Dash Options - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2009, 07:59 PM   #1 (permalink)
Member # 29177
Dash Options
I ordered a replacement dash to replace the old OEM gauges with my Autometers, but it's not really what I'm looking for.
While driving around with the dash apart, I realized I like the dash better without the overhang of the dashpad. So now I'm looking to replace the entire assembly and possibly order a wiring kit as I am getting tired of looking at the jumble of green wires. Most of that junk isn't even hooked up anymore.
Anyone have any decent close up pics or know of an aftermarket unit?
Blind Driver is offline   Reply With Quote
Old 07-02-2009, 09:26 PM   #2 (permalink)
wondering aimless
JetFxr's Avatar
Member # 4586
Here's mine made it from 6066 aluminum a few years ago, simple to bend up then I welded the end caps on. The dash pad is from a right hand drive, no hump thing on the pass side (but a bitch to find if you trash one). I used VDO gages but Autometers would work also. This photo was shot before I finished the remodel, the Scout steering column plastic thing will also wrap around the column. The speedo is not installed either in this picture.
RIP Ricky, you are missed.
JetFxr is offline   Reply With Quote
Old 07-03-2009, 11:54 AM   #3 (permalink)
Tactical Turtleneck
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
I've seen a few guys lay an aluminum panel over the stock dash and fill it with new gages, then junk the dash pad.
http://pirate4x4.com/forum/showpost....06&postcount=4
Originally Posted by usmcdoc14
sell. the correct word is "sell" you mouthbreathing fuck.
Type like you have a clue.
Urban Wheeler is offline   Reply With Quote
Old 07-03-2009, 03:48 PM   #4 (permalink)
budget76's Avatar
Member # 38264
Send a message via AIM to budget76
Pretty sure Snoop made a cover that replaced the dash pad, like his guage panels he sells now for the round gauges. I know i've seen pics, it was just a big flat sheet covering the whole dash area.
76 Scout, 85 Toy. SOLD
94 Cherokee. 5.5" lift, D44 truetrack rear, 4.10's, 35" MTR Kevlars, etc
budget76 is online now   Reply With Quote
Old 07-03-2009, 04:07 PM   #5 (permalink)
The Fleckster's Avatar
Member # 3178
Here are two different ones from projects I have done. The difference was the position of the indicator lights. I like them because they are labled and have arrows instead of a plain led.
I used Mikes (IH only) stainless dash as that was all that was available at the time. TheyTurned out nice
John
Back Country Binders 4x4 ( bcb4x4.com )
The Fleckster is offline   Reply With Quote
Old 07-03-2009, 04:09 PM   #6 (permalink)
Member # 3178
Lights moved. You gotta snug them down right before you install them to straighted them perfectley.
John
Old 07-04-2009, 06:24 AM   #7 (permalink)
Member # 31431
Fleck - Sweet fawking dash pad. That looks sick.
sprout4two is offline   Reply With Quote
Old 07-04-2009, 06:45 AM   #8 (permalink)
Member # 29177
That's the same panel I ordered, but I was thought it would be a flush fit against the old dash. I may take measurements of the panel and duplicate/modify it later.
Old 07-04-2009, 08:09 AM   #9 (permalink)
Tactical Turtleneck
Member # 26369
I think that was in the RockScout build, but I didn't want to go through the whole thread to find it.
Old 07-04-2009, 09:10 AM   #10 (permalink)
Member # 29177
I forgot about D&C. I like the flat panel much better.
Old 07-04-2009, 11:27 AM   #11 (permalink)
Banned
Snoopy's Avatar
Member # 5650
The krawler dash. That's what I called it. Did it on Rusty. However, I still used round gauges.
Snoopy is offline   Reply With Quote
Old 07-04-2009, 12:40 PM   #12 (permalink)
Member # 29177
Much better looking then using those old damn square gauges. I never could drill a square hole
Old 07-04-2009, 10:25 PM   #13 (permalink)
Mechanos's Avatar
Member # 6704
meh... anyone can drill a round hole.... it takes talent to drill a square hole.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 07-05-2009, 08:23 PM   #14 (permalink)
Tactical Turtleneck
Member # 26369
It's easy if you have a square drill bit.
Old 07-05-2009, 08:56 PM   #15 (permalink)
Member # 52376
got it right here (watch the video its sweet)
http://www.slatertools.com/index.htm
and its called "Rotary Broaching"
dboy is offline   Reply With Quote
Old 07-05-2009, 09:30 PM   #16 (permalink)
AF6 OD
R290's Avatar
Member # 46467
I just looked and Mike now sells a dash conversion that uses the 2 1/16 gauges, he still has the 2 5/8 size too.
I removed my old gauges and the tin cover. I made a cardboard template and then cut of a piece of sheet aluminum I had laying around to fit and then made some cardboard templates of the gauges to figured out my layout. No speedo as the GPS does that job.
I used some 10 gauge copper wire to plug into the existing wiring harness.
edit.. I left in the dash pad as they are good to have in case of accident. Need to get a pic during the day
73 IH Scout
R290 is offline   Reply With Quote
Old 07-06-2009, 06:09 AM   #17 (permalink)
Member # 105834
A coffee pot,can opener,toaster oven and a dish washer. Your dash has it all.
war pony is offline   Reply With Quote
Old 07-06-2009, 08:31 AM   #18 (permalink)
Member # 132020
Great looking dashes, all. I have a 4X8X1/8 sheet of aluminum just for that project. Thanks for the ideas of where to start. Now if only my 345 could rev to that 10K Tach.
spreader is offline   Reply With Quote
Old 07-06-2009, 10:32 AM   #19 (permalink)
AF6 OD
R290's Avatar
Member # 46467
I was going to get a diesel tach as they only to like 5K and that would have been about right. I held off forever on that tach as it went to 10K, but since it matches the rest of the gauges I got it.
You can get some carbon fiber sticker to cover the aluminum to give it a cool look too.
War Pony, now I just need to work on the refrigerated beer dispenser.
73 IH Scout
Old 07-06-2009, 04:30 PM   #20 (permalink)
Member # 105834
for sure on the beer dispenser, and remember it needs to be as cold as the rockies.
war pony build
http://www.pirate4x4.com/forum/showthread.php?t=651553
Old 07-07-2009, 08:45 AM   #21 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Autometer's HotRod series gauges have a tack that are 7000 RPM and are full sweep gauges. Which is why I use them. That way, the freakin' gauge acutally moves between idle and redline.
Old 07-07-2009, 09:05 AM   #22 (permalink)
RustoleumWhite's Avatar
Member # 4506
I've always liked the dash pad and square gauges. Been liking the NO dash I have in the racer/blue truck as well (just a triple pack of gauges screwed to the cowl and a tach strapped to the column). But thats really only appropriate for a stripped down rig.
Never thought of running without the pad and making a plate. Actually looks good (for a wheeler) and opens up the inside a bit. Food for thought, thanks for the idea(s) Snoop .
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote
Old 07-07-2009, 10:22 AM   #23 (permalink)
Member # 2071
You need to get a UniTool or UniPunch and the right dies.. then square holes are EASY.
Just stick it in the press, apply pressure, done.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 07-07-2009, 10:33 AM   #24 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Thanks.
Funny, the reason I built the krawler dash in the first place was so that I could run a bar across the dash closer to windshield (or farther from the steering wheel). Plus the pad was cracked up and didn't match anything anymore.
Old 07-07-2009, 06:46 PM   #25 (permalink)
Member # 29177
I'm liking this one a bunch for $275.00
It'll need to be modified to fit a Scout.
