anther 80 build - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-03-2011, 06:24 AM   #176 (permalink)
Buck Dodson's Avatar
Member # 35185
My old eyes cant read your screen numbers for shit...
What are you upper and lower link lengths?
Can you move your frame end upper link mounts forward on that frame extension? It looks like it would allow you to run longer uppers, closer to the same length as the lowers. I "think" that would do a couple of things, allow for the links to move in more similar arcs for less binding, allow for adjustment of AS on the lower end with less rear steer.
Last time I tweaked mine, I decided I had the least rear steer in the middle hole for the upper frame mount. I think this was an AS around 50 and the higher hole calculated near 100 AS and as I recall the feeling was the rear end would try to push through a corner, which I took as rear steer.
Also, my uppers and lowers are nearly the same length about 24" and 29" OAL. All 4 are made identical and the 5th one is stored as a spare in the rig. If I ever needed a spare, I can replace any of the links with the same spare.
So,
If you are still in the tweaking and tacking stage, try looking at longer uppers and moving the frame end upper link mound forward to equalize the link length a bit.
If you are past the tack stage... Run that bitch!
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
Buck Dodson is offline   Reply With Quote Quick reply to this message
Old 07-03-2011, 08:00 AM   #177 (permalink)
Member # 16680
I did play around with the uppers, and found it really just affected the pinion angle more than anything. Longer links do increase the AS a little, but only a few percentage points.
AS 56%
Roll Center 29
-1 understeer
plug ugly is offline   Reply With Quote Quick reply to this message
Old 07-03-2011, 10:39 AM   #178 (permalink)
Member # 35185
AS 56%
Roll Center 29
-1 understeer
What do you mean it affects pinion angle? It affects the roataion of the pinion as the suspension cycles from bump to droop, or are you talking about Static pinion angle?
Are your axle mounts and truss fully welded? I'm assuming you're running a CV Drive shaft.
Buck Dodson
Old 07-03-2011, 12:31 PM   #179 (permalink)
Member # 16680
yes, pinion angle through the travel cycle.
Nothing at this point is fully welded. I 'may' ditch the body lift, and increase lift height by an inch or so to get more crank to axle clearance in the front. IF I do that, I need to bring my lower frame mounts closer together to keep a negative roll axis to keep understeer instead of oversteer.
sooo, I have another questions too. I have and was planning to use some FOA coilovers in the front. With the radius arms I have, it would be udersimple to just throw some early bronco coils on the front of this thing, and I have the room for it. Is it really worth the jump to c/o's on a street(10%) and trail(90%) rig? I just worry that IF there is a problem with the c/o, the front end is toast (bent shaft, etc) as opposed to just pulling off a damaged shock. Im shooting for ultra realiability so I can take my 3 and 5 year old along on trips.
Old 07-03-2011, 01:12 PM   #180 (permalink)
Member # 35185
I wish I had my new tranny in the rig and more hours on the trail to tell you. You'll get tired hearing "why did you put a Scout on a Bronco frame?" with the coils
Coilovers are 10+ on the Cool-O-meter...
Buck Dodson
Old 07-03-2011, 03:26 PM   #181 (permalink)
Member # 63684
I understand trying to get it right the first time but you may be splitting hairs on the -1 under-steer. My rig is close to yours in weight and height, has the same rear roll center within a 1/2" and similar axles. I have 2 degrees of over-steer and apparently to dumb to feel it. I drive to most trails and back on bias 39.5's without complications. My antisquat is adjustable between 78-92-108. I run 92% and it is very predictable and neither squats or jacks. You have built a lot of adjust ability and I wouldn't hesitate to run the numbers you have. And I wouldn't hesitate to run coils on the front. Coilovers take up less real estate and are easier to mount and perhaps better in the long run but quality shocks and coils can get it done also. I'd ditch the radius arms and run a three link in the front. I gotta laugh I met you three to four years ago and we talked briefly about links and you were happy to have leafs on your Bronco because you thought links were to complicated. Ohh how the times change.Mark
Skorch is offline   Reply With Quote Quick reply to this message
Old 07-03-2011, 04:17 PM   #182 (permalink)
Member # 35185
x2
Buck Dodson
Old 07-03-2011, 04:24 PM   #183 (permalink)
Member # 16680
yeah, Im a dumbass. I think way too much for not being very smart.
I did like the leaves, hung them on the back, and reaized, they were just going to hang too far out there. Coulda gone to a shorter leaf, but then the money spent for a good working leaf pack vs. a link, and it just ended up here.
thanks for the feedback on the links, good to know.
Im seriously thinking front 3 link, but those radius arms work really well, are simple, and really negate the need for a sway bar, which I like. They are too long (46" from axle center line), and at a 24.5" frame height, I need to clearance the frame for up travel at the arms. The only downside to a 3 link is the front axle, 88 kingpin 60. I either need to learn to weld to the cast center section, pay someone to do it, or cut part of the housing back to make room for the link mount on the drivers side.
Where did we meet?
Old 07-03-2011, 04:42 PM   #184 (permalink)
Member # 63684
Well your not a dumbass for asking questions. Welding cast is nowhere near as hard as it is made out to be my Dodge front shares the lower link mount with the tube and the truss and spring bucket are welded to the cast. All using a mig welder. I was thinking about the 3 link while reading that you were concerned about the pinion angle in the rear during suspension cycling. Some would say that's why they make u-joints, I never liked the lack of anti-dive they had on braking. We met at your storage, when my buddy Jeff bought your hardtop. Mark
Old 07-03-2011, 05:16 PM   #185 (permalink)
Member # 16680
oh yeah, thats been a while. Hows he doing?
Old 07-03-2011, 05:31 PM   #186 (permalink)
Member # 63684
He wheels the crap out of it. pic from last year on the Rubicon, we went 2 weeks ago and will go back this Friday. Mark
Old 07-06-2011, 10:37 PM   #187 (permalink)
Member # 16680
so I want to raise and extend the front frame. Is there a reason I can not just use some 2x4 on top of my frame like the below pictures? Of course the pieces I would use would be longer.
Old 07-07-2011, 01:09 AM   #188 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Stacked frames were cool on the '80...along with mullets and triple chromed out Smittybilt roll bars and lots of shocks. I think you have issues if you just stack it and weld it in a few places, or are you going to fish plate and Z it and remove the original frame?
Borderline booty fab body lift IMHO...
By the time you get done plating and fabbing on the original frame, you coulda built a new one from scratch
guidolyons is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 08:40 AM   #189 (permalink)
Member # 16680
Originally Posted by guidolyons View Post
are you going to fish plate and Z it and remove the original frame?:
this would be the plan
Old 07-07-2011, 11:38 AM   #190 (permalink)
guidolyons's Avatar
Member # 56050
Well...then based on your previous frame work, Rock on
Old 07-07-2011, 01:47 PM   #191 (permalink)
Member # 63684
Too bad you can't chop the existing frame, move it up, plate the connection and then work the connection into your lower link mount. I have some 3x3x .188 if you want to stay closer to the original frame size. Mark
Old 07-07-2011, 01:58 PM   #192 (permalink)
Member # 16680
the 2x4 actually helps bring the frame, steering box, and upper c/o mount in some for better clearance. Im just not sure about the strength issue of having a welded seem on top of the old frame and bottom of the new with just a few fish plates here and there.
Old 07-09-2011, 09:46 AM   #193 (permalink)
Member # 105834
If you want to add strength, after you have plated the side of the frame, then go over the top and bottom with some flat bar. This will add a huge amount of strength to the side to side even just some 1/8" would be fine.
war pony build
war pony is offline   Reply With Quote Quick reply to this message
Old 07-09-2011, 11:59 AM   #194 (permalink)
Member # 16680
thanks for the tip
Old 07-12-2011, 04:24 PM   #195 (permalink)
Member # 16680
Im running the 4 link through its paces. The rear shaft is binding at 4" drop at the CV, which means I ll have to limit strap it there. Is 4" at the pumpking adequate? Really, I should limit it to 3.5 to be safe.
Of course, the other less desirable option is to drop the rear tcase........
Old 07-12-2011, 05:44 PM   #196 (permalink)
Member # 4586
Can you change your pinion angle to help with the binding? I don't have any binding through full travel of my rear axle.
RIP Ricky, you are missed.
JetFxr is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 06:08 PM   #197 (permalink)
Member # 105936
Go back and look at the photos in post 170. It looks like he already did that.
I've been watching this as his transfer case sits high to keep a flat belly and was wondering how it would work out.
OC IH is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 06:43 PM   #198 (permalink)
Member # 4586
Well I would get ahold of Tom Woods or Jessie here on Pirate and see about a better drive shaft, I would not limit travel until I had explored all my options.
Old 07-12-2011, 06:44 PM   #199 (permalink)
Member # 16680
well its short too, like 27", and the motor sits pretty flat. I 'think' factory is 5 degree, and I was at like 3. I raised the motor to 5 degrees, and it drops the tcase output by an inch, which should help, I just need to recheck and see what 1" equates to for drop.
I spoke to Jess, the only next option aside from moving things around is the 42 degree cv, which apparently is not very streetable. I like to drive to the local trails, so not really an option
Old 07-13-2011, 02:02 PM   #200 (permalink)
Member # 161937
Damon I have the 42* drive shaft and it is fine on the street. You have to grease it frequently (maybe every few hundred miles) and make sure the inner boots on the CV stay in place but it does fine on the road, and isnt all that much maintenance.
jrad12381 is offline   Reply With Quote Quick reply to this message
