np202 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2009, 02:20 PM   #1 (permalink)
Member # 36385
np202
I have searched here, and on google and can not find any definate answers. I am picking up an np202 out of a 1958 international, I am planning to install it behind a 454/th400/np241, basically making a 2nd case from it. My main concern is heat, I know the np200's had heat issues on the street, will I see these same issues with the 202, or are they suited for streeatability as much as a np205??
Big4x4Rides is offline   Reply With Quote
Old 09-24-2009, 05:40 PM   #2 (permalink)
Member # 9835
Im sure you will find a lot more guys interested in them and a few threads at http://www.binderplanet.com/forums/index.php
ChiScouter is offline   Reply With Quote
Old 09-24-2009, 09:30 PM   #3 (permalink)
TITUS
IDScout's Avatar
Member # 93509
Are you speaking of the mega truck guys with the 60" tractor tires and rockwells? If so, then yes anything will generate lots of heat when you spin them at those kinds of speeds and run them vertical.
IDScout is offline   Reply With Quote
Old 09-24-2009, 09:40 PM   #4 (permalink)
Member # 36385
no, every site i have seen says that the np200 transfer case had issues heating up badly, had to do with the straight cut gears generating more heat.
Thanks for the other link
Old 09-25-2009, 01:07 PM   #5 (permalink)
DNL
Member # 31995
202s do not have the heating issues that the 200s did.
Dave
DNL is offline   Reply With Quote
Old 09-25-2009, 08:36 PM   #6 (permalink)
Web Wheeler For Hire
Eagle-Mark's Avatar
Member # 26999
Do you need one? Where you at? I've got one in CDA Idaho I've been saving because it has the brake drum on it... but clearing out the storage if you need one...
Addicted and Obsessed with Fuel Injecting Anything!
GearHead-EFI.com
Eagle-Mark is offline   Reply With Quote
Old 09-25-2009, 08:46 PM   #7 (permalink)
Member # 36385
Nope, just paid for one, picking it up Sunday evening.
Old 09-27-2009, 06:33 PM   #8 (permalink)
Member # 36385
picked it up today, and it all looks okay, going to clean it up and put some new seals in it for sure. The rear output yoke has the big drum/emergency brake deal on it, I want to eliminate that and figure I can just use a regular 32 spline yoke off a 208, or 205 and make sure I have the correct id/od seal. As far as shifter, I would like to set up fro twin sticks in the same manner a 205 has em allowing front digs, can anyone point me in the right direction for info on twinsticking these?
Old 09-30-2009, 03:59 PM   #9 (permalink)
Member # 7646
you cant (well ther is no point) 1 shdt rail is for range and the other is for front axle engaugemnt
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II
76 Scoutt II turbo 345 propane
Chief yelling alot is offline   Reply With Quote
Old 09-30-2009, 07:02 PM   #10 (permalink)
Binder's Avatar
Member # 1684
Probably course spline yokes too.
S.N.O.R.T.
Binder is offline   Reply With Quote
Old 09-30-2009, 08:27 PM   #11 (permalink)
Member # 36385
hmmm, that sucks on both counts. I can't find any good write ups on these things
Old 09-30-2009, 11:35 PM   #12 (permalink)
"Official"
Diesel Smoke's Avatar
Member # 27575
Hmmmm.....I wonder why?
There a great case for the trucks they came in, but as far as putting one in a project, there is no reason not to go with a 205. 205 parts are available everywhere, upgrades are available and there are 1000's upon 1000's of them around. The NP 202 is old technology, and not the old technology the has stuck around. I really don't understand why you went with one in the first place.
Wheeling?!?!? WTF is that?
Diesel Smoke is offline   Reply With Quote
Old 10-01-2009, 02:35 PM   #13 (permalink)
Member # 36385
ahhh, because there isnt alot of info out there since they arent the most common thing, that makes em junk??
