer with as flat a blade as i had. It still sucked.
here is the pass side, which I plan to cut and replace for extra leg room for the wife/kids.
Luckily the factory heat shield kept too much "glue" off the bottom, even though I am leaving it on this side till I cut it out.
Ended up with 4 piles, all bigger than this
The tub is ready for sand blasting, sheet metal work.new firewall and floors, and bed liner/insulation
Also been working a little more on the rear links
I needed to raise the upper links as mentioned before. I plasma'd the bulk off, and the neighbor owns a machine shop with a nice 6" belt sander. That sander helped A LOT. I plan to cut on the yellow line to clear the body. The piece on top is the middle factory body mount, which I will weld back onto the body, and use this piece as a upper link mount and body mount. Its cut from 3x5x3/16
still just mocking and punching numbers through the calculator
Old 05-28-2011, 10:18 PM   #164 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Glad to see some more progress
Who's link brackets are you using? That's a lot of adjustability.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 05-29-2011, 07:32 AM   #165 (permalink)
Member # 16680
ruff stuff
Old 05-30-2011, 12:30 AM   #166 (permalink)
guidolyons's Avatar
Member # 56050
ruff stuff
I thought so, Dan makes good stuff
Old 05-30-2011, 09:43 AM   #167 (permalink)
Member # 16680
yes he does.
Does anyone know a good set of rear 4 link numbers to shoot for? Ive read the threads, but never really seen a good set of numbers to shoot for.
Right now, Im at
87 AS (can go higher, but not lower)
29.6 roll center
.5 degree roll steer
5 degrees piinion change through stuff to droop.
Im thinking Im good, but do I want to be able to adjust MORE AS in?
Old 06-01-2011, 08:12 PM   #168 (permalink)
Member # 16680
change the truss a bit. Gives me some more welding area along the inside part. Nothing exciting, but as you guys know, this shit takes a lot of trail and cutting.
Old 06-01-2011, 08:16 PM   #169 (permalink)
Member # 16680
OH, and heres the link numbers im looking at.
Old 07-01-2011, 01:55 PM   #170 (permalink)
Member # 16680
minor progress in the rear link set up. Most things are tacked in place, and I think final. Still waiting for someone to tell me that my numbers look good.
I can not figure out how to make these damn screen shots bigger.
Old 07-01-2011, 02:22 PM   #171 (permalink)
Member # 161937
Looks great Damon. Hurry up and get this thing done. One quick question though. How come you didnt move the lower front links in a little on the crossmember to give more traingulation? It looks like you already have a fair amount, but if you have room to have more would it be benificial?
jrad12381 is offline   Reply With Quote Quick reply to this message
Old 07-01-2011, 05:24 PM   #172 (permalink)
Member # 16680
it increase the understeer quite a bit, and I was trying to keep it as close to 1 degree as possible.
Old 07-02-2011, 01:48 PM   #173 (permalink)
Buck Dodson's Avatar
Member # 35185
IMHO, this is your most important bracket
You have three holes for an adjustment of AS and I would expect a noticable difference in handleing between each of the three holes. You're triangulation looks similar, likely a little more than mine and I'm very happy.
When you drive it around, let it cycle into place and change the frame end of the upper links until it gives you the best (compromise) charactistics.
Woohoo, start welding!
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
Buck Dodson is offline   Reply With Quote Quick reply to this message
Old 07-02-2011, 04:22 PM   #174 (permalink)
Member # 16680
actually I have 5. I can change the AS quite a bit.
Buck, do you know what kind of rear steer you are working with?
Old 07-02-2011, 08:36 PM   #175 (permalink)
Member # 35185
No, I don't remember, but I know that is one of the elements of changing the frame end upper mounts,
Buck Dodson
