#201 (permalink) |
Member # 16680
interesting. That came straight from Jess at HAD
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club |
#202 (permalink) |
Member # 161937
I have no doubt that it did. He built the drivelines on my truck and thus far I havent had any issues with the limited street time my Scout gets. Its not ideal for the street but so neither is big tires, soft springs, body roll, ect. ect. I know you know way more than I ever will but if your building a wheeler you might as well get all the travel you can get.
#203 (permalink) |
Member # 16680
a few more link pics.
I ended up lowering the tcase and raising the motor, soIm at 5 degrees lean back now. I get 5" of droop at the pinion. Im just gonna live with it. Im also gonna ditch the radius arms and 3 link the front. ![]() ![]() still need to cut the factory rear crossmember out, as the links hit. Was gonna wait till the coils were on to see how much up travel I will actually get though ![]() ![]()
#204 (permalink) |
Member # 16680
well, christmas came early. The wife took the boys to oregon for 10 days, and I actually got two 3 day spats of working in the garage without interuption......so 72 plus man hours later i have accomplished the following.
stripped the 60 of all the radius arm wedges,built a truss, cut a web (not pictured), tacked all brackets aside from the track bar and hydro assist, built a new upper link mount, etc, etc. Upper link mount, I still need to weld the end and gring smooth, and then make an inner bracket to put it into 'double' shear. ![]() ![]() upper link mount and gusset to the top of the housing ![]() 1.75 188 wall truss, slightly angled down for clearance ![]() finger worth of clearance at ride height ![]() new middle body mount ![]() rear mounts.
#205 (permalink) |
Member # 16680
lowered the body down 1". The body is twisted up pretty bad, and the doors wont align, so that will require some work. The sill plates are at 33.5" now with a 24.5" belly height. Should be 6" up travel front. Oh, I also pulled the front stretch back 2" to a total of 4 front and 8 rear.
#206 (permalink) |
Member # 16680
can someone tell me,
is the driver/pass floor level with the ground, or is the A pillar at a slight upward angle?
#209 (permalink) |
Member # 16680
it was scrap tub I cut from an old cage. just mock up links
#211 (permalink) |
Member # 16680
whats the white star for?
#213 (permalink) |
Member # 16680
Looks like flexing the front 3 link gives me what I need. Still lots of stuff on both sides, the lowers are hitting the old leaf mounts. Pinion angle appears pretty good through travel also, so its time to start burning things on for final.
#215 (permalink) |
Member # 16680
not yet, its looking to be VERY tight for track bar to drag link, but 1/8th clearance is 1/8the clearance, sooo, this may lend itself to full hydro
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club Last edited by plug ugly; 08-16-2011 at 07:11 PM. |
#216 (permalink) |
Member # 4001
Looks a whole lot better than the radius arms. I think a box like a SII will work with your current set up. I personally don't like the long sector shafts on a SII box but if you are are using assist, it might be okay. Did you decide to burn the front mounts on yourself after all?
Dysfunctional Rockcrawlers |
#217 (permalink) |
Member # 16680
no, I dont trust my welding for the cast and dont have a torch to heat it up anyway.
I was gonna look at late 70's ford bronco box too. Forward swing, outside frame mount
#218 (permalink) |
Member # 16680
soooooo, I am going to have a small rub area I need to cut out of the floor. Basically 2" up from the corner, and 4.5 down from the corner as seen here.
![]() My thought was to cut a small (6x20) rectangular hole across the floor area there, bend tabs all the way around and fill it with clear lexan. Basicall it would be below the pedals, right at the front axle from the drivers seat. I have to make the cut, and I have to fill the hole, its just a question of WHAT i fill it with. anyone have experiene with lexan? how would it do with the heat from the headers which will be near by?
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club Last edited by plug ugly; 10-24-2011 at 04:16 PM. |
#219 (permalink) |
Member # 161937
If I recall Lexan has a mounting point of 220 degrees. Its very strong and nearly shatter resistant depending on the thickness. Call or text me if you have any questions. My buddy developed lexan diff, and valve covers like 10 years ago.
5.3 TJ linked on ROCKS, ORI's, and 47's Last edited by jrad12381; 10-24-2011 at 04:38 PM. |
#220 (permalink) |
Member # 16680
lexan valve covers?
#222 (permalink) |
Member # 16680
i had it 2" further forward, but that put me at near 115". i just didnt want it 'that' long.
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club Last edited by plug ugly; 10-24-2011 at 07:18 PM. |
#223 (permalink) |
Member # 161937
Yep he sold the patent to the company that owned hooker headers I believe. I had the first diff cover they ever made on my ford. I had it on there for 5 years until I sold it with no issues.
5.3 TJ linked on ROCKS, ORI's, and 47's |
#225 (permalink) |
AF6 OD
Member # 46467
I could TIG weld the links longer. Cut / sleeve / weld . I took that TIG pipe welding class at ARC. They had us welding 1/4 and 3/8 walled 4" pipe in all positions. But they had a nice beveling machine too
73 IH Scout |
